Baby Needs a new pair of shoes.
Discussion in 'Wheels & Tires' started by Rapide, Nov 23, 2018.
  1. Nov 23, 2018 at 5:04 AM
    Rapide
    Rapide [OP] Member
    2004 Tacoma SR5
    none
    Hello... It`s time to get a new set of tires for my 2004 2WD Tacoma. I`ve always replaced the tires with what they came with from the dealer 205 75/15. Is their something better I should be using. It the extended cab model and the handling has never great from new. Any help would be appreciated. Thank Jeb
  2. Nov 25, 2018 at 11:22 AM
    Brokebrute
    Brokebrute Well-Known Member
    Joe
    2004 Tacoma TRD
    Grey wire mod and 2 low mod
    If you live where it snows very often I would stick with the stock size. Otherwise a bigger rim and a lower profile tire will help handling but will make it ride rougher.
  3. Nov 25, 2018 at 2:33 PM
    Rapide
    Rapide [OP] Member
    2004 Tacoma SR5
    none
    Thanks Joe.... I ended up putting the same size tires back on the truck. Walmart has the Goodyear 60000 mile tires on sale. So for 248.00 I`m all set. We do get snow up here, so I didn't have too many options. Thanks Again. Jeb
    Biscuits likes this.
  4. Nov 25, 2018 at 10:26 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Apparently the Walmart Goodyears are solid tires, so you're probably good. The OEM tires are good for holding air, but that's about it.
  5. Nov 25, 2018 at 10:37 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Make sure to add some weight in the bed if you do encounter snow. Better traction.
