B.A.M.F LCA Skids are here!!!
Discussion in 'Bay Area Metal Fabrication' started by JLee, Apr 10, 2012.
  1. Mar 8, 2016 at 6:14 AM
    #1161
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Get a 3 pack of step bits from harbor freight. Just don't use an impact driver to spin them or you will snap the shaft. Just advice from personal experience
  2. Jun 2, 2016 at 2:36 PM
    #1162
    qxrtz4321
    qxrtz4321 Well-Known Member
    Mitch
    Montana / Washington
    Do these fit 2016s?
    90yota likes this.
  3. Aug 28, 2016 at 3:56 PM
    #1163
    Jks1
    Jks1 Well-Known Member
    Jared
    SLC, UTAH
    14 dcsb offroad
    Looking on the website, do I need to select qty 2 or do they come as a set?
  4. Aug 28, 2016 at 6:32 PM
    #1164
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    They are sold as a set.
  5. Aug 28, 2016 at 7:20 PM
    #1165
    Jks1
    Jared
    SLC, UTAH
    14 dcsb offroad
    I figured they were since I'm sure they're handed. We spoke last week by email, you were checking that I still wanted to switch slider order to bolt on. If I ordered these can they ship together or do these go through a different carrier?
  6. Jan 30, 2017 at 9:18 PM
    #1166
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Took me about an hour to find this post Time to break out the drill. We will see how that goes.
  7. Jan 31, 2017 at 9:25 AM
    #1167
    Smar969905
    Zach
    Deer Park, WA
    if you have a full face shield, wear it. If not, wear safety glasses and minimize exposed skin when drilling. Hot metal burns a little when it hits the skin.
  8. Mar 15, 2017 at 4:00 AM
    #1168
    JLee
    Jerry
    Grass valley CA
    I've never had any reports of that. How many threads are sticking out past the bolt?
  9. Mar 15, 2017 at 6:09 AM
    #1169
    JLee
    Jerry
    Grass valley CA
    Yeah Please do we have sold hundreds of these and never heard that. was it full droop full lock also what suspension set up do you have?
    Blackout14 likes this.
  10. Mar 15, 2017 at 11:45 AM
    #1170
    JLee
    Jerry
    Grass valley CA
    I'm wondering if that torn boot is flexing down more at full droop. Also is it an aftermarket CV?
  11. Mar 15, 2017 at 12:09 PM
    #1171
    JLee
    Jerry
    Grass valley CA
    Well I'd like to know if this is only yours, We could look into pan head sex bolts if this is something that's common but hell not one single person has said anything about it being that close so I'm stumped. maybe alignment do you have your specs? Also does your boot rub the LCA?
  12. Mar 15, 2017 at 12:16 PM
    #1172
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Damn. I can't run those numbers but I think it's the back spacing on my wheels I'm at 2.25/2.0 caster was at 3.0/2.8 and still rub LCA no matter what caster apparently...:censored:
  13. Mar 15, 2017 at 12:22 PM
    #1173
    bski22
    Rob
    Toyota
    No tire side wall.
  14. Mar 15, 2017 at 12:32 PM
    #1174
    JLee
    Jerry
    Grass valley CA
    Yeah that's very odd worst case we could cut you some 1/8th thick square washers with a welded nut on the inside and just use a shorter bolt.
  15. Mar 15, 2017 at 12:54 PM
    #1175
    bski22
    Rob
    Toyota
    Yep
  16. Mar 15, 2017 at 12:55 PM
    #1176
    bski22
    Rob
    Toyota
    Also running 295/70/17 though so maybe the width of the tire could be the reason
  17. Apr 7, 2017 at 8:51 AM
    #1177
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    No issue here....
    Taco_2s_day and Pirhett like this.
  18. Jun 23, 2017 at 7:02 PM
    #1178
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Anybody have any issues installing this with an all pro ifs skid?
  19. Jun 24, 2017 at 12:08 AM
    #1179
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I used to have an AP ifs skid, no probs
    bijick[QUOTED] likes this.
  20. Jun 24, 2017 at 8:25 AM
    #1180
    JLee
    Jerry
    Grass valley CA
    Our LCA skids should clear just about every aftermarket skid plate. Now I've not tested them all but the only one I've found to have clearance issues was the Budbuilt.
