B14C0 and B14C1 codes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Josh-L, Sep 10, 2022.
  1. Sep 10, 2022 at 2:06 PM
    Josh-L
    Josh-L [OP] Well-Known Member
    2021 Silver SR DCSB V6 4x4
    So I picked up an OBD scanner to play around with. I ran a check and my truck threw these two codes. I googled it and it has to do with the front seat heaters from what I gather. Problem is I have a SR so I don’t have seat heaters. Further searching found there’s a TSB fix for this exact situation. Has anyone done this fix? Is it just a ecu re-flash? Any issues if I just ignore it? I’m pretty pissed also because I literally went to the dealership this week (before finding this) because my truck does the stuttering thing also and asked to check if I had the most recent flash. I’m not the smartest but I would assume they would have seen these codes when and if they actually checked. I sat there for an hour and they came back and said I was good so I’m assuming they did jack crap.
  2. Sep 10, 2022 at 2:13 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes its a TSB to reflash the AC ECU. The dealer is idiotic.
    What region are you in?
  3. Sep 10, 2022 at 2:17 PM
    Josh-L
    Central Oklahoma.
  4. Sep 12, 2022 at 10:16 AM
    Josh-L
    Anyone else have any input? If this really isn't necessary then I'd rather not return to the dealership if these error codes do no harm.
