Back Panels ?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrandonHayakawa, Aug 26, 2013.
  1. Aug 26, 2013 at 10:40 AM
    BrandonHayakawa
    BrandonHayakawa [OP] Member
    Brandon
    Tahoe
    Taco 03 2.7
    Cold air throttle body spacer
    I need to get in the back to take out the seat belt on the passenger side cause its jammed... Any one know of step by step photos or a video ? Anything helps! Thanks !
  2. Aug 26, 2013 at 5:59 PM
    Madjik_Man
    Colorado Front Range
    Remove back panel first.
    Start at the top and work your way down.
    Remove trim piece on top (3 or 4 clips)
    Remove the bolts it exposes holding on the pad.
    Remove the remaining large plastic (10 or 12 clips)
    Then you can remove the rear quarter panels. Obviously you have to unbolt the rear window latch and other obvious components.
    But that's the gist
  3. Aug 25, 2015 at 12:55 PM
    Rednexican01
    Rednexican01 Member
    Ellensburg
    95 Taco powder blue 4x4 2.7L excab
    3" Trail Gear lift w' 265/75 x 16 Treadwrights BFG AT knockoff
    I hope you had a better time at getting it un-jammed than I did. Nothing on my truck is a straight forward fix, oh no it isn't that's for sure. Murphy's law is all over my truck like stank on shit. Rare is the chance that it'll be easy and fast.
