B.A.M.F 2nd Gen rear shock relocation kit GB feeler
Discussion in 'Group Buys' started by JLee, Nov 7, 2012.
Thread Status:
Not open for further replies.
  1. Nov 7, 2012 at 10:54 AM
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The pricing is
    DIY kit in pieces: $100.00
    Fully welded ready to weld on the truck: $165.00
    All the GB kits are gone thanks guys for all the orders.
    NOTE you don't have to run KING shocks but they are the only shocks we have tested with this kit so others may not work in the buckets.
    KING shocks tested KING Part# PR2012-SS 12.0" stroke 31.585" Extended Length 19.585" Collapsed Length 7/8" Shaft Dia
    A Quote from the thread in my vendor section.
    We have been working on a shock relocation kit for a wile now and we now finality have one on a truck. We spent about 12 hours yesterday mocking up and installing this kit yesterday. We designed this kit to fit 12" stroke shocks off the front side of the axle.
    What the kit contains (Note this is just one side I comes with 2 sets of this)
    All stock shock mounts were removed and ground smooth.
    After everything was mocked up we tacked the buckets together.
    After tacking the buckets we fully welded all seems.
    Then we tacked the mounts to the frame and axle. The shocks are mounted and 90* from side to side and 9* forward
    After we tacked it up we went out side to make sure everything was all good the shock mounts looked good he does need longer bump stops to stop the leaves from going into a negative arch. we also noticed the tire touching the shock body at full stuff. Wheel spacers or a less back spacing may be needed. Or with a 90* fitting on the shock it could be tucked tighter to the frame by about .75"
  2. Nov 7, 2012 at 11:18 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
  3. Nov 7, 2012 at 11:30 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    diy shipped to canada yesterday :p
    Darth_Yota likes this.
  4. Nov 7, 2012 at 11:39 AM
    JLee
    Jerry
    Bay Area NorCal
    I'll get right on it Joe :rolleyes:
  5. Nov 7, 2012 at 11:42 AM
    JLee
    Jerry
    Bay Area NorCal
    i started a list feel free to add yourself if interested.
    List
    1. bulhas DIY kit
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
  6. Nov 7, 2012 at 12:48 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
  7. Nov 7, 2012 at 12:57 PM
    HomerTaco
    HomerTaco Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    I may be in as well - gotta talk to you though... I'll reach out later on this week if I get some free time.:eek: HD has me running... :(
  8. Nov 7, 2012 at 1:04 PM
    JLee
    Jerry
    Bay Area NorCal
    Sounds good Craig.
  9. Nov 7, 2012 at 1:05 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    any big gains from doing this?
  10. Nov 7, 2012 at 1:10 PM
    JLee
    Jerry
    Bay Area NorCal
    Yep 12" shocks it takes that stock limit factor out of your suspension. Your stock shocks limit travel in most cases these allow you to use the full travel of the springs.
  11. Nov 7, 2012 at 1:35 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total chaos Long travel kit, swayaway coilovers, deaver leaf pack with icon resi's
    Im on my phone can some one add me to the list please DIY kit. Thank you
  12. Nov 7, 2012 at 1:38 PM
    Burgman
    Stephen
    Ric VA
  13. Nov 7, 2012 at 1:42 PM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Thank you good sir
  14. Nov 7, 2012 at 1:42 PM
    JLee
    Jerry
    Bay Area NorCal
    Both added.
  15. Nov 7, 2012 at 2:06 PM
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    San Clemente
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    subd .. very interested, pending funds and a return message from DSM
  16. Nov 7, 2012 at 2:06 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    List
    1. bulhas DIY kit
    2. Burgman DIY kit
    3. Precoma DIY kit
    4. mgrande Welded kit
    5.
    6.
    7.
    8.
    9.
    10.
    Also, any chance I can add a diff skid to my order? :eek:
  17. Nov 7, 2012 at 2:09 PM
    JLee
    Jerry
    Bay Area NorCal
    Sure but it wont be discounted :)
  18. Nov 7, 2012 at 6:15 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    that's fine :D
  19. Nov 7, 2012 at 6:18 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    soooooooo glad i bought my rear shocks before :p and shackle flip :p
    no waiting for this guy, just need Jerry to say yup they are ready :p
  20. Nov 7, 2012 at 6:45 PM
    NoSoup4You
    David
    San Clemente
    Ehh .. I'll get shocks eventually
    List
    1. bulhas DIY kit
    2. Burgman DIY kit
    3. Precoma DIY kit
    5. NoSoup4You DIY Kit
    6.
    7.
    8.
    9.
    10.
Thread Status:
