AZ Classifieds
Discussion in 'Arizona' started by blatant, Jul 28, 2011.
  1. Aug 5, 2016 at 4:33 PM
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Todays haul!!!
    All Pelican Brand... Most of these were found for specific TW members but I'll be following up this post with a set that I grabbed to sell just because they were so well suited for Tacoma needs. Stay tuned...
  2. Aug 5, 2016 at 4:41 PM
    CodyTaco
    CodyTaco Well-Known Member
    Cody
    2013 dcsb sport spruce
    This has my interest. Pricing?
    a.smo likes this.
  3. Aug 5, 2016 at 4:42 PM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Hmm... these look interesting. I have kind of rear your posts about these before. Can you pm me prices to expect?
  4. Aug 5, 2016 at 4:45 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    nice score man!! I need to get sizes from you and cross reference what will fit with my setup.
  5. Aug 5, 2016 at 5:03 PM
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    As I have said before here is the scoop... THIS GOES FOR EVERYONE!
    I have been reaching out TW members to see if anyone would be interested in me "shopping" for them. I've asked for TW members to send me their desired specs (preferred brands if any, color, size restrictions, dimensions, wheels or no wheels, foam no foam, and anything else, etc). Once I have enough people who are interested... And have established what you are looking for. I will check out my local resources (technology companies, surplus, retail) and see if I can find anything that suites each persons needs.
    I've found the following brands:
    -Pelican (1660s and 1650s are popular and easy for me to find)
    -Pelican-Hardigg
    -Hardigg (Which are what my personal ones are)
    -ECS (harder to find practical sizes)
    -SKB (Usually rather expensive, but usually practically new!)
    Color wise, most of the cases I find are black or dark army green. Occasionally I'll find grey ones, and rarely do I find tan ones (plus I've been keeping them for myself haha).
    I've seen all sorts of sizes/dimensions, so if you want something specific in that regard let me know, but giving me a range is really helpful!
    As for pricing... One of the reasons I'm making the list of interested buyers is that often times I can get a good discount on the cases if I buy them in bulk. Usually however, the prices can range from $60-$140 each depending on the case (mainly size dependent). They are also all USED cases but finding functional ones in good condition isn't a problem. Almost all of which are weatherproof and some still have their pressure release valves in working order (which is nice if you are changing elevations often).
    Once we have established your desired spec, I'll ask for your contact info for when I go shopping! So start PMing me...
    PS: In the meantime... I have a couple up for sale NOW!!! I'll be posting them momentarily.
    snowtank and stumbles like this.
  6. Aug 5, 2016 at 5:11 PM
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    FOR SALE: PELICAN STORM 2975 CASES!!!
    I grabbed these while I was shopping for some other TW members today because they were too good to pass up… They are a set of Pelican Brand Storm IM2975 Trak Cases w/ Foam Inserts Here is the a description:
    The Pelican iM2975 Storm Trak Case is an injection-molded case made of HPX high performance resin, that is virtually unbreakable, dent-resistant and shatter-resistant. It is tough, rugged, lightweight, airtight and watertight. There is a permanently attached Vortex valve that automatically adjusts air pressure without letting in water, and won't unscrew from the case. Press & Pull latches open with the push of a button, yet stay closed securely under impact or stress. The case has unbreakable molded-in hasps that allow the addition of standard size padlocks. It has hinges with integrated feet that hold fast under impact, and create a flat surface for upright stability. It is carried by three double-layered, soft-grip, solid-core handles, lightweight retractable, telescoping handle and rugged in-line wheels.
    Exterior Dimensions: 31.3 x 20.4 x 15.5" (79.5 x 51.82 x 39.37cm)(LxWxH)
    Interior Dimensions: 29 x 18 x 13.8" (73.66 x 45.72 x 35.05cm)(LxWxH)
    -This case has a multilayer cubed foam bottom and a convoluted foam pad in the lid.
    -Injection-molded case made of HPX high performance resin is virtually unbreakable, dent-resistant and shatter-resistant
    -Tough, rugged and lightweight
    -Airtight and watertight
    -Multilayer cubed foam bottom and a convoluted foam pad in the lid
    -Permanently attached Vortex valve automatically adjusts air pressure without letting in water, and won't unscrew from the case
    -Press & Pull latches open with the push of a button, yet stay closed securely under impact or stress
    -Two unbreakable molded-in hasps allow the addition of standard size padlocks, offering another measure of security
    -Hinges with integrated feet hold fast under impact and create a flat surface for upright stability
    -Molded-in stacking ribs provide no-slip stability for multiple case-stacking during storage or transport
    Carrying options:
    -Three double-layered, soft-grip, solid-core carrying handles provides strong, durable comfort
    -Lightweight, retractable, telescoping handle locks in place
    -Rugged in-line wheels have shielded ball bearings, and are composed of a nylon core encased in a polyurethane tread. The wheels are mounted on a solid axle for improved stability and ease of transport.
    In short… These things may be used, but they are indestructible and everything from the clips to the hinges to the weather-stripping is great for condition. They fit nicely side by side between the wheel wells of a 2nd Gen. and they also have wheels for convenience. Perfect for your camping and/or recovery gear or tools. Keep the foam or remove like I did! I’ve done a quick rinse on these but if you want to remove the paint and/or shipping label adhesives I find that solvent and a scrubby usually does the trick!
    These retail for over $250 new! I’m asking $120 individually or $220 for the set!
    So start sending those PMs… Looking forward to meeting more of you guys! I'm located in Old Town Scottsdale!
    snowtank likes this.
  7. Aug 5, 2016 at 5:23 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
  8. Aug 5, 2016 at 6:53 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Thanks again for the cases! Wife already loves them! And as for the rest of you guys. Pick some of these up!
    a.smo likes this.
  9. Aug 5, 2016 at 6:55 PM
    snowtank
    Andrew
    Arizona
    Who has a set of stock 2nd gen leafs? Newer the better
  10. Aug 5, 2016 at 7:10 PM
    Aloha Scout
    Aloha Scout Drink beer and smoke your meats
    I have a pelican 1690 case if someone wants to make a deal. No foam inserts. Locks And tabs work great. Has yellow spray paint on it from a drunk idiot.
  11. Aug 5, 2016 at 7:33 PM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
  12. Aug 5, 2016 at 7:34 PM
    phx13
    Rob
    2015 DCSB TRD O/R
    I'll have some end of months have. Waiting until my Ray10s come in before I have this lift put on.
    35kish miles
    snowtank[QUOTED] likes this.
  13. Aug 5, 2016 at 7:37 PM
    snowtank
    Andrew
    Arizona
    Cool. Dibs . Let me know when they are available
    phx13[QUOTED] likes this.
  14. Aug 5, 2016 at 7:38 PM
    Aloha Scout
    $150?
  15. Aug 5, 2016 at 7:40 PM
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    I still have mine.
  16. Aug 5, 2016 at 7:44 PM
    snowtank
    Andrew
    Arizona
    I feel like a 18 year old white girl at a party In the hood. Stuff flying all at me now
  17. Aug 5, 2016 at 8:16 PM
    BDMcGuire
    BDMcGuire Well-Known Member
    Brent
    Peoria, AZ
    06 Tacoma OR SBDC
    I'll also have a set once I install my new ones. Waiting on last few parts to come in. I.e. brake lines and Ubolt flip
  18. Aug 5, 2016 at 8:20 PM
    snowtank
    Andrew
    Arizona
    Sweet. I got it worked out with blake right now tho.
    2ndGenJonny likes this.
  19. Aug 6, 2016 at 12:26 AM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Anybody have a G19 gen4 or know somebody with a G19 gen 4 that would be interested in trading for a G26 gen4? Has night sites, an extended slide release, 3 magazines (one with mag extension), american flag backplate (I'd like to keep this), ZORN (local company) IWB holster and a serpa level 3 holster. G26 has fewer than 1k Rounds through it and minimal holster wear. I would sell for the right price but would prefer to trade.
  20. Aug 6, 2016 at 8:10 AM
    cmack
    cmack Well-Known Member
    18 Burrito
    Mine are coming off today. 27k mi on them and they have a toytec AAL in em
