AZ BS thread...
Discussion in 'Arizona' started by Masada, Feb 24, 2010.
Thread Status:
Not open for further replies.
  1. Sep 16, 2010 at 6:15 PM
    #2961
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Right on...thats a great idea though for just chillen around the truck and what not!
  2. Sep 16, 2010 at 6:39 PM
    #2962
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    See, those are useful cup holders! Ha.
  3. Sep 16, 2010 at 7:38 PM
    #2963
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Got my swr meter today and tuned my radio.
    But couldn't get channel 40 below 2.5. 1-20 are at 1.5
  4. Sep 16, 2010 at 8:22 PM
    #2964
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Recheck your ground to the CB and make sure when your tuning it, that you're not touching the SWR meter or the coax isn't crossing the jumper cable from the box to the SWR meter...
  5. Sep 16, 2010 at 8:24 PM
    #2965
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Working may @$$ of, trying to have my homework done before I leave Saturday. I also have an exam tomorrow and Monday.
    Both my first exam, so it does not count :rolleyes:
  6. Sep 16, 2010 at 8:53 PM
    #2966
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I'll double check my readings then and make sure everything is isolated like you stated.
    Would having the 4 foot antenna be a problem becasue I have the screw all the way down.
  7. Sep 16, 2010 at 9:07 PM
    #2967
    Masada
    Taylor
    Laveen, AZ
    No the length of the antenna shouldn't affect you negatively. Might start with it in the middle and adjust from there.
  8. Sep 16, 2010 at 9:07 PM
    #2968
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Nope, I have the 4' Firestick and when Taylor tuned mine we almost gave up having the same issue, but then we put the screw to the max top, put the red cap on, reinstalled the antenna and rechecked.... near flawless. (makes no sense but I'm not complaining lol).
    If you can't get it in though deffinatly recheck the grounds, and from what I saw you really need to make sure to isolate allt he coax from touching each other and yourself as well (including the SWR box). It's pretty sensitive.
  9. Sep 16, 2010 at 9:20 PM
    #2969
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Ill go to the highest setting them move down from there. about what channel are we going to be on. if i cant get it tuned in all 40, i want to at least have the one were going to use working fine.
  10. Sep 16, 2010 at 9:21 PM
    #2970
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I dunno, maybe it's just me but it seems like my '08 was much better built. It seems like the stuff under is rusting a lot faster on the '10 (actually, the only rust I could find on my last truck was one tiny little surface spot on the frame and inside the hitch from towing stuff... and most of you know it wasn't exactly a street queen either, even drove it up hwy 1 and to the coast several times). Also, the interior trim really seems to not fit as well and flex more.... I dunno just a random observation/rant. Nothing THAT bad but still just kinda... weird.
  11. Sep 16, 2010 at 9:22 PM
    #2971
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    We were estimating somewhere mid twenties most likely depending on cb traffic... so if you can get it somewhat respectable on 1 and 40 it should be ok.
  12. Sep 16, 2010 at 10:32 PM
    #2972
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Bleh looks like I need to re-adjust the skids. The trans skid was a pita to get on with the alignment, now it's shifting under flex (oh the horror sound lol). That shit is torqued down as much as I dared too... need to look into it further tomorrow after work....
  13. Sep 16, 2010 at 11:50 PM
    #2973
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Thanks Jake and Taylor for the advice!!
    I retuned it and was able to get 1 and 40 both at 1.5.
    20 is almost at 1:1
    The chart says that a 1:1.5 is only a 3% power loss so its basicaly perfect.
    a 1:2 is a 11% loss
    a 1:3 is a 25% loss.
    I was able to talk to a trucker so the CB is ready to go!
  14. Sep 16, 2010 at 11:51 PM
    #2974
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Awesome man, glad it worked out :D
  15. Sep 17, 2010 at 5:47 AM
    #2975
    Masada
    Taylor
    Laveen, AZ
    David that's a great tune...you will be fine.
    But just so your clear, the SWR is expressed as a ratio so 1:1 is 100% transmition of the signal. So a 1:2 is only 50% and 1:3 is 33% So that's why you want something that's 1.5:1 or lower on all channels. you did good david :thumbsup:.
  16. Sep 17, 2010 at 10:52 AM
    #2976
    ColtsTRD
    Scott
    AZ
    Theres gonna be 55 of us...on a trail...probably not going very fast...if we don't get my CB working i'll just get out of my truck and walk up to a Tacoma :laugh:
  17. Sep 17, 2010 at 10:56 AM
    #2977
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    College lesson learned: it's not a good idea to invite a lot of people to your room to play beer pong.
    Punishment: Confiscated table ($50 value) and enrollment in alcohol edu.
  18. Sep 17, 2010 at 11:05 AM
    #2978
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    :woot:
  19. Sep 17, 2010 at 11:08 AM
    #2979
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    x2. :woot:
  20. Sep 17, 2010 at 1:09 PM
    #2980
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    I saw one of the RAs of my dorm at a night club last night......he told us to get fake ID's and have a great freshman year.
Thread Status:
