AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Sep 14, 2016 at 11:39 AM
    RavegreenA4
    RavegreenA4 Well-Known Member
    Gilbert, AZ
    2013 Tacoma Double Cab Long Bed Limited
    Me.... pm sent
  2. Sep 14, 2016 at 1:26 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    Have you sold these? I know someone who is looking to buy.
  3. Sep 14, 2016 at 1:54 PM
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    llibrm likes this.
  4. Sep 14, 2016 at 1:57 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Enjoihavok likes this.
  5. Sep 14, 2016 at 2:08 PM
    cmack
    cmack Well-Known Member
    18 Burrito
    i have not. PM me
  6. Sep 14, 2016 at 2:09 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    When can I pay you for some facials?
  7. Sep 14, 2016 at 2:17 PM
    cmack
    18 Burrito
    probably before I sell my gear haahah
  8. Sep 14, 2016 at 2:18 PM
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    SOLD!
    So I made a trip today for some Colorado guys who are coming down this weekend to pick up a bunch of cases... These were too damn good to pass on so I got em for some lucky TW member to snag up!
    Set of Pelican Hardigg Storm 2975 Cases w/ Foam Inserts!
    They are an injection-molded case made of HPX high performance resin, that is virtually unbreakable, dent-resistant and shatter-resistant. It is tough, rugged, lightweight, airtight and watertight. There is a permanently attached Vortex valve that automatically adjusts air pressure without letting in water, and won't unscrew from the case. Press & Pull latches open with the push of a button, yet stay closed securely under impact or stress. The case has unbreakable molded-in hasps that allow the addition of standard size padlocks. It has hinges with integrated feet that hold fast under impact, and create a flat surface for upright stability. It is carried by three double-layered, soft-grip, solid-core handles, lightweight retractable, telescoping handle and rugged in-line wheels.
    Exterior Dimensions: 31.3 x 20.4 x 15.5" (79.5 x 51.82 x 39.37cm)(LxWxH)
    Interior Dimensions: 29 x 18 x 13.8" (73.66 x 45.72 x 35.05cm)(LxWxH)
    -This case has a multilayer cubed foam bottom and a convoluted foam pad in the lid.
    -Injection-molded case made of HPX high performance resin is virtually unbreakable, dent-resistant and shatter-resistant
    -Tough, rugged and lightweight
    -Airtight and watertight
    -Multilayer cubed foam bottom and a convoluted foam pad in the lid
    -Permanently attached Vortex valve automatically adjusts air pressure without letting in water, and won't unscrew from the case
    -Press & Pull latches open with the push of a button, yet stay closed securely under impact or stress
    -Two unbreakable molded-in hasps allow the addition of standard size padlocks, offering another measure of security
    -Hinges with integrated feet hold fast under impact and create a flat surface for upright stability
    -Molded-in stacking ribs provide no-slip stability for multiple case-stacking during storage or transport
    Carrying options:
    -Three double-layered, soft-grip, solid-core carrying handles provides strong, durable comfort
    -Lightweight, retractable, telescoping handle locks in place
    -Rugged in-line wheels have shielded ball bearings, and are composed of a nylon core encased in a polyurethane tread. The wheels are mounted on a solid axle for improved stability and ease of transport.
    In short… These things may be used, but they are indestructible and everything from the clips to the hinges to the weather-stripping is in great working condition. I especially love these cases because of their button-latch designs - which help them from accidentally un-latching. They also fit perfectly side by side between the wheel wells of a 2nd Gen and just below the bed rail tie downs. With wheels for convenience, they are perfect for your camping and/or recovery gear or tools. Keep the foam or remove like I did! It simply pulls out. There are some scratches of corse but nothing major and also some minor adhesive left over from shipping labels - nothing some elbow grease wont take off.
    These retail for over $250 new and thats usually without foam! I’m asking $125 each and would prefer to sell em as a set. It's basically a 2 for 1 deal with free foam!
    Send me a PM if you are interested… I'm located in Old Town Scottsdale!
  9. Sep 14, 2016 at 2:21 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    I'll take the set!
    llibrm and Chipskip like this.
  10. Sep 14, 2016 at 2:26 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    dammit. always late to the party
  11. Sep 14, 2016 at 2:31 PM
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    If you are referring to the cases for sale... send me a PM. I've been helping out TW members with these for weeks now... See post #20868
  12. Sep 14, 2016 at 2:33 PM
    Enjoihavok
    Enjoihavok Never Forget Z.S.
    Erik
    Chandler, AZ
    2021 Tundra Pro
    Same here damn lol
  13. Sep 14, 2016 at 2:39 PM
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    PM sent
  14. Sep 14, 2016 at 2:40 PM
    Techoma
    Alta Mesa, AZ
    Back atcha!
  15. Sep 14, 2016 at 2:42 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    oh my.
    ill have to hit you up next time I am in AZ
  16. Sep 14, 2016 at 2:45 PM
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Do it! Give me a heads up if you can...
  17. Sep 14, 2016 at 2:46 PM
    ramonortiz55
    Ramon
    Texas
    stock
    oh I will.
    what size are the boxes that are side by side that fit in the bed?
  18. Sep 14, 2016 at 2:46 PM
    ramonortiz55
    Ramon
    Texas
    stock
    the bottom picture
  19. Sep 14, 2016 at 2:48 PM
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    In post #20883 they are all the same set of cases.
    2975s...
  20. Sep 14, 2016 at 2:50 PM
    ramonortiz55
    Ramon
    Texas
    stock
    sorry, I was talking about the other post you mentioned by post number.
    apparently the 2975s are the same ones I was inquiring about
