AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Dec 11, 2013 at 3:11 PM
    #6921
    Robby655
    Robby655 Well-Known Member
    Robby
    Alaskuhhh
    White TuRD
    Peep the build
    sounds dangerous haha... i prefer just slamming my bedsides into walls apparently :pout:
  2. Dec 11, 2013 at 4:49 PM
    #6922
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    Any one have a TSB leaf pack they don't want anymore?
  3. Dec 11, 2013 at 4:55 PM
    #6923
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    No, but I have some Dakar leafs I took off and replaced with All Pro Expo's :D
  4. Dec 11, 2013 at 4:56 PM
    #6924
    TacoBurrito07
    Jake
    Arizona
    And what would that run me?:D
  5. Dec 11, 2013 at 5:05 PM
    #6925
    Infra
    Az
    Too late....Germ has already spoken for them
  6. Dec 11, 2013 at 5:07 PM
    #6926
    TacoBurrito07
    Jake
    Arizona
  7. Dec 12, 2013 at 8:10 AM
    #6927
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    And Jason didnt even have me over to put them on. Could have halfed the install time and doubled the drinking time.
  8. Dec 12, 2013 at 8:20 AM
    #6928
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    No. You are correct in naming the artist, but the correct response to Jon's post would have been the next line in the song.
  9. Dec 12, 2013 at 8:59 AM
    #6929
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    lemme check if i have mine still
  10. Dec 12, 2013 at 9:03 AM
    #6930
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    I got a 5lug set if you dont have yours stefen
  11. Dec 12, 2013 at 1:00 PM
    #6931
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    i do still have them with the toytec 1.5 AAL :cool: $100 and theyre sold
  12. Dec 12, 2013 at 1:01 PM
    #6932
    TacoBurrito07
    Jake
    Arizona
    Alright. Sounds good.
  13. Dec 12, 2013 at 1:02 PM
    #6933
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Im only asking 50 for mine:eek:
  14. Dec 12, 2013 at 1:03 PM
    #6934
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    mine include a ride to phx tho lol
  15. Dec 12, 2013 at 1:05 PM
    #6935
    TacoBurrito07
    Jake
    Arizona
    Sweeeeet! I will probably take them. Let me check on a few things first! Thanks
  16. Dec 12, 2013 at 1:06 PM
    #6936
    TacoBurrito07
    Jake
    Arizona
    Wait a second.. they're tsb leaves? Didn't know that applied to 5 luggers...
    (and that was not a 5 lug joke. That was complete seriousness..)
  17. Dec 12, 2013 at 1:10 PM
    #6937
    05TacoRunner
    Peoria, Az
    No they are not. You are correct that they didn't apply to 5 lug trucks. However 5 lug trucks are spring under from the factory so when installed on a six lug spring over truck you gain a little lift.
  18. Dec 12, 2013 at 1:35 PM
    #6938
    Phil Dammit
    Your Mom
    Tempe, Arizona
    It didn;)
    Exactly, similar in that this pack has a larger arch thus the higher ride height and stiffer ride. Should yield you 1.5" lift with no AAl, 3.0" with AAL
    Mines already in phx:p
  19. Dec 12, 2013 at 1:38 PM
    #6939
    TacoBurrito07
    Jake
    Arizona
    I need an adult... what is the better option here...
  20. Dec 12, 2013 at 2:00 PM
    #6940
    Phil Dammit
    Your Mom
    Tempe, Arizona
    LOL, Minus Jason I am the only other adult posting right now
