Back end clanks and rattles when going over bumps...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PuyallupJon, Oct 16, 2016.
  1. Oct 16, 2016 at 6:58 PM
    PuyallupJon
    PuyallupJon [OP] 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Anyone know why the back end clanks and rattles when going over railroad tracks or speed bumps? It's a brand new truck but seems like something back there needs some grease.
    I'm a paper pusher by day. Sure would like to be able to crawl under there and shoot something with some grease.
  2. Oct 16, 2016 at 7:08 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    AT or manual?
  3. Oct 16, 2016 at 7:13 PM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    The spare tire has a chain that secures it and either the tire may be a hair loose or the chain may be rattling around.
    vinkon235, boynoyce and Lawfarin like this.
  4. Oct 16, 2016 at 7:14 PM
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    Manual Transmission.
    I'll have a look see at the spare.
  5. Oct 16, 2016 at 7:15 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    The manual transmission is a clunky girl, especially if you're in neutral or clutching going over rough things like speed bumps or potholes. It's entirely normal.
  6. Oct 16, 2016 at 7:17 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    My guess is the spare unless your doing 30 over these
  7. Oct 16, 2016 at 7:19 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    This truck seems to clunk and clank. Time will tell if it is ok...
  8. Oct 16, 2016 at 7:20 PM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    I think most trucks do...at least most I've driven. Nature of the beast.
    TacoJova likes this.
  9. Oct 16, 2016 at 7:27 PM
    NosBigShot
    NosBigShot Well-Known Member
    Charleston Oregon
    93 Bronco , 2016 Taco
    My truck sounded like a skeleton jacking off on a tin roof. I wrapped the spare tire chain in black tape after I tightened it up.
    TacoFister likes this.
  10. Oct 16, 2016 at 7:27 PM
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    Okay. Cool. I'll just drive it and not worry.
  11. Oct 16, 2016 at 7:57 PM
    SBC
    SBC Active Member
    This ^
  12. Oct 16, 2016 at 8:04 PM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    It's this.
    I wouldn't go so far as to say that it's normal because I don't think it SHOULD be happening. Let's just say it's the kind of 'normal' that the Toyota dealerships are talking about when they use that word. It's only 'normal' in the sense that Tacomas with manual transmissions clunk. Mine does it too.
    There's slop in the driveline somewhere that clunks when there is no load on the system.
    OldShu likes this.
  13. Oct 16, 2016 at 8:07 PM
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Same thing with my MT if you have it in gear so it has just a little load on it the clunking stops mostly. Had a MT dodge did the same thing for 120k miles.
  14. Oct 16, 2016 at 8:09 PM
    Normantaco
    Normantaco Well-Known Member
    Pensacola, Fl
    16 4Runner SR5
    Also check for how tightly the spare tire is held. Mine loosened up a little and sounded like shit was going to fall off over every bump. I tightened it up a little bit and the racket went away. Plus the previously mentioned spare tire chain.
  15. Oct 16, 2016 at 8:36 PM
    Homesteader64
    Homesteader64 Well-Known Member
    Alberta
    Alpine White 17 DCSB TRD OR
    Did you check your leaf spring U bolts? Hopefully not the problem, but an easy check, and from all posts about a possibility. If that's the case get em torqued up before anymore driving.
    qxrtz4321 likes this.
  16. Oct 16, 2016 at 8:41 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    it's a truck
  17. Dec 1, 2016 at 2:28 PM
    bssquared82
    bssquared82 b-squared82
    I had the same problem. I noticed that, after going through some deep puddles, I would hear that rattling. Finally looked under the truck and saw that the spare tire chain had fallen through a hole in the spare rim so it was clanging around when I was at an angle. I lowered the spare and re-raised it, trying to make the chain stay somewhere where it wouldn't fall through again. So far it seems to be working. Haven't heard the noise anymore.
  18. Dec 1, 2016 at 3:03 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Also check the rear fender liners as they are known to rattle, I put some rubber tubing on the lower edge of my 15 and it has really helped dampen the noise.
  19. Dec 3, 2016 at 3:51 PM
    ShOwStOpper
    ShOwStOpper Well-Known Member
    whoaa,,the spare tire chain...i got a mysterious rattle and son of a gun i bet thats its,,,i'll tape that up and see what happens...i'll be stoked if thats the prob..
  20. Dec 4, 2016 at 3:05 AM
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    +1 for spare tire chain. I put a padlock through a couple of links so it cannot be dropped, few wraps of gorilla tape to snug it up in the opening. Quiet.
