AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Feb 7, 2024 at 6:51 PM
    Yacob_D
    Yacob_D It's Fine, Leave It.
    Jacob
    The J
    08 Red, AC
    Couple nuts and bolts 4x converted
    Again.. Im not an electrician :anonymous: but It is most definitely 3 phase. It wouldn't run with out it. The receptacle was installed by an certified electrician, Red, Black, White, Green. The 85amp plasma and The 3 phase SuperShear Decanner I make all run off the same plug. 3 phase 5 horse power motor also wouldn't run off single phase.. Unless it was a 1 phase motor which we also run but only on the single phase outlet (3 wires black, white, green, 220V)
    the plug pictured I believe can be wired without the fourth wire installed, therefore leaving the stud out, all depends on the outlet on the wall and current provided.
    Just my 2 cents and not trying to argue :thumbsup:
  2. Feb 7, 2024 at 7:58 PM
    Nukeproof
    Nukeproof Well-Known Member
    Strawberry Az
    i dunno man, not arguing here either. i was tought that 3 phase receptacles will have one spade at 90* to the other 2, so maybe the sparky just used a single phase plug? or maybe it doesnt matter, just the way i was taught.
    as far as 3 vs 4 wires, yeah, 3 wire is called Delta if i remember correctly and i have never worked with that, my somewhat limited 3 phase exp has always been 4 wire, called Wye.
  3. Feb 8, 2024 at 7:27 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    Looking into this so I dont get egg on my face for the wrong info.. Yes this machine can be ran Single Phase, but requires an 80amp breaker. We have it wired 3 phase on a 60amp breaker. It can Also be wired 440 on a 25amp breaker. So Technically we are both Correct, but why run it on a 80amp single phase if you have 3 phase available. Plugs and receptacles come in many different applications. This is the one we chose as it matches the other 3 Phase machines we run. I could cut it off and let the next guy wire whatever plug he wants to, but he will have out figure out his own wiring configuration.
    Nukeproof[QUOTED] likes this.
  4. Feb 8, 2024 at 7:39 AM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Messaged ya on Signal.
    Phessor[QUOTED] likes this.
  5. Feb 8, 2024 at 10:45 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I could become adept at this, but the most I recall clearly about 3-phase from college electical circuits is a joke (or anecdote) about a guy emerging from an exploded shed saying "I guess A and B were really swapped on the 3-phase.".
  6. Feb 9, 2024 at 5:34 AM
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    @llibrm oh wise Electrical Sage, I summon thee! :boink:
    Do you mind passing down some wisdom on single phase/three-phase plugs
    KingOfTheNorth likes this.
  7. Feb 9, 2024 at 7:21 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    EatSleepTacos and prise like this.
  8. Feb 9, 2024 at 11:08 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Late response due to IT issues:
    In short, a 3-phase machine will not work on a single-phase panel without a lot of money. It requires a phase converter. All residential panels are single-phase. Power companies really don't like bringing in a 3-phase drop to neighborhoods in my experience. That too is expensive. Not all commercial buildings run 3-phase either. I'd say that most older commercial areas are still wired single-phase.
    In short, unless you know for certain you have 3-phase power, don't bother. It will be marked as 3p-4w and 208VAC, not 220VAC or 240VAC. There is a lot of small nuance within 3-phase that doesn't really need to be brought up here, and most small machines don't require it and everything involved is more expensive.
    :cheers:
  9. Feb 9, 2024 at 11:20 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    Thanks for the input @llibrm !:hattip:
    llibrm likes this.
  10. Feb 9, 2024 at 11:31 AM
    Queso_Blanco
    Queso_Blanco Formerly known as "Bad_Guac"
    Tyler
    Mesa, AZ
    '23 Super White DCSB TRD OR 4X4
    Accutune stage 4 Adjustable King 2.5's w/resi's All the meso Diamondback HD Method 701's 17x8.5" 285/70R17 Diode dynamics fog/ditch/stealth lightbar Sliders RCI skids OTT tune Total Chaos bed gussets Etc...
    *Reporting from the utility side of things*
    3 phase boils down to how much a customer wants to invest in the project. If there's 3 phase primary (actual high voltage 3,000-12,000ish volts) running by your shop then it'll be the cost of adding a new transformer bank (3 transformers in a cluster on the same pole) or a new kiosk (big brown/tan or green box for underground applications). The cost for new service wire to the building, a new meter base, and the labor for the utility to do all the work on their end. In other words unaccessible for the common home gamer shop/pole barn.
    There are scenarios where the infrastructure is already present within a few poles (your neighbor has an existing 3 phase) and all it would take is running a couple hundred feet of service wire.
    If you don't have 3 phase primary in the area, good luck. Whole other barrel of monkeys. That's where a phase converter comes into play which in my experience is only good for a small 3 phase motor (residential elevator, 3 phase compressor, etc).
    llibrm and Yacob_D like this.
  11. Feb 9, 2024 at 11:37 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    See this is why I like you. You supply it, and I'll connect the finer details. :fistbump:
    Queso_Blanco[QUOTED] and Yacob_D like this.
  12. Feb 9, 2024 at 11:51 AM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
  13. Feb 9, 2024 at 12:32 PM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    :rofl::poking:
    TACOTU3[QUOTED] likes this.
  14. Feb 9, 2024 at 2:10 PM
    Queso_Blanco
    Tyler
    Mesa, AZ
    :cheers:team work makes the dream work:cheers:
  15. Feb 9, 2024 at 5:15 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Wild fact. Up on the Rez at Keyenta and all that area. Single phase. With my old company and we upgraded that Chevron at the Goulding Lodge and area. It was a PITA to get them to install the right equipment to have at two phases to make stuff work. The owner of the site wanted it done. But had to go through the tribe.
    Queso_Blanco and Rezkid like this.
  16. Feb 9, 2024 at 7:52 PM
    AZoverlandTaco
    AZoverlandTaco How do I change my profile name?
    Eric
    Flagstaff
    Toyota 4 Life
    I have to make a quick visit to Phoenix on Sunday. I am willing to bring these to Phoenix and meet up.
    TACOTU3 likes this.
  17. Feb 10, 2024 at 11:52 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Cleaning some stuff out of the garage.
    All following were off my 2020
    Rear bumper caps Cement Color with the inner plastic frame, backup sensors, blind spot sensors, and bumper wire harness.
    $250 for all
    x2 only one shown
    x2 only one shown
    Tronfunkblow and Yacob_D like this.
  18. Feb 10, 2024 at 12:10 PM
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    ooowww, where are you? I am in the east valley. How do I get a hold of you? That is just what I need as long as it all works, I don't care about the paint.
    Are those Ray10's on your truck?
  19. Feb 10, 2024 at 12:12 PM
    Supr4Lo
    Surprise, AZ
    Yes all works. I was using them up to 4 weeks ago. I'm in Surprise. I'll PM you my number.
    Yes, Ray10s
  20. Feb 10, 2024 at 3:36 PM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    Wish i had more room for the top boxes at the house, Thats a good deal to hide all the tools I have!
    Supr4Lo[QUOTED] likes this.
