AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Apr 30, 2020 at 8:04 AM
    AZoverlandTaco
    AZoverlandTaco How do I change my profile name?
    Eric
    Flagstaff
    Toyota 4 Life
    Haha well I tossed that a while ago. My wife can only tolerate so many car parts laying around.
  2. Apr 30, 2020 at 8:12 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Darn. I just need you to borrow a new 4Runner with a locker from the dealer for a log lunch break, swing by my place for an hour or two while we swap rear axles with my wife’s. Take a TRD Pro, people that buy those will probably never try to put the locker in anyways.
    Techoma, llibrm, wilcam47 and 2 others like this.
  3. Apr 30, 2020 at 9:53 AM
    AZoverlandTaco
    Eric
    Flagstaff
    Toyota 4 Life
    Take a long lunch break lmao! Wish I had that much freedom haha
  4. Apr 30, 2020 at 9:54 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Can I take a long test drive lol?
  5. Apr 30, 2020 at 10:42 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    wilcam47 likes this.
  6. Apr 30, 2020 at 11:02 AM
    AZoverlandTaco
    Eric
    Flagstaff
    Toyota 4 Life
    :thumbsup::rofl: Sure, haha :burnrubber:
  7. Apr 30, 2020 at 12:21 PM
    ArizonaNativ
    ArizonaNativ Well-Known Member
    Tucson
    Still available?
  8. Apr 30, 2020 at 2:19 PM
    barretta
    barretta -
    San Clemente, CA
    '18 White TRD OR 4x4
    PM sent
  9. Apr 30, 2020 at 4:00 PM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Anyone have any fishing kayaks they want to get rid of??
  10. Apr 30, 2020 at 4:26 PM
    Vitalzone
    Vitalzone Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    If anyone is interested I have a full 4.30 gear set (front and rear) out of my 16 OR. 12k miles on them. I need to dig them out of my garage to take pics, so hopefully I dont get a pee pee slap for posting this up without.
    $200
  11. Apr 30, 2020 at 5:33 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Free stuff
    Located in chandler
    BED BOX IS GONE
    unlewser, Jeff Dartfrog and wilcam47 like this.
  12. May 1, 2020 at 1:44 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    SOLD for over asking price
    freddy2923, llibrm, LTacoman and 2 others like this.
  13. May 1, 2020 at 1:56 PM
    G's 05taco
    G's 05taco Well-Known Member
    Gunner
    Gilbert, AZ
    2017 Tacoma Limited
    Icon Stage 9 Suspension System with upgraded finned reservoirs and Icon S2 secondary bypass system stage 3, Camburg's Lower Control Arms, Camburg's Performance Spindles, Baja Designs 30" S8 LED Light Bar, Baja Designs 30" OnX6 LED Light Bar, Baja Designs SAE Fog Light Kit, SDHQ Built Behind the Grille Mount, SDHQ Built ABS Guards, SDHQ Built Swith Pros Keypad Mounting Panel and Power Module Mount, SDHQ Built Universal 3-Way Tie Down Strap and Bracket, SDHQ Built Power Steering Reservoir Kit, SDHQ Built Rock Sliders, RCI Off Road's Front Skid Plate, aFe Momentum Intake, Total Chaos Fabrications Bed Stiffeners, Icon Alloy's Six Speed Wheels, and Toyo M/T Tires.
    I am looking for a third gen OEM tonneau cover. I already have the bed rails so thats not a necessity if you just have the cover! Not looking to spend a lot of money as I have heard the quality is poor just want to be able to lock stuff underneath!
  14. May 1, 2020 at 2:19 PM
    RickTRD
    RickTRD Active Member
    Richard
    El Mirage, AZ
    2017 Super White Tacoma TRD OR
    New running boards and plasti dipped grill
    You said something to me before I was banned for no reason, what were you saying?
  15. May 1, 2020 at 2:37 PM
    DR TACO
    DR TACO Well-Known Member
    Denny
    Fort Mohave
    2019 Tacoma Off Road 4x4 Double Cab
    Pro grille, POD lights, SEMA wheels.
    Huh?
  16. May 1, 2020 at 2:41 PM
    RickTRD
    Richard
    El Mirage, AZ
    Idk it just showed I had a message from you before I was banned idk why but it doesn't show it anymore
  17. May 1, 2020 at 2:49 PM
    DR TACO
    Denny
    Fort Mohave
    The last thing I posted in this thread was me putting my wheels and tires for sale. Not sure what happened to you. You should ask the mods. Sorry, wish I could help you.
  18. May 1, 2020 at 2:52 PM
    RickTRD
    Richard
    El Mirage, AZ
    I have, thanks though I was just wondering
  19. May 1, 2020 at 2:56 PM
    DR TACO
    Denny
    Fort Mohave
    What did they say? Did you try to buy/trade/sell something? The rules state you have to have 50 posts before you are able to do that.
    Sent you a pm.
  20. May 1, 2020 at 4:07 PM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Free tools for the taking...
    Currently located in SoCal.
    The cases are broke and there are way too many pieces that are missing to mention. And don't get me started on why pieces are missing...
    I'm not mailing squat, but I'll be in the PHX/Mesa/AJ area in a couple of weeks ( not exactly sure when ), so I can drop them off if you want them. You can take just one set or both. I'd rather they get used vs. tossed out because nobody is taking donations in SD County right now. I might be able to unload them at Goodwill in Mesa when I'm out there.
    Azdvo, asuchemist, wilcam47 and 2 others like this.
