azchris's 2011 TRD Off Road Build
Discussion in '2nd Gen. Builds (2005-2015)' started by azchris, Apr 24, 2011.
  1. Apr 24, 2011 at 8:02 PM
    azchris
    azchris [OP] Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    So I'm not new to the forums, but I'm fairly new to Tacoma ownership :D I'm gonna do this chronologically so you can see the truck as it progresses.
    Specs:
    • Silver Streak
    • TRD OffRoad
    • Double Cab Short Bed
    • v6 PreRunner
    Current mods:
    • Smittybilt Lightbar with 4 Kragen HIDs
    • Removed mudflaps
    • 20% tint front, 5% tint rear
    • Smoked rear emblems, debadged doors
    • Powdercoated TRD rims graphite, had the black side of tires turned outside. Balanced with stick-on weights on the inside.
    Future mods:
    • 265/75R16 All Terrain KOs
    • Wicked Flow muffler
    • Some sort of leveling kit for the front
    March/April 2011
    Anyway, I have big plans for the truck but I'm trying not to get in over my head right away. So far, I've put a Smittybilt lightbar and 4 Kragen HIDs up front and removed the mudflaps. I also want to tint the fronts 35% and the rear doors/window 20% over the factory tint, which should bring it down to about 7% I think.
    Here's some shots of the truck with less than 1000 miles on it:
    Mudflaps and paper plates still on
    2011 grille up close
    Stock... for now
    The 2011 gauge cluster
    Now for the lightbar...
    The second one in wasn't quite straight...
    And one of another Tacoma parked in front of me
    May 2011
    Got it in to be tinted, decided to do 20% on the front, and 5% around the back 3 windows. I'm glad I did, it's exactly how I wanted it to look. A little hard to see the rear view at night, but otherwise it's perfect. Some bad cell phone pics:
    June 2011
    Blacked out the badges with Duplicolor Shadow, there's a thread about it here:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/162937-smoked-badges-experiment.html
    July 2011
    Originally these were getting powdercoated to fix some gouges that a tire shop put in them. Unfortunately, the powdercoat shop did a pretty terrible job, so a friend made me some paint that is mostly clear coat and black+gold pearl and sprayed over the sanded powdercoat, so it was a body-shop-quality job with hardener and everything :D
    Next thing on the list is debadging the doors (which I've been meaning to do for awhile) and a front-to-back detail job.
    Stuck!
    So I figured I would add a stuck section to the thread. This is the first weekend I got the truck, locked and running at 35PSI. It did pretty well except for these two hills.
    That's all for now!
  2. Apr 24, 2011 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Subbed!
  3. Apr 24, 2011 at 9:54 PM
    sveezy012
    sveezy012 BigPoppaSmurf
    Sergio
    Huntsville, Tx
    Texas Edition
    2 1/2" Bilstein Lift w/ Add a Leaf Pack Borla Exhaust aFe CAI
    nice lookin truck man, mines stock too except for the new headlights, takin my build slowly but surely! im really diggin the new gauge cluster! let me know what kind of mods ur plannin, ill be sure to return some ideas :D
  4. Apr 24, 2011 at 9:55 PM
    rcfreak201
    rcfreak201 Well-Known Member
    WOW! You sir have some great photography skills! awesome truck!
  5. Apr 25, 2011 at 8:23 PM
    azchris
    Prescott, AZ
    Guess I should add this to the main thread, after the warranty runs out I'm looking at doing a nice mid travel suspension. Here's one setup I was thinking about, but I'll have some time to decide while it's under warranty.
    Wheels and Tires
    Procomp 8128
    BFG All Terrain 285/75R16
    Suspension
    Icon Ext. Travel Resi Coilovers Front
    Camburg Uniball UCAs Front
    Camburg 4" Lift Spindle Front
    All Pro 3" Leaf Pack Rear
    Icon Resi Shocks Rear
    All Pro U Bolt Flip and Bumpstops Rear
  6. Apr 25, 2011 at 8:24 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    check out the AZ sections man!
  7. Apr 25, 2011 at 8:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    sounds like a solid set up!
  8. Apr 25, 2011 at 8:45 PM
    Dr. Pepper
    Dr. Pepper Well-Known Member
    Tampa, Florida
    08 PreRunner SR5
    Truck looks good man, and plans sound good aswell. I love that cluster!
  9. Apr 27, 2011 at 8:50 PM
    azchris
    Prescott, AZ
    Stuck!
  10. Apr 27, 2011 at 8:57 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Where are the stuck pictures taken?
  11. Apr 27, 2011 at 8:58 PM
    azchris
    Prescott, AZ
    Nighttime ones are at Picacho in California, daytime ones are in the desert near Yuma, about a mile or two north off exit 12 on I-8.
  12. Apr 27, 2011 at 9:13 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I love the road to picacho. specially at night, too bad its only 18 miles long.
    I got stuck there once as well. What had happen was that i was prerunning and hit some whoops but everything was fine. we stopped to check out the canyon at the midpoint of the trail. Once we got in the truck again, the battery was dead. it turned out that the battery bounced and cracked. leaking all the battery acid. We walked back for a while till we got picked up
  13. Apr 27, 2011 at 9:15 PM
    azchris
    Prescott, AZ
    I was down in the wash, I backed off the trail to turn around and ended up on a slope which dug the back tires in. Stupid mistake. I don't have 4WD to get me out. My friend's 1st gen didn't fair so well...
  14. Apr 27, 2011 at 9:18 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Ouch,
    Ill be down to do the run when im back in yuma for the summer
  15. Apr 27, 2011 at 9:20 PM
    azchris
    Prescott, AZ
    Yep, I'm at ASU right now. Can't wait to get back to Yuma and hit up the desert and the river :D
  16. Apr 27, 2011 at 9:21 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  17. Apr 27, 2011 at 9:26 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Im at ASU as well.
    Im ready to do some float downs as well
  18. Apr 27, 2011 at 9:29 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Ouch! :eek:
  19. May 18, 2011 at 2:08 PM
    azchris
    Prescott, AZ
    May 2011
  20. May 18, 2011 at 2:22 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    you down in Yuma yet?
