AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Nov 15, 2016 at 1:02 PM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Anyone want to talk SPOT vs inReach? Both are on sale at REI right now, seems like good prices.
    05tacomabro and Chipskip like this.
  2. Nov 15, 2016 at 1:10 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
  3. Nov 15, 2016 at 1:37 PM
    Aloha Scout
    Aloha Scout Drink beer and smoke your meats
    Getting paid to sit on my couch, drink beer, and make sure these ex-convicts don't steal my stuff as they pack.
    What did Ice cube say?
    Today was a good day.
    Chipskip, Taco Love, phx13 and 4 others like this.
  4. Nov 15, 2016 at 3:19 PM
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    Used an inReach while commercial fishing in Alaska to get messages back and forth from town. It worked well there. Never had any experience with SPOT. Nice for getting your location and a message out.
    phx13[QUOTED] likes this.
  5. Nov 15, 2016 at 4:29 PM
    Aw9d
    Aw9d That one guy
    A very strange thing just happened with my truck.
    I went to the store, parked, bought stuff, came back from the store and stopped my truck in the driveway. Got out, hit the alarm, the beep was half as long and the door wouldn't lock. Unlock, same thing.
    Tried to start the truck, gauges/lights come on and start flickering. I try to start it to see what happens, nothing at all. Starter isn't moving, stereo is running but dim and not flickering. All other lights in the truck were flickering. Ok dead battery.
    Check the battery, 12. 74v and holding steady. Try the alarm again, same thing. Took battery out and had it tested, came back ok. Checked all my cables/grounds, good.
    Plugged in battery, everything is working as normal. Checked battery voltage after starting it and shutting it off, 12.75v and holding.
    WTF?
    The Fluffer likes this.
  6. Nov 15, 2016 at 4:37 PM
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    Sounds like some weird shit Josh was going through to me
  7. Nov 15, 2016 at 4:38 PM
    Aw9d
    Aw9d That one guy
    His issue was different.
  8. Nov 15, 2016 at 4:50 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    I've heard that spot has improved dramatically over the past few years.
    Inreach is nice because of the gps and text communication are in 1 device.
    In my research , I wanted global comms and went with iridium go.
    It pairs with your cell phone and creates its on wi-fi spot. It's worked flawlessly in the Arizona wilderness and backcountry.
    https://www.iridium.com/products/details/iridiumgo
    The monthly plan allows for text and global voice communications.
    It all comes down to how often do you go off grid. Verizon has the best service in the state and I'm amazed I get a signal hunting in some of these deep canyons. But to be able to communicate anywhere on the planet - encourages adventure. Which sometimes meaning going solo.
    Either way you go it's a great (mandatory) piece of gear.
    Az
  9. Nov 15, 2016 at 5:03 PM
    Aw9d
    Aw9d That one guy
    Thanks. I will check the belt tomorrow and see how it looks.
  10. Nov 15, 2016 at 5:06 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Whatever it was, it sounds like you reset it when you pulled the battery.
  11. Nov 15, 2016 at 5:08 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    @RPS1030 or anyone else that does some metal work. What do you suggest for ear plugs. I did some grinding and cutting and my left ear is really mad at me.
  12. Nov 15, 2016 at 5:54 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    I could only find a small dirt hill nearby. not sure if I will have to do more cutting when I can stuff it better.
    Brian007Taco[OP] likes this.
  13. Nov 15, 2016 at 5:59 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    i just use regular old orange ear plugs or headphones if i even use em.
  14. Nov 15, 2016 at 6:01 PM
    Aloha Scout
    I had the exact same problem when I last went through rats eating my wires. Drove the truck home from the dealership after some repairs. Pulled into the garage to repair head light and aux light wires. Get done, turn truck over and it did the same thing you are expierencing. Battery read fine. Eventually stumped, I went and replaced the battery cause I couldn't afford to be stranded somewhere with the same problem later on. Since replacing the battery, never had a problem.
    Aw9d[QUOTED] likes this.
  15. Nov 15, 2016 at 6:07 PM
    Aloha Scout
  16. Nov 15, 2016 at 6:17 PM
    swalters
    swalters Well-Known Member
    Samantha
    Apache Junction, AZ
    2004 Tundra SR5 4x4 V8
    Brute Force Fab front bumper, 5100s, 35" Toyo RTs on Icon Six Speeds
    That's okay, cause my truck is making a gnarly squeak when I reverse. Just started today. Aaron tried looking for where it's coming from when I back up but no clue.
  17. Nov 15, 2016 at 6:38 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
  18. Nov 15, 2016 at 6:44 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
  19. Nov 15, 2016 at 7:17 PM
    Aw9d
    Aw9d That one guy
    Fuck off.
    Still funny as hell.
    But.
    Fuck off. :D
  20. Nov 15, 2016 at 7:24 PM
    phx13
    Rob
    2015 DCSB TRD O/R
    Watching Misery. Haven't seen this in 20 years. Can't wait to watch Bates mess up his legs.
    Fiend13 and Aw9d like this.
