Az Geek Talk
Discussion in 'Arizona' started by Aw9d, Dec 11, 2012.
  1. Feb 15, 2017 at 1:00 PM
    #4481
    iBoosted
    iBoosted It's go to be the king
    Niko
    Mesa, Arizona
    2017 BBP Tacoma TRD Off-Road 4x4
    TRD PRO Front Grille Icons stage 3 lift Icons Billet Upper Control Arms Method Roost's Toyo Tires Caliraised Ditch Lights Caliraised Rear facing amber lights Caliraised Fog Lights Interior: Many Patches Greyman Tactical Rigid Insert Molle Panel
    I have yet tried either. Not sure if I should use it on the Linksys Velop if it will really help with it that much.
  2. Feb 15, 2017 at 1:00 PM
    #4482
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I want to get the Linksys WRT1900AC. It was designed with 3rd party firmware in mind. My Cisco E3000 does the job right now though.
  3. Feb 15, 2017 at 1:05 PM
    #4483
    Aw9d
    Aw9d [OP] That one guy
    I love Tomato for all the little tweaks you can't do with stock firmware. Over clock it, increase WiFi performance, use a VPN on it without limiting yourself to 15mb down speeds.
  4. Feb 15, 2017 at 1:10 PM
    #4484
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Well no Tomato but there does seem to be a DDWRT firmware from what the support list suggests.
  5. Feb 15, 2017 at 1:15 PM
    #4485
    Aw9d
    DDWRT isn't bad. I just like Tomato more. Both really do the same thing. It's not worth it for most people as all the extra features you can tweak can just make things worse if you aren't sure what they do. My main reason for doing it was to put my entire house on a VPN. So anything connected to WiFi is on that VPN vs me having to install a client on each device.
    a.smo[QUOTED] likes this.
  6. Feb 15, 2017 at 1:17 PM
    #4486
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Netgear Router/Modem arrived yesterday. Finally got it hooked up today. And I am dealing with it now.
    Modem connected to ISP without issue. 24 channels down are locked and 4 channels up are locked.
    So far all wired devices are working as expected.
    Wireless are all connected and I am in the process of modifying Kodi settings as the routers IP range for nether is slightly different that asus. Not a big deal, just mildly a PITA. I am sure if I dug deep enough I would figure out how to change the router's IP range, but That would be as much work as resetting Kodi's source settings on one device, as the other pull from it.
    I was hoping to use my old ASUS RT-N56u as a repeater for a faster connection to an older Media server, but that is easier said than done. First I have to load a different OS in the router, as this one doesn't allow it... not hard, just time. Second, and most importantly, the mac mini I am using for the media server (SickBeard and SAB) seems to have a hardware issue with it's ethernet port. Which I will deal with on a mother day.
    Setup was easy and it is all work, will report back in a few weeks. Hopefully the latency issues over trying to do some much on wi-fi have been elevated.
    Aw9d[QUOTED][OP] likes this.
  7. Feb 15, 2017 at 1:18 PM
    #4487
    a.smo
    Aaron
    PHX, Az
    Hmm... Thats why I haven't gotten a VPN was convenience... Might have to do more research.
  8. Feb 15, 2017 at 1:21 PM
    #4488
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    This Netgear and my older ASUS both have VPN that can be setup by default. I think it is one example of these guys finally listening to what the people want.
    I need to play with Tomato more, maybe this ASUS will become my test router.
  9. Feb 15, 2017 at 1:22 PM
    #4489
    Aw9d
    I have the NHL package and I hate that fact we get blacked out if it's on NBCSN. So I set the VPN to Canada and boom, no more blackouts.
  10. Feb 15, 2017 at 1:22 PM
    #4490
    Aw9d
    My Asus's all had VPN, but the speeds were limited to 10 or 15mb down. Which made it worthless if you wanted to stream.
  11. Feb 15, 2017 at 1:23 PM
    #4491
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I did not know that, as I haven't played around with it too much. Thanks.
  12. Feb 15, 2017 at 1:24 PM
    #4492
    Aw9d
    Try it out and see if they've changed it. I read the new Asus are faster but not sure if I'll get the 200mb down still. I think they throttle it for torrent reasons.
  13. Mar 3, 2017 at 6:27 AM
    #4493
    iBoosted
    Niko
    Mesa, Arizona
    Logan was so god damn good!
  14. Mar 3, 2017 at 7:08 AM
    #4494
    Aw9d
    I'm so going today.
    iBoosted[QUOTED] likes this.
  15. Mar 3, 2017 at 7:11 AM
    #4495
    iBoosted
    Niko
    Mesa, Arizona
    It was so worth going last night and being super tired for work today lol.
  16. Mar 3, 2017 at 7:13 AM
    #4496
    Aw9d
    I'm going to try and dip out of a few meetings and go during the day to avoid the teenage crowd.
    iBoosted likes this.
  17. Mar 3, 2017 at 7:15 AM
    #4497
    iBoosted
    Niko
    Mesa, Arizona
    Good luck sir. Co worker said lots of the tickets were sold out.
  18. Mar 4, 2017 at 12:39 PM
    #4498
    replica9000
    2019 T4R ORP
    So what's my reasoning for buying used here? o_O
    2ndGenJonny, Aw9d[OP] and Chipskip like this.
  19. Mar 4, 2017 at 1:56 PM
    #4499
    Aw9d
    Is it any good? I'm waiting for injustice 2
  20. Mar 4, 2017 at 2:07 PM
    #4500
    replica9000
    2019 T4R ORP
    I'll tell you soon. 9 was pretty good. It was the first MK I got into after MK Trilogy.
