AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jun 17, 2025 at 8:26 AM
    AZ_J
    AZ_J Well-Known Member
    Ahwatukee, AZ
    2019 TRD OR 4x4 DCSB
    265/75r16, sliders, softopper, roof rack, 6112/5160's
    I just did all 4 corners of my shocks just this past weekend. Actually not too bad. About 1:15 each corner. Did the rears on friday, fronts on saturday with an alignment. I got the fronts pre-assembled so that saved me some time. I also did one corner at a time instead of both sides at the same time. So maybe you can shave some time off that way.
    Having the right tools definitely helped me. [floor jack, jack stands, breaker bar, ratchet & sockets, ratcheting wrenches, 3/8" and 1/2" torque wrench, and about ~1 beer per corner]
  2. Jun 17, 2025 at 4:13 PM
    Queso_Blanco
    Queso_Blanco Formerly known as "Bad_Guac"
    Tyler
    Mesa, AZ
    '23 Super White DCSB TRD OR 4X4
    Accutune stage 4 Adjustable King 2.5's w/resi's All the meso Diamondback HD Method 701's 17x8.5" 285/70R17 Diode dynamics fog/ditch/stealth lightbar Sliders RCI skids OTT tune Total Chaos bed gussets Etc...
    1 beer per corner?! Whoopsie :anonymous:
    Yacob_D and XPOTRPR like this.
  3. Jun 17, 2025 at 4:22 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Those are rookie numbers
    Queso_Blanco[QUOTED] and Yacob_D like this.
  4. Jun 17, 2025 at 5:27 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oof.. between all us Saturday..
  5. Jun 17, 2025 at 6:22 PM
    Queso_Blanco
    Tyler
    Mesa, AZ
    Shhhhh
    :anonymous:
    Its fiiinne:drunk:
  6. Jun 17, 2025 at 7:22 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    How can you expect to over-torque things enough unless you on the second case by the third corner? :drunk:
  7. Jun 17, 2025 at 7:34 PM
    MGMDesertTaco
    Don't use seafoam. You'll fugg up the motor.
  8. Jun 18, 2025 at 6:08 AM
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    We don't talk about that, plus we grilled out.
    XPOTRPR[QUOTED] and Queso_Blanco like this.
  9. Jun 18, 2025 at 7:09 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Jim, thank you for the offer! I actually have someone stopping by tonight to help around 5:30. Your welcome to stop by for a beer if you'd like.
  10. Jun 18, 2025 at 9:35 PM
    time623
    James
    AZ
    Moved back into Tempe last weekend from Chandler, got a problem I’ve never encountered after living my entire life here in the Phoenix area… Scorpions
    Only found 1 inside so far, but after that one I picked up a black light and checked the backyard to find 6 more hanging around.. Likely many more hidden deep in the planter bushes.
    Did the perimeter of the house with some general pest control spray to hopefully keep their food out, and planning some nightly hunting to knock down the population. Any other ideas from anyone who’s dealt with them before?
  11. Jun 18, 2025 at 11:22 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Gonna have to keep at it a long time because they can go months without eating. They also only need like 1/16" to get into something so spray any and every crack. We had an infestation in our block wall so between spraying that and the footing of the house, we have only seen a couple in the last year or so and none inside.
    time623[QUOTED] likes this.
  12. Jun 19, 2025 at 1:57 AM
    MGMDesertTaco
    I always use Bifen IT with Tekko pro, but never had an issue with scorpions. (north phoenix) That combo's potent. There's some other products that will probably work a little better. (CY Kick CS, Onslaught, Demand CS, ect.)
    1. Seal any gaps and cracks around the house perimeter and doors. (caulking, weatherstripping, stucco patch; they can squeeze through the smallest cracks)
    2. Get a one gallon sprayer from HD or wherever. Pick your poison and mix with water per directions.
    3. Wear a mask, gloves, proper clothing and spray 2-3 feet out around the perimeter of the house and 2-3 feet up the sides of the house.
    4. Bifen IT granules can supplement this.
    5. Inside of the home place glue traps around baseboards near water sources and openings. Bathrooms, tubs, doors, ect. Scorpions are practically blind and follow walls for guidance.
    Ditch the protective gear, shower and wash clothes immediately after. The spray will last 2-3 months then you'll need to reapply.
    links...
    https://www.domyown.com/search?w=scorpions&search=
    https://www.domyown.com/bifen-lp-insecticide-granules-p-227.html
    https://www.domyown.com/tekko-pro-insect-growth-regulator-p-10273.html
    https://www.domyown.com/onslaught-f...MI2I_Qk4n9jQMVnyXUAR3OLyj8EAQYASABEgL8a_D_BwE
    https://www.domyown.com/bifen-it-p-...V7y3UAR2oyhi-EAQYASABEgL06_D_BwE&sub_id=11662
    https://www.domyown.com/cykick-cs-p...MIrPqlkYj9jQMVmDnUAR0KyCHXEAQYASABEgJOPPD_BwE
    https://www.domyown.com/demand-cs-p-46.html
    time623[QUOTED], TACOTU3 and Atl-atl like this.
  13. Jun 19, 2025 at 9:12 AM
    Cal671
    Cal671 Well-Known Member
    calvin
    AZ
    08 Taco smurf, 10 fj, 16 runner
    spray fastcap for scorpions and cyzmic to cover any other bugs
  14. Jun 19, 2025 at 12:19 PM
    time623
    James
    AZ
    Saw another one last night slip through a virtually invisible gap between baseboard and floor.. can’t believe it fit through
    Appreciate it!
  15. Jun 19, 2025 at 12:24 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    Might I suggest burning the house down and starting over?
    BillW and time623[QUOTED] like this.
  16. Jun 19, 2025 at 12:36 PM
    time623
    James
    AZ
    If all else fails
    TACOTU3[QUOTED] likes this.
  17. Jun 19, 2025 at 1:17 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    I cannot recommend a Smith sprayer enough. Best $50 (x2... because bugs and weeds) I've spent in a while. The spray pattern and volume is top notch so you can hit a wide, even stripe as you move along.
    time623 likes this.
  18. Jun 19, 2025 at 2:16 PM
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    Well, guys, it is time for me to say goodbye. I still don't have my truck back from the shop (that's not the reason), but I moved to Del Rio, Texas to begin my pilot training for the Air Force. Every one of you who I have had the pleasure of meeting has been awesome, and you guys have given me a lot of good advice for my trucks. Hopefully there is a Texas group as good as you guys, but I doubt it.
    BillW, Yacob_D, azshooter40 and 4 others like this.
  19. Jun 19, 2025 at 3:32 PM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    Good luck, man!
    And just because you move out of state doesn't mean you have to leave...ask me how I know :rofl:
  20. Jun 19, 2025 at 3:37 PM
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
    Sorry I didn’t make it last night. I do appreciate your invite for a beer. If you need any help in the future I am close by
