AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Jan 1, 2014 at 5:40 PM
    #7221
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Eh go for it. Lol.
  2. Jan 1, 2014 at 5:41 PM
    #7222
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    I've done it once to my buddys 1st gen not to hard
  3. Jan 1, 2014 at 5:47 PM
    #7223
    JuansTaco
    Juan
    gilbert az
    Hmm. I would think it would jist be easier to go do a bedcage woth shocks than that
  4. Jan 1, 2014 at 5:49 PM
    #7224
    Milota95
    Qrampage
    B.F.E
    Driven Safely
    :spy:
  5. Jan 1, 2014 at 6:43 PM
    #7225
    Hound83
    Hound83 Well-Known Member
    Phoenix
    11 TRD off road 4X4
    Icon coilover w/ King 700lb spring, ARB front bumper, Warn M8000, AllPro rear bumper w/ tire carrier, OME rear nitrochargers, Dakar leaf pack with overload, Wheeler€™s front and rear SuperBump, Icon tubular UCA, Icon lower control arm skid plate, Armor Tech Offroad front skid, Relentless mid skid, CBI rock sliders, diff drop, BAMF behind the grill light bar, Rigid Dually & D2 LED lights, HomerTaco Satoshi grill, ATO bed cross bars, ARB air compressor, ARB roof top tent, ARB awning = 6300lbs gvw
    I would think that you would need a 2" extension then with a 2" taller bump stop. Honestly I'm not sure I'd recommend this. The only reason these are not on my truck now is because I have the Dakar leafs. Icon and DSM says you need the extended shocks for the bigger leafs, but I didn't feel like dishing out another $500+ for the same shock that is 2" longer.
    Sounds good, I'll let you know if anything changes
  6. Jan 1, 2014 at 7:05 PM
    #7226
    tacosunday
    tacosunday GoldMember
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    I have this exact setup. Except I wanted to see exactly how short they were with dakars. So, I unbolted both shocks from the bottom mount and jacked the truck up so the rear was fully extended. Whoever said they are too short was right except not by two inches but more like 7/16in. I always thought the dakars rode just a little stiff so I removed the top overload, which is about 1/2in thick. Worked out perfect. And I beat the shit out of my truck, nevrr had a problem.
  7. Jan 1, 2014 at 7:15 PM
    #7227
    Hound83
    Phoenix
    11 TRD off road 4X4
    I guess 2" is just the next size they can do, DSM had them in stock ready to ship when I inquired. I have the OME nitros (same length as the Icons) on mine now and they are 1" to short but I also have the D29XL extra leaf installed. As far as I know the OME are the only ones that you can run short without damaging them because they are designed to work with the Dakar leafs acting as a limiting strap.
  8. Jan 2, 2014 at 7:39 AM
    #7228
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Which means all he would need is limiting straps, or not jump his truck....
    Shorter bumps allow for more up travel, however if the shock shaft and body are not short enough, depending on where top mount is you will bottom the shock out before you hit your bump.
    Dont worry, he will flake out.
    this comment makes me LOL:rolleyes:
    Only need one welder, a break, and a plamsa/torch to make this happen Q;)
    with*
    This is why we don't let you fab on your own. Leave the thinking to the professionals:cool:
    IF the body of the emulsion is coherrent with the location of the mount and full bump then he need not worry about his bump, it is his extension that he wants to worry about as the all pros will droop more than the shaft and body of the emulsion allow.
  9. Jan 2, 2014 at 11:49 AM
    #7229
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    OEM Intake: $40
    Kicker Comp S in sealed box: $40
  10. Jan 2, 2014 at 11:51 AM
    #7230
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Wasn it 35 last week?
    EDIT: Nevermind, it was 45.
  11. Jan 2, 2014 at 8:17 PM
    #7231
    SixD7
    SixD7 Active Member
    Hello fellow Arizonans. New to the site and looking for a few things. Anyone have roof molding for DC they want to part with. Also looking for front carpeted mats for 2012+
    Thanks
  12. Jan 2, 2014 at 8:38 PM
    #7232
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    What color mats are you looking for?
  13. Jan 2, 2014 at 8:42 PM
    #7233
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    I will have a extra full set on Monday.
  14. Jan 2, 2014 at 8:44 PM
    #7234
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    ^ say what?
  15. Jan 2, 2014 at 8:45 PM
    #7235
    snowtank
    Andrew
    Arizona
  16. Jan 2, 2014 at 8:46 PM
    #7236
    JerryTaco
    JerryTaco Well-Known Member
    I've got a set out of my 2012 DC that are just collecting dust
  17. Jan 2, 2014 at 8:51 PM
    #7237
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    Congrats
  18. Jan 2, 2014 at 8:55 PM
    #7238
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    What part of AZ you in? I have my roof mouldings
  19. Jan 2, 2014 at 8:56 PM
    #7239
    snowtank
    Andrew
    Arizona
    Thanks. But thatd not all :spy: more happening. Top secret stuff I can't release details on forum wife is apart of. :spy:
  20. Jan 2, 2014 at 8:58 PM
    #7240
    Brian007Taco
    I will keep it on the DL then.
