Az Geek Talk
Discussion in 'Arizona' started by Aw9d, Dec 11, 2012.
  1. Mar 4, 2017 at 2:47 PM
    #4501
    iBoosted
    iBoosted It's go to be the king
    Niko
    Mesa, Arizona
    2017 BBP Tacoma TRD Off-Road 4x4
    TRD PRO Front Grille Icons stage 3 lift Icons Billet Upper Control Arms Method Roost's Toyo Tires Caliraised Ditch Lights Caliraised Rear facing amber lights Caliraised Fog Lights Interior: Many Patches Greyman Tactical Rigid Insert Molle Panel
    Mortal Kombat X was so much fun
  2. Mar 4, 2017 at 3:53 PM
    #4502
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I'll try it later tonight. Didn't want to wait for a 3gb update
    iBoosted[QUOTED] likes this.
  3. Mar 4, 2017 at 3:55 PM
    #4503
    iBoosted
    Niko
    Mesa, Arizona
    Most of it will just be buffs/nerfs to some champs and what not but really fun to play and the online net code is pretty damn good. I hardly ran into anyone who was laggy to play against as well.
  4. Mar 4, 2017 at 9:13 PM
    #4504
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Hmm, I never looked into tomato because I didn't think I had a need. Auto VPN would be nice.
  5. Mar 5, 2017 at 10:03 AM
    #4505
    Aw9d
    Aw9d [OP] That one guy
    It's worth it. Typically I keep my entire house off the VPN until III want to stream hokey game's that are blacked out. Put the house VPN on Montreal and then start watching. The only problem is that you adds for webpages will change and depending on where your VPN is the language might change as well.
  6. Mar 5, 2017 at 11:18 AM
    #4506
    Istan
    Stan
    Vegas and Yuma
    I don't see that as a problem. I use PA on my devices when I'm out in public and they have instructions for Tomato. Just need to look at which Asus router I'm using these days and see if it'll work. Thanks.
    Aw9d[QUOTED][OP] likes this.
  7. Mar 5, 2017 at 4:16 PM
    #4507
    replica9000
    2019 T4R ORP
    I like it. Being on PS4 vs PS3, it loads faster, and the graphics are better. Fighting feels more fluid. Lots of characters and they have multiple variations of fighting styles/looks. More towers to choose from. Haven't tried online play yet
  8. Mar 8, 2017 at 11:09 AM
    #4508
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    @Aw9d What in the actual fuck did google do to my Samsung S6...
    Google assistant replacing the home key/search?? This literally ruins my phone. I use the "press and hold" on the home key CONSTANTLY to search stuff.. Now I press and hold and it takes me to this assistant bitch.. Nowhere to actually type anything, its all voice..
    Now I have to open chrome (homepage is set to TW), hit the menu dropdown or page button, open a new page, then search..
    It's the smallest change and makes zero sense to me.. It's absolutely not intuitive at all now. Ive been using that button and method for years.. This phone, my note 2.. What.. The... hell..
    "Oh, update on vehicles.. We swapped your gas and brake pedal around, good luck with the learning curve"
    iBoosted likes this.
  9. Mar 8, 2017 at 12:43 PM
    #4509
    Aw9d
    You can turn of the assistant where it reads what ever screen you are on.
  10. Mar 8, 2017 at 12:47 PM
    #4510
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    If I turn off Google assistant... It renders the home button completely useless.
  11. Mar 8, 2017 at 1:20 PM
    #4511
    Aw9d
    Open assistant
    got to the triple dots (settings)
    Disable use screen context
    see if that helps
  12. Mar 8, 2017 at 2:55 PM
    #4512
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Nope. Tried it.
    It turns it off.. Then when I press and hold the home button.. A pop up opens "assistant is turned off, would you like to turn it on"
    :annoyed: :violent:
  13. Mar 8, 2017 at 4:27 PM
    #4513
    Istan
    Stan
    Vegas and Yuma
    Go to settings, aps, default aps, phone assistant, choose which one you want?
    Aw9d[OP] likes this.
  14. Mar 8, 2017 at 9:20 PM
    #4514
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Just turns off assistant. The feature itself is gone.
  15. Mar 8, 2017 at 9:25 PM
    #4515
    Istan
    Stan
    Vegas and Yuma
    So you want Google search to pop up? I use the Google app widget.
  16. Mar 9, 2017 at 6:02 AM
    #4516
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah now I have to use that widget. So lame... Takes up real estate on my screen too..
  17. Mar 10, 2017 at 12:34 PM
    #4517
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Im looking for a wifi signal strength meter. I have an iphone but my brother has a pixel. So an app for either platform will work.
  18. Mar 10, 2017 at 12:49 PM
    #4518
    Istan
    Stan
    Vegas and Yuma
    Did try to undo the update?
  19. Mar 10, 2017 at 2:01 PM
    #4519
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Nah. Just using the dumb search bar widget for now
  20. Mar 10, 2017 at 2:09 PM
    #4520
    Aw9d
    Root and problem solved! Then you can load anything you like. The Pixel comes with it by default.
