B&M tranny cooler + Autometer temp gauge
Discussion in '1st Gen. Tacomas (1995-2004)' started by Markmarkmark, Mar 31, 2020.
  1. Mar 31, 2020 at 10:25 AM
    Markmarkmark
    Markmarkmark [OP] Well-Known Member
    Mark
    Seattle, WA
    1996 White Taco SR5
    Exterior: ARB Bumper NWTI Rear Bumper All Pro 80 rock sliders with bump Bakflip Tonneau CBI ditch light brackets Lighting: Trucklite LED headlight 20' Rigid Radiance Lightbar Rigid SRM ditch lights Rigid E series reverse lights Hella 500 spotlight with HID conversion Amazon special RGB bed lights (it blinks lol) LED all over the place Electronics: Compustar with Drone LTE Switch-Pro 9100 Pioneer AVH-1440 Kicker 6x9 speakers Portable Viair 400P compressor Badlands 9K Winch Drivetrain: 3rd Gen OR 16 wheels BF Goodrich K02 OME Nitrochargers with 883 Coils Dakar Leaf springs Bilstein 5100 rear suspension Wheelers S/S brake lines Tundra Calipers Brembo blank rotor Random Stuff: Diff breather relocator DIY pioneering gear mount Quickfist mounts Rear dog platform Future: Overland racks SCS 16x8 rims or Enkei RPT1 Skid plates ARB rear locker ARB onboard Air CB radio Unibal UCA Future: (probably not going to happen lol) Heated seat conversion King suspension
    Hello,
    Trying to find what everyone's transmission temperature displays with the following mods or a similar transmission cooler with temp gauge set up.
    ---B&M super cooler with autometer electric temp gauge---
    I am running a selenoid from the return line through the inline sensor. (Improved Racing ENV-150 Dual Inline Oil Sensor Manifold Block, 3/8" Hose Barbs )
    My autometer reads under 100 degrees on normal driving conditions with no tow or load. I used a laser temp reader and I get between 65-80 degrees on the hose line and the tranny cooler. My transmission pan reads around 125-130 degrees.
    Just for reference, my truck is lifted 3' and I run 285/75/16 tires V6.
    I typically two a 6x10 with two race bikes spares and rolling tool cart. I've had my tranny temp sensor go off before without the transmission cooler.
    Question:
    - Is my temp sensor wrong?
    - How do I check my temp sensors accuracy?
    Thanks,
    -Mark
  2. Mar 31, 2020 at 10:48 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    I don't believe you would want your transmission temps that low.
  3. Mar 31, 2020 at 12:15 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I'm running a trans cooler and my normal temps via scan gauge is 130 to 140 degrees. With 80 to 100 degrees ambient air temp.
  4. Mar 31, 2020 at 12:18 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Is the temp gauge sensor stick down into oil flow? Also is you temp sensor on the outlet cooler line of trans or return line?
  5. Mar 31, 2020 at 12:19 PM
    Wulf
    rock raisin
    100 degrees on the cool side and 125-130 at the pan? it sounds like the cooler is doing its job
    you may want to move the sender to the feed line or the transmission pan to get a more accurate reading or just add 30 deg to whatever the cooler return value is at
  6. Mar 31, 2020 at 1:33 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    There is no way those numbers are correct.
    I have a different cooler and gauge and I installed my sensor right at the outlet from the transmission. This should give me the hottest reading.
    Cruising in lockup mine sits right around 160, sometimes cooler depending on ambient temp.
    High shifting/load situations it will spike up to 200.
    Do you still have your transmission lines routed through the radiator? That should bring the temp close to the coolant temp.
    100 degrees is way too cold.
    If I were you I would get the sensor as close to the outlet of the transmission as possible. Putting it on the return line only tells you if the cooler is working. I would want to know how hot my transmission is getting, not what the cooler is doing.
    mechanicjon and opteron like this.
  7. Mar 31, 2020 at 2:07 PM
    SpikerEng
    SpikerEng Well-Known Member
    Leon
    Portland, OR
    Your temp gauge sending unit should be in the transmission outlet line, and it should always read hotter than the pan temp (transmission picks up the pan oil and heats it up before sending to radiator for cooling). So if you're measuring pan temps higher than your gauge or your line, you must have your gauge in the return line, not the outlet line.
    mechanicjon likes this.
  8. Mar 31, 2020 at 7:09 PM
    rj15tacoma
    rj15tacoma Well-Known Member
    I have a scan gauge 2 and found a code on the internet that shows the tranny temp. Mine is an 01 prerunner auto and it reads consistently around 140, goes up to 180 when towing
