Back at the dealer clutch noise .
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GOTSAND?18, Sep 8, 2020.
  1. Sep 8, 2020 at 11:00 AM
    GOTSAND?18
    GOTSAND?18 [OP] Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Well I got a noisy clutch pedal when pushed in especially coming off 1st gear creak noise . Only 5k miles =( .wondering if anyone knows the TSB for this issue or a quick fix of some kind ..ie lube adjustment . The pedal does have a little play . I have appointment with dealer but would like to have the tsb for it incase they try to pull a fast one on me .
  2. Sep 8, 2020 at 11:01 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    TSB-0112-19
    GOTSAND?18[OP] likes this.
  3. Sep 8, 2020 at 11:36 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If they don't want to do anything with it then just lube it yourself with Disc Brake Grease
  4. Oct 12, 2020 at 2:01 PM
    GOTSAND?18
    stock
    Back at the dealer for the second time for the clutch pedal creek literally 1 week later . Pulled the tsb they told me it doesn’t apply to the 20 ... swear this Toyota dealer have a bunch of morons . If I came in already for the same issue and it’s doing the same shit . Logic says replace the mofo . Lol
  5. Nov 15, 2020 at 5:33 PM
    RHED808
    RHED808 -Zeke
    Hawaii
    2018 TRD Pro MT
    RIGID DSS PRO KO2 265/75r16
    I had this problem with my Tacoma and didn’t get it fixed till 10k but I think I have my paper that went over what they did. Do you need what they did to fix it for reference next time you bring it to them ?
  6. Nov 15, 2020 at 5:47 PM
    GOTSAND?18
    stock
    Update dealer replaced all the bushings and parts for the clutch pedal . Noise gone hopefully stays gone .
  7. Nov 15, 2020 at 5:51 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Do be surprised if it comes back... You're truck is a 2020, so it likely had all of the updated parts installed from the factory.
    I had a 2018 with the creak. Dealer's master mechanic said they deal with them all of the time (all Tacoma years).
    I bought a tube of Permatex 80345 White Lithium Grease and greased up the spring pivot points and the top of the rod pivot (hard to get to).
    The creak was gone for 10k miles until I sold it.
    Give it a try when the creak comes back in 5k...
  8. Nov 15, 2020 at 5:52 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Ia the 3rd gen clutch pedal still plastic?
  9. Nov 15, 2020 at 5:53 PM
    HAILST8
    HAILST8 Retired Munitioneer
    Russ
    Florida
    2022 Sport SWDCSB4WD
    Stock+
    I just went thru this. 6K miles on my 2020. Noise started around 5K, but I never dealt with it. I finally put brake grease (maybe 1/2 tsp total) on the spring coil and bushings a little over a week ago...no noise at all now. Kinda pissed I didn't do it sooner. Too easy.
    fdbyrne likes this.
  10. Nov 15, 2020 at 5:53 PM
    DTaco18
    Yup.
  11. Nov 15, 2020 at 6:05 PM
    Key-Rei
    Key
    Florida
    The FJ cruiser uses a steel pedal I have a (modified) FJ pedal and master cylinder and my clutch is nice and quiet. It uses a clevis and pin rather than the ball and socket.
  12. Nov 15, 2020 at 7:55 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    I've had three different Tacoma's with MT and the squeak is normal.
    Dab some grease on it yourself and save yourself a trip to the dealer.
    Never really bothered me.
    shakerhood and Key-Rei like this.
