AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Apr 24, 2017 at 1:25 PM
    christhebassman
    christhebassman Cheese head
    Litchfield park
    10 White Boosted
  2. Apr 24, 2017 at 3:29 PM
    Phessor
    Phessor Well-Known Member
    Updated axle ratio information.
  3. Apr 24, 2017 at 3:52 PM
    JTB727
    JTB727 Well-Known Member
    Justin
    AZ
    35's and a Good Time.
    How much backspace does -12mm offset equate too?
  4. Apr 24, 2017 at 3:53 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    I think that equals about 4" backspace.
    JTB727 likes this.
  5. Apr 24, 2017 at 4:20 PM
    JTB727
    Justin
    AZ
    More backspace means sticks out less correct?
  6. Apr 24, 2017 at 4:26 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    Less backspace moves it away from the mounting surface. So this would stick out a little more than a stock wheel which is 4.5" backspace.
    Brian007Taco and JTB727[QUOTED] like this.
  7. Apr 24, 2017 at 4:35 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Have a set of brand new 700lb Icon Coils I found hidden in my parents garage. Bought them for the old truck, never used them before I went LT. $150 picked up. Will fit all 05+ Icons.
    05tacomabro likes this.
  8. Apr 24, 2017 at 5:13 PM
    phillipthetaco
    phillipthetaco Well-Known Member
    Marcus
    Mesa,AZ
    2007 Tacoma Prerunner Barcelona Red
    Wheels and Tires: (5) 35/12.50/17 Toyo R/T tires (5) 17” x 8.5” Matte Black Method NV wheels Black extra thread (ET) spline lug nuts Front Suspension: Total Chaos 3.5” long travel kit Fox 8” x 2.5” coilovers with remote reservoirs Wheelers Super Bumps Limit straps and clevis mounts Total Chaos shock tower gussets Total Chaos cam-tab gussets Maxtrac 4 inch lift spindle Larger Lexus rotors, calipers and brake pads Stainless steel extended brake lines Rear Suspension: DMZ Fabrication Spring Under Kit Fox 16” x 2.5” smooth body shocks with remote reservoirs Fox 4” x 2.0” hydraulic bump stops (shortened to 3”) Custom low profile bolt in bed cage (1.5” DOM tubing) Boxed frame from fuel tank back Custom tube rear cross-member (1.5” DOM tubing) Custom bump stop mounts and strike pads Stainless steel extended brake lines Performance: AFE cold air intake w/reusable filter Nitro 4.88 Gears w/heady duty seals Custom driveshaft with grease-able slip-yolk Odyssey Extreme battery Armor: Custom front tube front bumper (1.5” DOM tubing) w/custom skid plates and valance Custom rear tube bumper w/license plate mount and led light Exterior Accessories/Body: SDHQ “y-strap” for spare tire mounting Harbor Freight 1.5 ton floor jack w/quick release mount Fiberwerx fiberglass front fenders Fiberwerx fiberglass “TT” style bedsides Custom window tint and tint visor Retrofit style Headlights LED tail lights Custom black mesh grill Viper alarm Rigid Industries 30 inch amber LED Rigid Industries 20 inch white LED Rigid Industries D2 Blue rear chase lights X2 Interior: Pioneer touch screen head unit Kenwood mono amplifier Rockford Fosgate 12" P3 subwoofer Infinity Kappa door speakers (4) Weathertech front floor mats LED interior dome lights
    FS: 4 brand new 35 inch general grabber short course style wheels sitting on new 17 inch KMC true Beadlock wheels.
    Cost around 2k new so save yourself some money. $1600
    Possible trades for other tires (grabbers and projects) and method wheels. Also like Vision X and Baja Designs HID lights, KING or FOX 12 inch coilovers, rear chase led box, fiberglass for a 95 silverado single cab, rugged radio headsets and other King or fox coilovers/bypasses.
    *also last picture is of my new truck!
    LTacoman, 2ndGenJonny and MaverickTRD like this.
  9. Apr 24, 2017 at 5:41 PM
    AZM
    AZM Well-Known Member
    Mike C...
    AZ
    06 Tacoma Dlbc 4x4 Trd sport
    PM sent
  10. Apr 24, 2017 at 6:18 PM
    JTB727
    Justin
    AZ
    How did these balance out for you? Any problems with hopping? Im chasing a vibration and think I may have a bent wheel.
  11. Apr 24, 2017 at 6:20 PM
    christhebassman
    Litchfield park
    10 White Boosted
    Ya @stumbles is right. I think it's like a 4 inch backspace. I can barely notice the difference with my new wheel setup. Here's them on the truckimage1(3).jpg
  12. Apr 24, 2017 at 6:23 PM
    christhebassman
    Litchfield park
    10 White Boosted
    They balanced out fine. Never had an issue with them.
  13. Apr 24, 2017 at 8:29 PM
    tacos_modern_life
    tacos_modern_life Well-Known Member
    Brandon
    Portland, OR
    2015 Inferno TRD Pro
    TRD S/C, afe/TRD intake, TRD exhaust, Work Meisters, Retrax, Baja Designs Amber Fogs
    Someone help a desperate young fella locate a lower bumper valance. Broke 3 mount tabs like an idiot while tryintp install my light bar. Willing to fork out 1.5 handys :jerkoff:
  14. Apr 24, 2017 at 8:51 PM
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
  15. Apr 25, 2017 at 8:14 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Punch in what you have then what he has and you can see the difference
  16. Apr 25, 2017 at 9:37 AM
    JTB727
    Justin
    AZ
    I dont know the specs of my current wheels other than the fact that they are 15x8 I bought them from a buddy.... I can measure them. Im not too worried about them fitting. More so that they balance well.
  17. Apr 25, 2017 at 10:59 AM
    Tekniquetaco
    Tekniquetaco Well-Known Member
    Brandon
    Phoenix az
    2020 DCSB TRD off-road 4x4
    Still have these wheels that will be coming off my 17 tacoma. Only have 3000 miles on them so they are in great condition. $450 and you can have the lugs too. If you want to tires with the wheels I'll do everything for $800
  18. Apr 25, 2017 at 11:36 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Still avail or no?
  19. Apr 25, 2017 at 11:46 AM
    PangTRD
    PangTRD Well-Known Member
    Nick
    Phoenix, AZ
    2016 TRD O/R
    Anyone have one toyo at2 285/75/17 for sale in decent shape ?
  20. Apr 25, 2017 at 1:10 PM
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    Or you could just step up to a real wheel and tire combo.... they're even low profile...20170425_130234.jpg 20170425_130246.jpg 20170421_170107.jpg
