Back From The Dead
Discussion in '1st Gen. Tacomas (1995-2004)' started by MykeyD, Feb 28, 2024.
  1. Feb 28, 2024 at 9:20 AM
    MykeyD
    MykeyD [OP] Member
    04 Tocoma, 98 4Runner
    2002 Tacoma 2.7L Auto Trans 4x4. I am in the process of locating any parasitic loads I may have & I have a couple of questions. My amp meter is showing 61m.amps between the neg post on battery & the neg clamp with the key in off position which I think is acceptable but my OBD2 meter still shows that it has power, is this normal. I thought the key had to be on for the OBD2 meter to be on. Also, with the key on the seat belt light is on even though i am not sitting in the seat, if I connect the belt it goes off. I thought the seat belt light was setup to detect weight on the seat. I also have a broken (burnt in half) steel cable that runs on the accelerator setup on the TBI to the auto trans, truck runs & shifts fine, what does it do. I will add thought the truck was abandoned for over 6 yrs & I recently brought it back to life.
  2. Feb 28, 2024 at 12:05 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    ODBII should show power but not comm with key out, so that's correct.
    61mA is basically nothing but the way you describe taking the reading seems a little fishy
    Seat belt, at least on mine, just runs to the clip with 2 wires so no pressure sense
    MykeyD[OP] likes this.
  3. Feb 28, 2024 at 12:24 PM
    MykeyD
    MykeyD [OP] Member
  4. Feb 28, 2024 at 12:28 PM
    MykeyD
    MykeyD [OP] Member
    Thanks !! I hooked the battery back in & disconnected the OBD2 scanner. At 1:30 pm I checked battery with no scanner & no key at 12.57 vdc. I will wait until tomorrow same time & recheck battery voltage.
