AZ LED Gauge swap
Discussion in 'Arizona' started by tacosunday, Aug 10, 2012.
  1. Aug 10, 2012 at 3:30 AM
    tacosunday
    tacosunday [OP] GoldMember
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Local Only - I Supply LED's
    $80 -Gauges
    $15 -Steering Wheel Controls/Per Side
    $10 -Switches/Per Switch
    I can do all four guages and needles in any color theme.
    Also, warnings, caution lights, blinker arrows, ect.
    Any questions please PM or Text (480) 528-6088
    Here is my Taco and wifes 4-Runner.
    Jonesn13's
    BMOC
    Aw9d
    Window switch, Buttons & steering wheel controls
    Rav4 Guages
    1st Gen - Tacomagirl64
  2. Aug 10, 2012 at 4:31 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Looks like in your picks you have some LEDs out.
    Good luck to ya. I was doing this in SA for awhile. Good cheep mod to do.
  3. Aug 10, 2012 at 6:41 AM
    tacosunday
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Not exactly sure what your seeing, but maybe Ill have to try and take some better pictures.
  4. Aug 10, 2012 at 6:45 AM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    Looks like the tacks for fuel and temp are not lit up on the Tacoma. Blue back ground. If one is not working then the other won't. Just tryin to help ya out.
  5. Aug 10, 2012 at 7:13 AM
    tacosunday
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Are you talking about the needles?
  6. Aug 10, 2012 at 7:35 AM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    I believe he is. The needle for the tac is not as bright as the speedometer, and the gas and temp look very dim almost inop on your tacoma vs your wifes 4runner.
  7. Aug 10, 2012 at 7:39 AM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    Yes the needles are out on the Tacoma.
  8. Aug 10, 2012 at 12:55 PM
    tacosunday
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Probably because the speedo needle I did 2 white and 1 blue. The tach 1 green and 1 blue, and fuel and temp 1 green each. I also didnt paint the backs of the needles, I was just experimenting. Plus the camera didnt get it very well. But I assure you that there is no burnt LED's.
    Also, this morning I changed all the needles to pure white and painted them, just to cure any doubt about whether or not I can tell if a LED looks "inop" or "out" and took another picture. Sucks cause I kinda liked the green.
  9. Aug 10, 2012 at 1:10 PM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    Aaawell didn't know you put green for the needles on that side. Green with the red needles maybe why.
    There are a lot of guys in AZ and I'm sure plenty will want this done.
    Good luck OP
  10. Aug 10, 2012 at 1:37 PM
    Aw9d
    Aw9d That one guy
    Az
    What did you paint them with?
    And why did you have to paint them?
  11. Aug 10, 2012 at 2:12 PM
    tacosunday
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    The backside of the stock needles are originally painted red, I used nail polish remover to take the red off and paint the backside white. It helps the color and light of the LED reflect brighter. I used white acrylic from a local RC hobby shop.
  12. Aug 10, 2012 at 3:05 PM
    Aw9d
    Aw9d That one guy
    Az
    awesome! thanks for the tip.. I'm still debating if I want to tackle this myself or not.
  13. Aug 10, 2012 at 4:39 PM
    XPOTRPR
    XPOTRPR EXPOtrooper
    Moose
    Chandler, AZ
    Mid-Travel, Boosted, Expo Taco
    Click build link in Sig >>
    I want to do this.. but the thing is.. there's still a lot of orange lighting in our trucks. I want them ALL the same color. So I may stick to orange. My deck can change colors so everything matches already..
    Looks sweet tho! I would want everything white.. with red needles. :)
    Good luck OP! People.. jump on this. $50 is cheap!
  14. Aug 10, 2012 at 8:48 PM
    CQB 1911
    CQB 1911 Well-Known Member
    Jesse
    AZ.
    2010 TRD OR AC
    What he said...
    ALL the same color white with red needles. Post some more pics when you do more. Nice to see someone in AZ doing these.
  15. Aug 10, 2012 at 8:54 PM
    kfree1
    kfree1 Well-Known Member
    Kyle
    Tempe, Arizona / Los Alamitos, California
    06 PreRunner SR5
    I'll be back in Tempe in a couple weeks. I'm for sure hitting you up to get this done
  16. Aug 10, 2012 at 9:09 PM
    tacosunday
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Im already looking in to doing all the accessory and option lighting such as the radio, steering wheel controls, clock and power windows and locks. Ill update OP when it happens.
  17. Aug 10, 2012 at 9:10 PM
    tacosunday
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Sounds good :thumbup:
  18. Aug 10, 2012 at 9:20 PM
    broken taco
    broken taco Well-Known Member
    Adam
    San Diego
    01 TRD SR5 4WD
    Custom pre-runner front bumper with a warn winch, custom grill, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), Fox extended travel coil overs with reservoirs up front, Total Chaos upper control arms, limit straps, Diff Drop, Deaver leaf Springs, Fox shocks with reservoirs on back, BFG KM2 tires, HID off road lights on front bumper, 16w square pods from olympusoffroad for reverse lights, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system. Alpine Deck, Alpine amp, Alpine speaker, JL W6 12" subwoofer, JL amp,
    i will probably have you do this for me. i am heading up to flagstaff for college and i will probably see if i can stop by on my way up there. if not this trip up. i will get to you sometime. and you can do 1st gens right?
  19. Aug 11, 2012 at 8:55 AM
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    lemme know how u do the buttons and everything. i did my gauges and radio all blue and white. just waiting to do the hvac stuff and steering controls
    its an easy mod
  20. Aug 11, 2012 at 9:09 AM
    XPOTRPR
    XPOTRPR EXPOtrooper
    Moose
    Chandler, AZ
    Sweeet.. keep us posted then. Cuz I will DEFINITELY have this done then. :)
