AZ2013 Build, Hunting & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by AZ2013, Nov 15, 2015.
  1. Apr 7, 2016 at 8:54 AM
    #101
    AZ2013
    AZ2013 [OP] Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    Work truck. Off duty detail sitting in construction zones with the lights on. Easiest money I'll ever make.
    I haven't sat in the other truck in a week! Lol. Been too damn busy with work.
  2. Apr 7, 2016 at 10:40 AM
    #102
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    :wave: lucky sob . Im sitting in my office surfing the web Tho. So cant complain to much :D
  3. Apr 7, 2016 at 11:03 AM
    #103
    AZ2013
    Blake
    Easy $$$$$$$
    snowtank likes this.
  4. Apr 7, 2016 at 12:44 PM
    #104
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ahhh ok. where the construction?
    you know.. I really need to get with you so we can plan some pranks on my family and friends that still live up there :D
    I've been playing in Solidworks all day.. designing truck parts :D lol
    snowtank[QUOTED] likes this.
  5. Apr 7, 2016 at 1:03 PM
    #105
    snowtank
    Andrew
    Arizona
    Nice! Lucky
  6. Apr 7, 2016 at 1:38 PM
    #106
    AZ2013
    Blake
    This particular job is up in cottonwood wood. Have another one in a couple weeks up in Sedona. We rarely get the local jobs. DPS usually swipes them up.
    Shoot me some names and I'll see what I can do!! Haha.
  7. Apr 7, 2016 at 2:03 PM
    #107
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ahh got ya. ok. yeah DPS is who we all usually deal with. unless the Johnsons or that crew show up. lol Was actually supposed to see them a couple weeks ago. family BBQ.
  8. Apr 22, 2016 at 12:29 PM
    #108
    AZ2013
    Blake
    So I decided to skip the Ultra Gauge and picked up this.
    http://www.amazon.com/gp/aw/d/B01C6...1&pi=AC_SX236_SY340_FMwebp_QL65&keywords=obd2
    I downloaded the Torque app and started messing around with it. Can't figure out why my speedometer is so far off. App shows 42 when I'm doing 20 and 110 when I'm doing 60!! I figured it would be off some because of the bigger tires but not like this.
    Also my traction control light has been on since I drove home with my alignment jacked after I did the lift. Figured it would have thrown a code but the reader says no current or stored codes. Tried using the reset function on the app and the light is still on. I even disconnected the battery and the light is still on.
    Something I'm doing wrong that's so obvious I look right past it?
  9. Apr 22, 2016 at 12:33 PM
    #109
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    take it into the dealer to have them recalibrate the traction control/vsc and that should take care of that.
    the Torque thing.. hmmm.. idk. either a setting in there somewhere or how you did your vehicle profile?
    you order those switches yet? :D
  10. Apr 22, 2016 at 12:37 PM
    #110
    AZ2013
    Blake
    Switch came in about an hour ago. It's sick but the actual button is small. Nor sure they make them any bigger though. I'll have that stuff on its way to you later today.
    I'll keep messing with the app. There's a ton of shit on there. Lol.
  11. Apr 22, 2016 at 12:39 PM
    #111
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    nice! next week I'll hopefully get started on it then.
    yeah.. maybe do a reinstall or clear the cache, etc.
  12. Apr 23, 2016 at 9:56 AM
    #112
    AZ2013
    Blake
    So I decided to do some reading up on the VSC issue to see if maybe I could re calibrate it myself. Found out a ton of people having issues after installing a lift. I haven't had any of the forced braking issues but my light stays on and it does drive funny. I had no idea the VSC system was such an issue.
    In true TW fashion I'm sure I'll spend a few hours researching it before I give my money to the stealer ship.
  13. Apr 23, 2016 at 9:59 AM
    #113
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Abs killswitch mod
    You'll never have to deal with it again... And most likely forget about it. Lol
    Was one of the first mods I ever did, and its it's still one of my factories.
  14. Apr 23, 2016 at 10:08 AM
    #114
    AZ2013
    Blake
    Yeah I don't know man. ABS has saved my ass a couple times over the years and I'm not sure I want to bypass that.
    I'm wondering if the VSC has anything to do with the truck driving funny. It's hard to explain but I constantly feel like the truck just wanders wherever it wants to. Alignment is good. Maybe I'm just not used to the sway bar being removed?? Also sounds funny when going through turns. Kind of similar to rubbing or bad brake pads but I've double checked. I don't rub and my pads are probably still 75%.
    I don't get the beeping and forced braking at all. I just have the VSC light on. These things may have nothing to do with the VSC system at all and could just be byproducts of having the lift. I don't know yet.
  15. Apr 23, 2016 at 10:28 AM
    #115
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Understandable. For me.. It would kick on in even the most calm of driving maneuvers. Turning out of driveways, trying to make I turns, etc. Now its selectable. And in numerous instances the abs has almost caused me not be able to stop in time in some scenarios.
    The other things about wandering, etc.. Could just be not being used to no swaybar.. A lifted vehicle.. Not perfect alignment. Etc. Might all just be placebo too. Lol.
    Have you retorqued everything since install? Especially the lowers after the alignment?
  16. Apr 23, 2016 at 10:35 AM
    #116
    AZ2013
    Blake
    Everything but the lowers has been re torqued. I'll double check those today.
    I'm guessing most of the wandering is simply the sway bar and not being used to it. I'm half tempted to throw it back on real quick and see what the difference feels like.
    Which method did you use for the ABS kill switch? Seems like there's several.
  17. Apr 23, 2016 at 10:45 AM
    #117
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Lowers have always been the cause of my weird feelings in my steering or suspension. Just have to reeeally torque down on those lower cam bolts.
    I did just the ground wire with a simple toggle switch method. Lol tap into it and add your switch. Turns your lights on but I like it because it's a good indicator when its activated.
    AZ2013[OP] likes this.
  18. Apr 23, 2016 at 10:51 AM
    #118
    AZ2013
    Blake
    Right on man. Thanks for the tips.
  19. Apr 23, 2016 at 11:07 AM
    #119
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Not a problem! :cheers:
  20. Apr 28, 2016 at 6:25 PM
    #120
    AZ2013
    Blake
    Impromptu rim road run today. Tried to find some mud but the rain surprisingly stayed below the rim.
    20160428_120614.jpg 20160428_114706.jpg 20160428_114225.jpg 20160428_114245.jpg
    TACOVRD likes this.
