AZ Ratings
Discussion in 'Arizona' started by RPS1030, Mar 7, 2016.
  1. Mar 7, 2016 at 7:01 AM
    RPS1030
    RPS1030 [OP] Well-Known Member
    General Off-Roading Tips/Etiquette
    DO NOT RUN CLOSED TRAILS! If the gate is locked, don't bypass it. If it's posted, don't go there. Do your research, a number of historical trails are no longer open to access. If you can't find info on location, make friends with those that might. If it's not out there, don't post location/GPS info. There are a number of trails that are kept low-key to limit traffic and issues.
    RIP Martinez Canyon, Coke Ovens, etc.
    Don’t go alone. Some of these trails are remote and receive very limited use. Having another vehicle to help get unstuck/recover, is a good practice.
    Keep the vehicle behind in view (check your mirrors semi-regularly). Make sure the vehicle behind you hasn’t had trouble/missed a turn.
    Don’t follow too closely. On climbs/obstacles, wait for the rig in front to complete it. If they have to stop/back-up; you don’t want to be in the way or have to stop/lose your momentum. On the slow stuff, being able to see and pick your own line is helpful.
    Use 4Low. The low range gear reduction improves control and reduces strain on the transmission and/or clutch. For the Manual Trans folks, try it and practice…yes, it tends to lurch forward initially, but then it usually slows down and crawls along. Get used to what to expect.
    Air Down. Dropping the tire pressure increases grip, improves sidewall flex/grabbing of rocks, allows the tire to conform to the terrain. Many times the tire can move instead of tearing.
    CB/Ham Radio – Communication is helpful and fun. Knowing if/why somebody has dropped back or having difficulty (or taking a pit-stop). Or why did the group stop (Is it a quick “move something” or “look-see” or should/can we all get out)? Not to mention the jokes/banter/trash talking you might be missing out on.
    Spotting *Driver* - Pick/Decide on one person to lead you through a section. Get a plan of attack/line choice. What level of “damage” are you willing to accept? (Rub a lower bumper/Use the skids/sliders/Rub a wheel/etc.) Shit happens if/when rocks move/tires slide/clearances misjudged; we are hoping to avoid it-try to be positive. We are here to hangout/have a good time and the group will help when needed.
    Spotting *Spotter* - Know what the driver wants to do. Give clear guidance. “Turn Driver/Passenger”, avoid “Straighten Out” (driver may not know where the wheels are pointed), Obvious/Visible Hand Direction when needed/used.
    Spotting *Group* - Let the Driver/Spotter work together. Too many directions will confuse the driver. A Safety Full Stop is ok if you see something the spotter doesn’t.
    Stay on the Trail/Remove Stacked Rock/Keep it Clean. Our access to these trails is always under scrutiny. Almost all of the rocky/wash trails are confined to the wash. If you’re planning to take dirt bypasses, they probably aren’t legal access and trying that trail should be reconsidered. If you stacked rocks to get up a ledge, remove them so the next group can experience the full challenge. A trail will eventually get easier/”paved” in if we don’t. (Until the next monsoon season of course). Don’t litter.
    Disclaimer: Most of the ratings/reviews out there are Jeep biased. Short wheelbase/solid front axle/narrower body change the crawling ability/maneuverability, so realize that it might be more challenging in a longer Tacoma/4Runner, etc. Sliders are mandatory if you want to progress up the difficulty level in a truck.
    It has also been a number of years since these trail rating numbers were set/posted. Monsoon/Floods move rocks/boulders/sand/dirt. What was hard may be easier and what was easier may be impassable.
    1.0-Improved dirt road
    2.0-Unimproved dirt roads. Potholes, minor wash outs, medium sized rocks and mud holes. Higher ground clearance helpful.
    3.0-Difficult Trail. Loose gravel, large pot holes, steep inclines, medium sized rocks, 4 wheel drive required, aggressive tread and lowered tire pressure helpful.
    3.5-Hard Trail. Same as above. Some rocky sections, go arounds at major obstacles. Body damage possible, mainly rocker panel or rear quarter panel.
    4.0-Moderate rocky trail. Frequent ledges, crevices, large boulders, steep inclines and off camber situations. Body and or tire damage likely. Spotters may be needed for some obstacles. Low tire pressure required, good chance of loosing a bead. Possible component breakages.
    4.5-Hard rocky trail. Same as a 4.0 rated trail but the obstacles are bigger, tighter squeezes and bigger risks to body and mechanical components. Few bypasses if any. Longer wheelbase vehicles may have problems with breakover angles, short wheelbase vehicles may have to use a winch or strap on some obstacles. Large vehicles will damage sheet metal. Spotter may be needed for all major obstacles. Rollovers possible. Plan for common component breakages (vehicle specific).
    5.0-Extreme rocky trail. Same as a 4.5 rated trail but the obstacles are bigger, tighter squeezes and bigger risks to body and mechanical components. No bypasses. Body damage guaranteed. Spotters needed for most of trail. Rollovers likely. Some obstacles may require a winch for larger vehicles. Trail may be impassible when wet. Plan for major component breakages. Realistically these trails should be run with rock buggies.
    5.5-Insane trail. Same as a 5.0 rated trail except all of the obstacles are bigger. Constant spotting required, vehicles will get hung up frequently, undercarriage will catch rocks. At some point a winch will be required to support the full weight of the vehicle.
  2. Mar 7, 2016 at 8:05 AM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
  3. Mar 7, 2016 at 8:38 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    I think id like to try Raw Deal again(as long as there isnt 15 jeeps ahead of us)
    4Running Daily and RPS1030[OP] like this.
  4. Mar 7, 2016 at 8:45 AM
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    This is a awesome thread an will help many people find a answer fast good idea !! :thumbsup:
    JeepAndrew likes this.
  5. Mar 7, 2016 at 8:50 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    :popcorn:Great thread idea OP!:thumbsup:
  6. Mar 7, 2016 at 8:50 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Maybe add a closure section. A lot of the guides don't have that info.
    Like Coke Ovens trail, Martinez Canyon etc
  7. Mar 7, 2016 at 10:31 AM
    JeepAndrew
    JeepAndrew Nah bitch Jeep guy
    Andrew
    Tucson, AZ
    Offroad beast YJ/2015 Taco
    Lots-o-mods
    Damn good thread idea! If need be, I can give input on a lot of the Tucson area trails (Rug Road, Charouleau Gap, Chiva Falls etc).
    TaylorU, snowtank and RPS1030[OP] like this.
  8. Mar 7, 2016 at 11:14 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    you da man Ryan!! awesome thread!
  9. Mar 7, 2016 at 3:15 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    omg, the thread picture is the VJC logo. make it stop!! its burning my eyes
    I have a ton from Sunflower Mine and I can find some from LC
  10. Mar 7, 2016 at 3:26 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    :popcorn: nice idea ryan!
  11. Mar 7, 2016 at 5:23 PM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
    I didn't think Jack Handle was all that bad, unless it has changed drastically since 2014. There were only a couple spots that were challenging.
    I really want to run CK, Desoto, and Sunflower. Haven't ran Log Corral since I broke my rear axle housing and shredded a radiator, need a redo there.
  12. Mar 7, 2016 at 6:16 PM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
  13. Mar 7, 2016 at 6:35 PM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
    I did Jack Handle during a 4wheelparts customer appreciation run. Did the squeeze open/open without much trouble. Bro-tool behind me in a huge mall-crawled out Grand Cherokee wasn't so lucky; massive body damage. Very amusing that was :D
  14. Mar 18, 2016 at 10:30 AM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I'm liking this. Maybe I can dig up some old pics or post a few trail reviews.
    RPS1030[OP] likes this.
  15. Mar 18, 2016 at 10:34 AM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Sub'd!
  16. Mar 18, 2016 at 10:43 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    geoyota760 and RPS1030[OP] like this.
  17. Mar 18, 2016 at 10:44 AM
    jhonn236
    jhonn236 Member
    Just last night I was looking at trails to go off-roading in the near future. I've been to box canyon too many times! I even downloaded the AllTrails app haha. Great thread OP!
  18. Mar 18, 2016 at 10:58 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
  19. Mar 18, 2016 at 10:59 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Watching that video makes me miss it haha
  20. Mar 18, 2016 at 11:10 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Im trying to get back but the weekend everyone is going is Jerome's bday. So maybe easter weekend a few of us can sneak up there
