AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Jun 2, 2019 at 9:17 AM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Will you also want to swap for stock? Or are you upgrading from the 5100?
  2. Jun 2, 2019 at 9:27 AM
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    What would be the lowest I could set it at? I have concerns about too much lift since my work takes me into a lot of low clearance areas. I've also got to shed about 40lbs because getting in and out of my Taco is a chore as it is. Motivation to exercise!
    TacoBuffet[QUOTED] likes this.
  3. Jun 2, 2019 at 9:29 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    The coils provide the lift, I'm guessing he has them set on the lowest setting which should but you right at 3'' and contrary to the sheep herd here on TW you can run stock UCAs with 3'', it will be barely in spec but I and many others have done it on trucks (my 15 and now my 19), then save up when you're ready to put on aftermarket UCAs.
    Snaeper[QUOTED] likes this.
  4. Jun 2, 2019 at 9:39 AM
    Snaeper
    Martin
    Phoenix, AZ
    The more I mull on it the more I think I'm gonna hold off. Tires will likely be this week as well as flaps. Then tint likely next after I get my shell on. Sliders and Dashcam somewhere in there. Anyways!
    Appreciate the info and help man :fistbump:
  5. Jun 2, 2019 at 9:41 AM
    TacoBuffet
    AL
    Sure man, I would get tint first and mull some more, would suck to drop the money on 265's or tires that work with stock suspension only to turn around and go 285's with a lift. Enjoy the process!
  6. Jun 2, 2019 at 9:50 AM
    Snaeper
    Martin
    Phoenix, AZ
    Well tint will come after the shell which I probably wont have for another two weeks. I got a friend ready to buy my tires now and I'm not wanting to go 285's because I know what little acceleration my truck can muster will disappear in a cloud of dust.
    I've settled on SL Nitto Ridge Grapplers and anything bigger than 31's become a D or E load and weigh 55+ pounds.
    I dont wanna put fat tires and crazy suspension on a truck I just financed and then roll it when my inexperience bites me in the ass. Gonna stick to fire roads and simple/easy trails for now and focus more on making sure it still functions as a work truck. Edit: For that reason and purpose, I figured some OR Take Offs would be fine for the time being.
    I dont wanna lift a 70lb tool box any higher than I have to as well.
    Mike330R likes this.
  7. Jun 2, 2019 at 9:58 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    You probably said it somewhere but I didn’t see it, what yr/model Taco are you working on?
  8. Jun 2, 2019 at 10:01 AM
    Snaeper
    Martin
    Phoenix, AZ
    2019 SR Access Cab with I4 and 4x4
  9. Jun 2, 2019 at 10:10 AM
    GLOOMY
    GLOOMY Well-Known Member
    2015 Pyrite Mica Tacoma SR5 4x4
    Stock
    I’m interested in the aal?
  10. Jun 2, 2019 at 10:24 AM
    TacoBuffet
    AL
    Incorrect. I have Nitto Ridge Grapplers 285/70r17, SL 116Q on my 19 right now.
    But yes with a 4 banger I'd be apprehensive with anything bigger than 31s.
  11. Jun 2, 2019 at 10:30 AM
    Snaeper
    Martin
    Phoenix, AZ
    Allow me to specify: 31's are the largest size standard load for 16's.
  12. Jun 2, 2019 at 10:33 AM
    65skyturbo
    65skyturbo Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
    I haven't looked into it much but I think the 885 coils on the lowest notch would give about 2" on a 4cyl 3rd gen.
  13. Jun 2, 2019 at 10:37 AM
    TacoBuffet
    AL
    Ahhh, gotcha, sticking to a 16'' wheel.
  14. Jun 2, 2019 at 10:39 AM
    65skyturbo
    Mesa, AZ
    I'm going to try to sell it as the complete kit before I split it up. Ideally someone will buy the whole thing in one easy transaction.
    Snaeper likes this.
  15. Jun 2, 2019 at 10:53 AM
    IzzyTacoG3
    IzzyTacoG3 Member
    2018 Tacoma TRD offroad Cement
    3”lift with 33s cooper ATT
    NFAB low profile slider for Tacoma 2016-2019
    $350 OBO
    Negotiable, no lo blow
  16. Jun 2, 2019 at 11:04 AM
    GLOOMY
    Stock
    True. Well if anyone comes around for just the shocks let me know about the Aal. Thank you for you time.
  17. Jun 2, 2019 at 11:11 AM
    Two Tons
    Two Tons What Would Stun Gun Do?
    Tim
    Valley of the Sun, AZ
    2016 Off Road 4x4 access cab FTW
    Snaeper likes this.
  18. Jun 2, 2019 at 11:13 AM
    Two Tons
    Tim
    Whoa, how did I just quote-ception your quote?
    Rhino8541 likes this.
  19. Jun 2, 2019 at 12:50 PM
    Two Tons
    Tim
    https://phoenix.craigslist.org/nph/pts/d/phoenix-toyota-tacoma-bilsteins-fit/6897172283.html
  20. Jun 2, 2019 at 4:29 PM
    Snaeper
    Martin
    Phoenix, AZ
