B.A.M.F 2nd Gen rear shock relocation kit.
Discussion in 'Bay Area Metal Fabrication' started by JLee, Aug 6, 2012.
  1. Feb 12, 2013 at 8:31 AM
    #121
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You can see here if you drilled a hole in the back of the upper mount you could get that nut closer to the side of the bed. The problem is that upper is so close to the bed you would have to drill a hole in the bed to do so.You might beable to get away with not drilling but I'm sure the nut would contact the bed side. In the next batch I'm just going to cut a larger hole in the back side of the upper mount to give you guys that option with the only modification being a small hole drilled in the bed. Doing this with give you another 0.695" of clearance it's not much but it could be the difference between hitting the tire or not and full flex. Just doing so would make it so the 2.0 shocks would be to only thing you could run. It's kinda a toss up to get longer shocks in without cutting changes need to be made IE wheel spacers or less BS wheels. If you don't mind cutting the bed you can always cut the bed and move the uppers further in giving you more room for tires.
  2. Mar 7, 2013 at 8:49 PM
    #122
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    just placed my order
  3. Apr 2, 2013 at 12:53 AM
    #123
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Added the Spidertrax to the just installed B.A.M.F. Shock relocation buckets, 2.5 King 12" stroke remote resi's and Deaver custom 5" lift pack
  4. Apr 2, 2013 at 9:08 AM
    #124
    JLee
    Jerry
    Bay Area NorCal
    How big of a hole did you cut into the top of the bucket? I might just add that in the next batch so the 2.5's will clear in all of the kits.
  5. Apr 2, 2013 at 10:24 AM
    #125
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Man, I really want/need a set of these. I need to take some measurements to see if they'll fit with the new shoes...
  6. Apr 3, 2013 at 12:58 PM
    #126
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    This is where the mount had to be cut to be able to fit the 2.5's
  7. Apr 3, 2013 at 1:11 PM
    #127
    JLee
    Jerry
    Bay Area NorCal
    Thanks i will adjust the file for the next run.
  8. Apr 5, 2013 at 7:20 PM
    #128
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
  9. May 17, 2013 at 5:59 PM
    #129
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    we may have taken the bed off to do this
  10. May 19, 2013 at 10:24 PM
    #130
    sytfu510
    sytfu510 INSTAGRAM: sytfu510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit DMZ LT Kit TRD Supercharger SCS Wheels BAMF
  11. May 21, 2013 at 3:53 PM
    #131
    allmotorrex
    allmotorrex Grove Street Fabricating
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    cage it!!!
  12. May 22, 2013 at 4:36 PM
    #132
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Glendale, AZ
    Just returned from OCS and will be keeping track of this thread to get in on the next run!
  13. May 27, 2013 at 12:14 AM
    #133
    Only Danks
    Only Danks TRUKWERX : Desert Racing Products
    Bryant
    San Diego, CA
    05 Black TRD O/R 4x4
    3" MID-TRAVEL LIFT: Fox 6x2.5 Front RR C/O's, Fabtech unibal UCA, Fox 10x2 Rear RR Shocks, All-Pro Leaf Pack, Fox 2x2.5 Air Bumps all 4, Strapped all 4, TC Gussets:, Lower Arm Cam Tabs, Front C/O Bucket Tower, Spindles, OTHER: Custom Front Bumper skid, Custom Rear Tube Bumper, McNeil Racing 3" Fiberglass Fenders, McNeil Racing 4" Fiberglass TT Bedsides, 2 Matching Vertical Spares, GrillCraft black mesh, 07 LED Tails(black), Headlights (black), Viper 5204 Alarm, Remote Start, Cobra 19 CB Radio, 6 ft Red LED Firestick Whip, High-lift jack, Black Emblems, STEREO: Custom Nexus7 inDash, Rockford 3sixty.3 to SPDIF, Rockford T1 6.5 Comp Front, Rockford T1 6x9 rear, Rockford PBR300x4 Amp, Rockford P310 (x2) rear seats, Alpine 1100w amp, USB DAC via SPDIF, USB Audio ROM, FUTURE MODS: TC +2" LT Kit, 8" LT Coilover, 16 Rear Piggys, L/T CV Axle Shafts, Heim Steering, DMZ SUA kit, Bedsaver cage, Shackle Crossmember, Motor Mount Gussets, Box Frame
    just what i was looking for. considering something like this in combo with Defined SUA kit. 12" shock wont fit?
  14. May 27, 2013 at 7:15 AM
    #134
    JLee
    Jerry
    Bay Area NorCal
    I know nothing about the defined kit so the best thing to do would be to order both before the shocks and measure for shocks once everything is on the truck.
  15. May 27, 2013 at 11:00 AM
    #135
    xSectionxEightx
    xSectionxEightx Well-Known Member
    Josh
    Phoenix
    06 4x4 4.0L 6sp Access Cab
    Allpro LT powder coated black with Fox 2.5s. BAMF Sliders w/ kick outs. Allpro Expo leaf pack and Fox 2.0 RR. Brute Force hybrid bumper. BAMF Roofrack. Tepui Kukenam in Siberia Camo. CBI ditch light brackets. Cobra CB. Allpro skidplate.
    Moving to Bay area next week. I will be getting a set of these for sure. I can't wait to get rid of my hoop setup!!
  16. Jun 4, 2013 at 12:40 PM
    #136
    Lil'Taco
    Lil'Taco Well-Known Member
    Scotty
    Corvallis, OR
    2010 PreRunner Sport DCSB
    Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights, aFe CAI, Borla Cat-back exhaust, Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts.... It has more stuff done to it now.
    Whats the difference between King and Fox shock mounting? Would it be as easy as larger bolt hole or the hole in the top to make room for it? I would like to stay with Fox all around.
  17. Jun 6, 2013 at 10:34 AM
    #137
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
  18. Jun 6, 2013 at 10:46 AM
    #138
    JLee
    Jerry
    Bay Area NorCal
    Your guess is as good as mine I would assume eye to eye shocks would be the same. As far as I know a 1/2" mounting hole is the standard. The main thing is compressed and extended lengths.
  19. Jul 22, 2013 at 10:27 AM
    #139
    tacobox
    tacobox Evasive Maneuvers PMKMS
  20. Jul 22, 2013 at 3:11 PM
    #140
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Those def wont fit. I'm hoping to fit 2.5's like TX PRO did on the previous page. Have you seen the ones with an internal bypass?
    http://downsouthmotorsports.com/i-8...ck-with-internal-bypass-option-reservoir.html
    I havent done my homework on them yet so I have no idea what theyre about.
