B.A.M.F Rear Diff skid plate
Discussion in 'Bay Area Metal Fabrication' started by JLee, Sep 6, 2011.
  1. Nov 29, 2011 at 7:11 AM
    #1041
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Hey Jerry, my truck is an '04. Just noticed you have it on the OP as an '03. I'm guessing it's the same design for the parking brake cable, but wanted to check just in case.
  2. Nov 29, 2011 at 7:14 AM
    #1042
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah its the same thing and the skid fits the 03 & 04 I just need to drill and tap a hole for that little brake cable.
  3. Nov 29, 2011 at 7:20 AM
    #1043
    Enigmaaron
    PA
    1st gen superiority
    Cool, is the cable getting attached to the skid now instead of making the skid bigger to go around it?
  4. Nov 29, 2011 at 7:23 AM
    #1044
    JLee
    Jerry
    Grass valley CA
    Yeah the skid fits if you remove the cable and move it to the skid. And the skid is already big on the back of the 1st Gen axle i don't want to make it any bigger.
  5. Nov 29, 2011 at 7:43 AM
    #1045
    Enigmaaron
    PA
    1st gen superiority
    Sounds good. :thumbsup:
  6. Nov 29, 2011 at 9:57 AM
    #1046
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Got mine this morning.... Had just enough time to open the box & drool on it before I had to leave for work.:(
    May have to paint it tonight... :D
  7. Nov 29, 2011 at 5:04 PM
    #1047
    CVYota
    CVYota Damaged Goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    these looks great Jerry, shouldn't you take a vacation from work so you can finish them up? :D
  8. Nov 29, 2011 at 5:40 PM
    #1048
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    Painted, nothing fancy.
  9. Nov 29, 2011 at 5:43 PM
    #1049
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Some pics...
    When I unwrapped it:
    cleaned up the welds around the logo a bit with the Dremmel & re-primed it.
    I'm thinking red... :notsure:
  10. Nov 29, 2011 at 5:48 PM
    #1050
    JLee
    Jerry
    Grass valley CA
    Man If I could I would it sucks sitting all day doing noting when i could be in the shop busting these skids out. I do have a good grove now and I can pump out 5 a week. I have 6 80% right now and I just went and picked up some more 1/2" plate so tonight I cut the clamps for the next 20 skids and tomorrow I build.
    I'm hoping to have most of the GB done by the end of the month :pray: Because I've go some new things I want to do some R&D on :spy:
  11. Nov 29, 2011 at 8:35 PM
    #1051
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    Thats my plan. Red with black letters
  12. Nov 29, 2011 at 8:56 PM
    #1052
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I think I'm going to do the same when I do my 90k service :D
  13. Nov 30, 2011 at 1:02 AM
    #1053
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    I should be done painting mines tomorrow. Turned out a little disappointing, the flouro green ended up looking like just a lime green. LAME.
    I blacked out the letters, then realized I missed the dots/periods. So once those are blacked out as well, the diff will be done and mounted up.
    However a green diff cover on a red truck will be quite the color clash. lol
  14. Nov 30, 2011 at 7:05 AM
    #1054
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    Not to those that love Christmas!
  15. Nov 30, 2011 at 9:36 AM
    #1055
    JLee
    Jerry
    Grass valley CA
    Here is a quick screen shot of something I'm working on for the shop. It's my rendering of a Catch style Press Brake. I wish I would of built something like this before the GB :(
    Quick rundown of the specs.. 37" window width, 1/2" thick main frame sandwiched between 2 pieces of 1/4" for a total of 1" thick main frame.
    Arms and shackles will be 2 laminated pieces of 3/8" for a 3/4" thickness.
    5"x 24" Hydraulic Cylinder pushing on swingarms with about 3:1 ratio. This will push down on shackles that will increase downward pressure as the shackles get close to swinging "over-center".
    Hydraulic System will consist of a 5hp motor, 2500psi pump and log splitter valve.
    When finished it should be running somewhere around 100tons of down force. plenty to bend 36" sheets of 1/4" plate. I should be able to bend 24" 3/8" plate with ease
    This is just what I did yesterday wile at work :cool: I'm sure I'll be changing things as I go. I'm hoping to have the .dxf ready to cut in a month or so I will be cutting everything on my TorchMate but the main frame because it's too large I'll be farming that out.
  16. Nov 30, 2011 at 1:01 PM
    #1056
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    some mounted pics with a cleaner truck :p
    Crom likes this.
  17. Nov 30, 2011 at 4:40 PM
    #1057
    JLee
    Jerry
    Grass valley CA
    Looking good man :thumbsup:
  18. Nov 30, 2011 at 4:45 PM
    #1058
    Mudman
    Cerritos
    08 4X4 TRD Sport
    Gonna mount it up by Friday hopefully. Been pretty busy.
    Crom likes this.
  19. Nov 30, 2011 at 4:50 PM
    #1059
    MJonaGS32
    MJ
    SF Bay Area (East)
    niiice!! slimer!
  20. Nov 30, 2011 at 5:02 PM
    #1060
    Mudman
    Cerritos
    08 4X4 TRD Sport
    Are you picking up all this material with the Tacoma? lol because it sure sounds like a crapload of weight.
    At this rate your going to need a full size or a dually to haul all that steel dude. :D
