back in the market for a tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by gupster88, Sep 29, 2010.
  1. Sep 29, 2010 at 2:25 PM
    gupster88
    gupster88 [OP] Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    so i sold the 06 for a 11 mustang 5.0 but as i said id need a truck eventually. so im looking for a getting a decent 1st gen. these trucks seem to last well over 200k. ive found a couple for $11k with about 100k miles on them. mostly 03-04 models.
    anybody got some words of wisdom or special things to look for when checking out the trucks? is 100k miles a little much? im obviously going to need this truck to last me as long as possible so i need something reliable
  2. Sep 29, 2010 at 2:32 PM
    pittim
    pittim mittip backwards
    Mk7 TDI
    Permanent CEL
    if you're getting a v6 that has 100k miles see if the timing belt/water pump was changed. Toyota recommends that it gets changed at 90k.
    Also the whole frame thing.
  3. Sep 29, 2010 at 4:37 PM
    scocar
    scocar Treat the cause, not the symptom
    Ricardo
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    ^^^ x2 on the T-belt, and should also be water pump...
    I bought a late 01 last year with 101k miles (yeah, lucked out on the mileage). No, that mileage is not too much. These trucks should turn a minimum of 200k with basic maintenance (and no jumping). No regrets, other than the stock suspension sucks, so I replaced that.
    You know about the frame rust issue, right?
    A few minor cosmetic things will probably be worn out but are easy to fix (window trim, fender flares, etc.).
    The 01s and 02 had ABS as an option, it became standard in 03, if you care one way or the other.
    They fetch a premium. High demand. Be prepared, and act quickly if you see one you like. Lots of guys have had them snatched out from under them...
    Good hunting.
  4. Sep 29, 2010 at 4:54 PM
    carolinaTRD
    carolinaTRD Well-Known Member
    Evan
    Ft. Bragg, NC
    03 double cab TRD debaged
    nothing....yet
    i've had my '03 for two months now. this is the first i've heard of the timing belt/water pump issue. how can i check mine to see if they've been replaced?
  5. Sep 29, 2010 at 5:16 PM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    on mine when i bought it on sept 3rd, the dealership had a sticker on the engine saying the timing belt was done
  6. Sep 29, 2010 at 5:52 PM
    scocar
    Ricardo
    2015 DCLB 4x4 SR5
    You could also check the maintenance log in the glove box, if it is still in there.
    You can also register on toyotaownersonline.com and enter your VIN, and it may show the truck maint records and TSBs/recalls.
  7. Sep 29, 2010 at 5:56 PM
    scocar
    Ricardo
    2015 DCLB 4x4 SR5
    Oh, yeah, the 01s and I think 02s had a lower ball joint recall on some trucks. This is serious. Mine wasn't done when I bought it. When you are looking at a specific truck or have bought one, register on toyotaownersonline.com and enter the VIN, and it will tell you...dealer will do it on the spot if it is needed. It will get you a free alignment, too....
  8. Sep 29, 2010 at 6:33 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    thanks guys. i am aware of the rust frame issue. this one im looking at specificaly is a 2004, the frame has been coated with a black, texturized paint or something. its a reg cab, 110k miles manual tranny. ill check on the timing belt and water pump. they want $12k for it. i like it alot but not sure about $12k
  9. Sep 29, 2010 at 6:44 PM
    pittim
    Mk7 TDI
    Permanent CEL
    12k is too much.
    I bought my 03 Xcab TRD 4x4 blah blah 5 speed with 55k on it for 13k + TTL 2 years ago.
  10. Sep 29, 2010 at 6:59 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    wow thats a low price (insert staples guy :) ) at least compared to what ive looked at here
  11. Sep 29, 2010 at 7:18 PM
    pittim
    Mk7 TDI
    Permanent CEL
    Yeah I got them to come down a bit in price. I went out the day that it was listed on Autotrader and put a deposit down for it.
    Plus I bought it from a BMW dealer...they probably wanted to get rid of it :p
  12. Oct 2, 2010 at 3:39 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    so where is the water pump and how can i see if its been replaced if theres no documentation? im not exactly a mechanic lol
  13. Oct 2, 2010 at 7:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The water pump is behind that black plastic shroud, front and center on the engine. Removing the shroud will expose it and if its is leaking you will see water/coolant stains.
    Typically, when the timing belt is changed, a sticker saying so will be placed on the black shroud. However, that does not guarantee the wp was changed when the t-belt was changed.
    If the stealership did it there will be documentation that you can access to by creating an account at toyotaownersonline.com. The vin # will give access ot the records in the toyota system.
  14. Oct 2, 2010 at 11:43 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    thanks man!
