Az Geek Talk
Discussion in 'Arizona' started by Aw9d, Dec 11, 2012.
  1. Jun 3, 2015 at 6:50 PM
    #2141
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
  2. Jun 3, 2015 at 6:57 PM
    #2142
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I have Cox, and my torrent speed seem pretty quick. I also use protocol encryption with is supposed to help with that. :notsure:
  3. Jun 5, 2015 at 8:24 AM
    #2143
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    If Cox does throttle high end ports, I've never noticed it.
    A simple ICMP pingplotter to the ASUS during torrent connections shows that the router couldn't handle the number of connections and load through it. I switched over to my ASA5505 and showed over 2000 concurrent connections. I don't think ASUS has that kind of stats and horsepower anyway.
  4. Jun 5, 2015 at 10:17 AM
    #2144
    Aw9d
    Aw9d [OP] That one guy
    My speeds on Cox have been decent as well. I don't use default ports but I just switched over to them and didn't notice much of a difference in speeds when downloading the same file 2 times.
  5. Jun 10, 2015 at 8:52 AM
    #2145
    Aw9d
    Been messing with "Ok Google" and found some neat stuff it can do while I was on back to back meetings all day yesterday.
    1. Ask it to play any music. I have it to check my phone first, if its not there it checks my Google Play Music account which more than likely has the song I'm looking for. "Ok Google, Play Stone Temple Pilots Crackerman" and boom it plays. Then you can "Ok Google, next, pause, stop".
    2. Ask it things about where you are at. It now has location awareness. I was walking in the park and asked "What is the name of this Park" and it told me. The demo I saw showed a guy standing by a church in a park and said "what is the name of that Church" and it figured it out. Kinda neat.
    3. Carry a conversation with it, sort of. I asked it "How built the Hover Dam" and got the answer. Then I just asked "When" and it told me when construction started. I asked "when did it finish" and it told me the end date of construction. Google now knows you are asking follow-up questions about the first question you asked. Kinda neat but still needs more work.
    4. Fun things to say to google. "Make me a sandwich", "Do a barrel roll", "Tilt", "Who's on 1st", "When am I".
    Brian007Taco likes this.
  6. Jun 10, 2015 at 11:02 AM
    #2146
    Martimus
    Martimus Well-Known Member
    Martin
    'neath a cactus
    2012 PreRunner SR5
    A few years ago I got the crazy notion to build my own e-mail server. I found out the hard way that Cox blocks port 25. While I could have worked around it, I ultimately decided to re-use the hardware and build something else. It's my understanding that many ISP's block ports to make it more difficult for businesses to operate on their consumer networks, though many tend to spin it by saying they do it to reduce virus exposure and security risks.
    http://www.cox.com/residential/supp...rticleId=cacf82f0-6407-11df-ccef-000000000000
  7. Jun 10, 2015 at 11:11 AM
    #2147
    Aw9d
    This is true with cox for some areas. However if you get a business account with them then they will open those ports up.
  8. Jun 10, 2015 at 12:18 PM
    #2148
    Martimus
    Martin
    'neath a cactus
    2012 PreRunner SR5
    Quite true... Unfortunately, in my case, I don't want to pay for a business account when I'm not running a business out of my home. I periodically build systems to help keep my skills current.
  9. Jun 10, 2015 at 12:35 PM
    #2149
    replica9000
    2019 T4R ORP
    I wish I could get a static IP from them without a business account.
  10. Jun 10, 2015 at 12:37 PM
    #2150
    Aw9d
    Does your change often? I've had the same IP for 3 years.
    Get Dyndns. Hell I got like 18 more domains, you are more than welcome to one.
  11. Jun 10, 2015 at 12:48 PM
    #2151
    replica9000
    2019 T4R ORP
    It only changes when my router restarts due to power outages, which is maybe twice a year. I SSH to my PC often (not using port 22), so it sucks when I need to update the IP address for the apps that connect to my PC.
  12. Jun 10, 2015 at 12:52 PM
    #2152
    Aw9d
    Even when I power cycle my modem or the power goes out I still get the same IP. The only times it's changed for me is when I bought a new modem, or when I called and asked for it to be changed because of non-stop brute force entries and what not.
  13. Jun 10, 2015 at 12:54 PM
    #2153
    replica9000
    2019 T4R ORP
    This is why I don't use port 22. I think a lot of bots try to attack that port.
  14. Jun 10, 2015 at 1:08 PM
    #2154
    Aw9d
    I don't use any standard ports for most anything. I just got lucky and had an IP that for some reason was getting nailed on all ports no matter what I did. Cox changed the IP issue went away.
  15. Jun 10, 2015 at 5:08 PM
    #2155
    azchris
    azchris Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    Bots hit my sshd on port 22 with their shitty password lists 24 hours a day. With password login turned off and reasonable rules set on the firewall and fail2ban I give zero fucks. A real DDoS hitting your gateway is going to cause a shitty day regardless of what port you're using.
  16. Jun 10, 2015 at 7:03 PM
    #2156
    azchris
    Prescott, AZ
    Also, this might be a decent place to put this, but I've got a 1U poweredge 1750 up for grabs if anyone is willing to pick it up within the next couple days. I'm near 48th st and elliot. I haven't tried booting it for a couple years, but it used to work just fine. Comes with 2x 30GB 15krpm Cheetahs, 2x 3GHz Xeons, and 2x 512MB DDR ECC memory.
    It's useless for modern server stuff like ESXi, because the Xeons aren't x64, but it's also free. Figured someone might need some old ass part/power supply that's hard to find.
  17. Jun 11, 2015 at 9:01 PM
    #2157
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
  18. Jun 11, 2015 at 9:11 PM
    #2158
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Planing on checking out the S6 tomorrow and maybe leave the apple world!
  19. Jun 11, 2015 at 9:12 PM
    #2159
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Bwahaha.. Goood Goooood.
  20. Jun 11, 2015 at 9:15 PM
    #2160
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    picked mine up today!!! love it so far.
    also picked up the samsung gear circle
