AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Jun 20, 2017 at 7:27 PM
    UncagedAlpaca5
    UncagedAlpaca5 Well-Known Member
    Anyone selling method wheels 17"? Or SCS SR8?
  2. Jun 20, 2017 at 7:37 PM
    mkrespke
    mkrespke Well-Known Member
    Phoenix, AZ
    07 4x4
    That is the fan clutch that is malfunctioning, not your ac. Replacing it isn't that difficult
  3. Jun 20, 2017 at 8:25 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Mm, not necessarily. Mines kinda the same way. Besides if it's the clutch fan, you're engine will probly be running hot as well no? Or can clutch fans work intermittently? Idk. But my clutch fan works fine. I did a proper drain/vacuum and refill after replacing some o rings, which helped quite a bit to how it was previously, but still gets only mildy cool idling. And only gets back to being cool on one speed lower than on high, and after driving at speed for quite some time. I suspect that it's a component that will need replacing. My knowledge of the components is limited though. But in either case, getting it checked out professionally is the first step. Thats what I would do before doing anything else. Certainly do NOT use the crappy refill cans from parts stores to try and "top it off", or anything of that nature. I need to take mine in somewhere too. Because I'm pretty sure it should be working better than it is.
    Another thing you CAN check or do, is to check the condenser for debri/dirt, and blow it out with compressed air. From the inside out, btw.
    Edit: I even installed a couple efans in front of the condenser to help with low speed/idling performance, but I don't think they are doing squat.
  4. Jun 20, 2017 at 9:08 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    Thanks for the advice,,,I have the same trouble as NightProwler. The clutch fan seems to engage and disengage properly. There are no weird noses coming from any area. I've also checked the condenser for any damage and is in great shape. About 2 or 3 yrs ago i had an AC hose replaced due to a leak, the system recharged but ever since ive felt the system hasn't been at 100%. Im just trying to find a reputable shop that is not the stealership. lol
  5. Jun 20, 2017 at 9:34 PM
    JTB727
    JTB727 Well-Known Member
    Justin
    AZ
    35's and a Good Time.
    Sounds like you are low on Freon. Grab a can at autozone and top it off and see if it makes a difference, if it does have somewhere put dye in it and check for leaks.
    Is this the fix for it no... But its cheaper than paying a shop trouble shooting labor.. Also if there is too much Freon it will make your system kick off due to over pressure. The cans at the auto parts store will be fine for a little testing.
  6. Jun 20, 2017 at 10:09 PM
    NightProwler
    Harlan
    Maricopa, Az
    I mean, you could try this with a can that has dye in it. Once. Just to see if there's a leak. But don't buy any that are strictly Freon. Especially the ones with claimed additives to "make it colder". That's what I was told anyways. Don't remember why tho. Been too long. Then if you have a leak you'll know with that singular can. If not then it's been topped off. But the proper way to do it after fixing the leak, is to have a set of proper gauges, do a full drain/vacuum with a pump, and test it for any additonal leaks. That way you don't waste any money on buying additional cans of Freon to refill and wait for it to leak out yet again if it does. Not sure if you can rent the pumps or not, but they're expensive to buy. Gauges are reasonable tho.
  7. Jun 20, 2017 at 10:21 PM
    Tsinajinii
    Tsinajinii Black Wood Streak People
    Jamin
    AZ
    2011 DCLB 4x4 TRD Sport
    OME 885's paired to Bilstien 5100's, LR UCA's, OME Dakars w/ 5160's, Debadged Tailgate, TRD Stickers Removed, ARE Topper, Tailgate Theft Deterrent Mod, Mobtown Tailgate Skin, Light Bar in Hood Skewp, VIAIR OBA, Diaz Fabrication - T.H.R.B., Always on Cig. Outlet, BAMF behind the grill light mount with KC HiLites Pro Halogens, KC HiLites Flex ditch lights
    My AC was doing the same thing to me last year. I did what @JTB727 suggests and picked up some R134a from O'Reilly and topped it off a few times, even over filling it by accident once (turned the can upside down, not suppose to do that), but there is a relief valve that kicked out the excessive pressure and I haven't had an issue since.
    When I got my stuff from O'Reilly, I was sure to NOT get the R134a that had leak stop additives, no need to have that shit gumming up my system. I just wanted to top it off and see if it went bad again. It didn't.
    I think the AC's poor performance came from when I may have bumped an AC line when I was changing my battery. Topping off the system was easy and relatively cheap.
    This is what you want, the legit stuff from DuPont along with the hose needed to fill your system:
    Refrigerant,R134a,12 Oz https://www.amazon.com/dp/B001CUNFGI/ref=cm_sw_r_cp_api_MbGszb6A9WADE
    FJC 6036 R134a U-Charge Hose with Gauge
    https://www.amazon.com/dp/B00620PXMW/ref=cm_sw_r_cp_api_NdGszbHS4G2XQ
  8. Jun 20, 2017 at 11:22 PM
    NightProwler
    Harlan
    Maricopa, Az
    This. And done. I'm sure there's lots of threads out there with additional info. Along with debates that have been drawn out about it. Ha. Back on topic.. Still on the lookout for potential goodies:D
  9. Jun 21, 2017 at 9:06 AM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    All this talk about AC's and I am just over here trying to get some interest on my sliders in 88 degree weather.
  10. Jun 21, 2017 at 9:33 AM
    Aw9d
    Aw9d That one guy
    This. When it comes to AC in a car/truck take it to a professional. There are too many ways to fuck up super easy fixes that will cost you more down the road.
    House AC on the other hand you can fix that shit yourself unless the compressor needs Freon or dies. Other than that it's just parts replacement and is super easy to do.
    phx13, Chipskip and RPS1030 like this.
  11. Jun 21, 2017 at 9:41 AM
    Brindybot
    Brindybot I don't see the problem.
    Jonathan
    Tucson az
    03 4runner
    A Snorkel
    Did you already sell the black headlights and grill?
  12. Jun 21, 2017 at 9:45 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    You'll get no sympathy from the valley dwellers.:p
    I'd be interested in the sliders but I don't have a DCLB or a lot of money to throw around right now.:boink:
    mh.meier[QUOTED] likes this.
  13. Jun 21, 2017 at 9:59 AM
    mh.meier
    The Doctor
    Commiefornia
    I dont need any haha. I used to live down south and when I was in afghan temps were between 130-140 so I have had my fun in the sun and will enjoy being able to leave my door and windows open all day haha. Yeah they are long but I am thinking of maybe letting them go for next to nothing if you cut them off yourself.
    Tsinajinii and christhebassman like this.
  14. Jun 21, 2017 at 10:22 AM
    Tsinajinii
    Jamin
    AZ
    PM'd
  15. Jun 21, 2017 at 10:40 AM
    UncagedAlpaca5
    IMG_1162.jpg Would anyone be interested in tires or wheels?
    SCS F5 16" 3.5 BS
    OR
    BFG KO2 LT265/70R16(less than 5000 miles)
    They should be available for pick up on Monday. Saturday/Sunday getting a new wheel/tire setup.
  16. Jun 21, 2017 at 10:42 AM
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    How much are you asking for the wheels ? 4 or 5 of them?
  17. Jun 21, 2017 at 10:45 AM
    azsean
    azsean Well-Known Member
    sean
    HELL ... aka mesa,arizona
    2013 black prerunner trd sport
    gosh.. where do I start, 18x9’s on 275-65 ridge grapplers. Bilsteins, clazzio leather, audio consists of stereo integrity,fosgate power amps,sundown audio, hybrid audio. Plus more...
    i bought my gf a new car and time to sell this one..... its not pretty, needs alot of work. but her dad used to bring it to garage all the time and have work done to it.
    1995 toyota camry. 6 cyl. 230k miles. no ac components. salvage title
    recent tires,brakes,rotors,battery,water pump
    body banged up,needs door handle fixed.
    it runs every day, its a perfect commuter or bank robbery car
    jk, dont rob banks with it, its not that fast...
    $1,000 on cl. 700 for tw
    Tsinajinii likes this.
  18. Jun 21, 2017 at 10:50 AM
    UncagedAlpaca5
    Idk yet. They are like 640+ shipping new. Maybe like 560? Plus no shipping since it's local pickup.
  19. Jun 21, 2017 at 3:26 PM
    Enjoihavok
    Enjoihavok Never Forget Z.S.
    Erik
    Chandler, AZ
    2021 Tundra Pro
    @Aw9d, this the droid you are looking for:
    swalters likes this.
  20. Jun 21, 2017 at 5:07 PM
    TACO 12B
    TACO 12B Team Hoyt
    Brody
    Flagstaff, AZ
    2017 DCLB TRD Offroad 4x4
    Selling one or the other?
    How much for the tires?
    Might be interested in the wheels... curious what they would look like on a DCLB 3rd Gen MGM... o_O
