AZ PewPewPew Meet aka @Mike330R shooting diary
Discussion in 'Arizona' started by Istan, Mar 11, 2018.
  1. Sep 23, 2018 at 8:23 PM
    #301
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    @Mike330R would you happen to know of is this a stepped case? Haven't seen a case w/ a line around it like this
  2. Sep 23, 2018 at 8:27 PM
    #302
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I know the feeling. I almost bought an optic. But I really REALLY need to keep my spending in check. I wanna buy ADS shocks.
    Why are all the cool hobbies so damn expensive???:spending:
    Adventurer_Alex likes this.
  3. Sep 23, 2018 at 8:36 PM
    #303
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Not sure but it looks funny.
    That type of case with that crimp ring is what came apart in my M&P. Although it was a reload.
  4. Sep 23, 2018 at 9:02 PM
    #304
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    Not necessarily stepped. But might be.
    The dotted ring is a case cannelure, and can be used with or without a step to reduce bullet setback/eliminate seating processes.
    Either way, it is a stress riser and is usually where you'll see casehead separation when it occurs.
  5. Sep 23, 2018 at 9:05 PM
    #305
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Well these are new, not reloads so I'll shoot them. I dont reload yet and i probably wont reload 9mm when i start so I'll sell them. Hopefully they get melted down.
    axisofoil[QUOTED] likes this.
  6. Sep 23, 2018 at 9:09 PM
    #306
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Had a productive evening. Loaded up some AR mags for plinking. 9 steel case then 1 brass for the full 30 rounds. Then pulled the rest of my steel case out of the white plastic holders. Id rather it be loose in a box than in those when I'm reloading mags at the range/desert. Also loaded my scorpion and glock mags. Ready to go shoot more!
    TXpro4X4 likes this.
  7. Sep 24, 2018 at 8:00 AM
    #307
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    Who has the cheapest transfer fees in north Phoenix?
  8. Sep 24, 2018 at 9:50 AM
    #308
    Mike330R
    Far West Phoenix
    Tried a few different loads and H130 ELDM's today at 100 and 500.
    Was expecting better results at 500. Had a fair amount of misses on paper but 99% hits on a 6" steel swinger.
  9. Sep 24, 2018 at 11:35 AM
    #309
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Dislike, the withdrawls after 6 weeks would be rough :bananadead:
  10. Sep 24, 2018 at 1:27 PM
    #310
    Istan
    Istan [OP] Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Woo-hoo. Finally got to go out with my 6.5grendel. I didn't realize I never put a bipod on it and it is the only non Aero Precision handgaurd I have so I couldn't use my bipoded handgaurd. It was hard as hell using the grip as a monopod but was able to ring steel at 780 yards. Not very many but I heard it ring!
    Also, it's the first time in probably a year I shot something without a suppressor. Didn't think of putting hearing protection on. That's a mistake you make once.
    Mike330R and Adventurer_Alex like this.
  11. Sep 24, 2018 at 3:14 PM
    #311
    Istan
    Stan
    Vegas and Yuma
    I'll pick one up from you. I was just about to order a new bipod and mlok adapter. I'm still on cheap Caldwell but they seem to work. I just have to remember never to use an Atlas so I don't know better.
  12. Sep 25, 2018 at 6:23 PM
    #312
    Istan
    Stan
    Vegas and Yuma
    So should I get one? Mlok direct is appealing.
  13. Sep 25, 2018 at 6:57 PM
    #313
    Istan
    Stan
    Vegas and Yuma
    I've been trying to change all of my handgaurds to aero precision mlok but I forgot I had one Samson on this upper. I think it's time for me to put on my big boy pants and try an atlas but my bank account keeps saying don't do it.
  14. Sep 25, 2018 at 7:42 PM
    #314
    Mike330R
    Far West Phoenix
    I have 4 I have gathered over time, 3 are QD.
    I like that they lock into position, can be used at different angles, and think they look nice.
    I often use it in the forward 45 degree position from a bench.
    Downside is weight (still not very heavy) and slower deployment.
    DevilDocAZ likes this.
  15. Sep 26, 2018 at 9:46 AM
    #315
    Vitalzone
    Vitalzone Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    I have 2 Atlas PSR QD bipods, about to buy an Atlas CAL.I use them for hunting, and long range steel. I like the ability to change the feet between rubber, and spikes. Yeah there a lil slower to deploy than a Harris. In a hunting situation that won’t be a problem. Far more time will be wasted getting into a comfortable shooting position, and acquiring your target.
  16. Sep 26, 2018 at 9:59 AM
    #316
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I host shooting/wheeling TW meets at my cabin in the mountains of WV. Always a great time!
  17. Sep 26, 2018 at 12:33 PM
    #317
    Mike330R
    Far West Phoenix
    201 rounds of 260 loaded. Working on other calibers now.
  18. Sep 26, 2018 at 3:29 PM
    #318
    Mike330R
    Far West Phoenix
    I still use Hornady 130 factory ammo since it shoots so good. Also use these reloads, same bullet.
  19. Sep 26, 2018 at 3:47 PM
    #319
    Mike330R
    Far West Phoenix
    Prime is a tad to hot for a semi auto. Similiar results as shown in my pic's below from others.
    Although a fair amount of people use it in these Larue's.
    My last outing with my reloads speeds were 2800'ish.
  20. Sep 26, 2018 at 4:15 PM
    #320
    Mike330R
    Far West Phoenix
    Anyone up for some morning pew pew tomorrow?
