AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Jul 18, 2017 at 12:34 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    I was talking about the Tucson Add with the icon 2.0 remote resi shocks, i'll buy the rears if someone buys the whole shebang from Clist add.
  2. Jul 18, 2017 at 12:34 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    Wait, which rears do you have..? o_O
  3. Jul 18, 2017 at 12:36 PM
    RPain
    Chandler, Arizona
    Oh dang didn't know you were thinking about selling yours already, thought it was someone elses. I'm not dead set on having the CDCV so unless it was a killer deal I'd probably pass..
  4. Jul 18, 2017 at 12:45 PM
    JerryTaco
    JerryTaco Well-Known Member
    The thought had crossed my mind
    T-rev[QUOTED] likes this.
  5. Jul 18, 2017 at 1:12 PM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Sierra Vista, AZ
    I am interested in the coils. What do you consider fair for the rears if I call this guy?
    Thanks,
    Techoma and wheeliest[QUOTED] like this.
  6. Jul 18, 2017 at 2:36 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Yeah... not enough meat in this game. I'm running Camburg Coil overs in front. It rides sooooo nice and took a lot of work, many iterations to get it where it is. For me to change, I need to do the whole thing. Rears are more important at this point.
  7. Jul 18, 2017 at 4:56 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    2 used Cooper Discoverer Atp tires.
    265/75/16
    60 bucks in Mesa
  8. Jul 18, 2017 at 7:02 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Considering he only has like 500 miles (maybe) on the new shocks anything below what he paid would already be a killer deal.
    I also threw the thought around of ditching my existing rears for the RXTs but I don't think I want to run their leaf pack and I think I have a way around it potentially worked up :spy:
    RPain[QUOTED] likes this.
  9. Jul 18, 2017 at 7:13 PM
    RPain
    Chandler, Arizona
    True..
    If all goes to plan I should be buying some used 2.5 coilovers no resi or CDCV from @Rashnu. So not sure I'd want the ability to only adjust the rear.. it would almost force me to upgrade to some resi/CDCV CO's... It's a trap!
  10. Jul 18, 2017 at 7:17 PM
    tubbsisland
    Cliff
    Arizona
    If you have a lot of variable weights it would be nice. Being able to adjust the compression speed between empty or loaded bed would be a huge upgrade, the additional fluid capacity would just be an added bonus.
  11. Jul 18, 2017 at 7:22 PM
    RPain
    Chandler, Arizona
    You talked me into it..
    @JerryTaco You know you won't find happiness till you get the RXTs... :boink:
  12. Jul 18, 2017 at 7:25 PM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Dammit, I had myself talked out of compression adjustable Kings :)
    Enjoihavok and RPain like this.
  13. Jul 18, 2017 at 7:32 PM
    tubbsisland
    Cliff
    Arizona
    I've always said that if your going to spend the money for 2.5s with Resi's it's foolish to not go ahead and make them adjustable for a couple hundred bucks more. Just being able to dial in the ride specific to YOUR preferences without having to open the shock up is a huge plus. I like my truck to run on the firmer side so I run my CDC at a 7/10 in front and my rear bypasses about 3/4 of the way closed on the compression and right in the middle on my rebound speed.
    Mike330R[QUOTED] likes this.
  14. Jul 18, 2017 at 7:39 PM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    But then by the time you pay for adjusters you may as well spend a couple hundred more bucks and get bypasses....
    Never ending fuckery with this habit I tell ya
  15. Jul 18, 2017 at 7:41 PM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    At what point does LT come into the picture?
  16. Jul 18, 2017 at 7:43 PM
    RPain
    Chandler, Arizona
    Get those COs taken off before these guys give me more bad ideas :devil:
    Rashnu[QUOTED] likes this.
  17. Jul 18, 2017 at 7:48 PM
    tubbsisland
    Cliff
    Arizona
    I wouldn't do bypasses again. Right in the middle on the rebound is just standard valving on the shim stack, same as a CDC. There just isn't the need for that much adjustment on a sprung over 10" travel rear suspension.
    I at least have enough expirence from tuning the old truck myself to know what needs to be adjusted and how it should handle. I can't imagine someone green trying to play with them, it's a PITA and you can do more harm than good by making bad adjustments
    RPS1030 and MaverickTRD like this.
  18. Jul 18, 2017 at 7:56 PM
    tubbsisland
    Cliff
    Arizona
    Exactly, basically a dropped lower eyelet allowing for a little more droop. They tested the crap out of this kit, I have spy shots of it that I couldn't show anyone from October of last year when I stopped by their shop on the way home from the off-road expo and at that time it had already been installed on their truck for months. It's a solid kit for sure. What I don't like is that under load their springs drop to like 1.1" of lift in The heaviest setting. My deavers hold close to 2" with 500ish lbs in the bed.
    RPain likes this.
  19. Jul 18, 2017 at 8:13 PM
    JerryTaco
    Basically what Cliff said. After having 2.5 non cdcv shocks and now the 2.5 cdcv to match my front, the truck drives amazingly well. The ability to quickly change it on the fly when the tent goes on will be great as well. So I really couldn't be happier. Where I struggle is that the truck is pretty perfect as it stands. Those deaver u402s paired with the new shocks ate pretty unbeatable and I am leery of the new icon leads, primarily because the Deavers are so good and handle weight so well. IF I did do the rxt rear setup, I'd just go with the rxt cdcv shocks and forego the bypasses, primarily because I really don't need them for my application. It's all really an "if" at this point as I have other build priorities and the suspension is pretty perfect as it stands now.
  20. Jul 18, 2017 at 8:23 PM
    RPain
    Chandler, Arizona
    It sounds like the deavers still out perform the new icon packs anyway.. If it ain't broke, no need to fix it. You've got a killer setup as it is. If I were to find a sweet deal on front CO's with cdcv I'd probably go that route front and rear. This is what I get for trying to move to a top tier suspension on a budget, I know what I'm in for. :D
    MaverickTRD likes this.
