Back Pressure Question
Discussion in 'Performance and Tuning' started by Drunknsloth, Jan 11, 2011.
  1. Jan 11, 2011 at 11:11 AM
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    So I've been reading a few threads on exhausts and people keep saying things about backpressure. It seems that people think that you need more backpressure, but I thought you only needed backpressure, and a small amount at that, if you had a turbo. So I looked it up and found this website: http://www.thumpertalk.com/forum/showthread.php?t=659727 which explains that you want zero backpressure with the highest output velocity of exhaust gases. Sooo... According to this website, a cut out with the right diameter pipe would be the best choice for performance as to have close to zero backpressure and with the highest output velocity of exhaust gases. So in theory this increase in efficiency should also increase your miles per gallon right?
    Does everyone who complains about loosing back pressure actually mean loosing the velocity of output? Because you don't want back pressure right?
    Am I wrong or does this make sense?
    Edit: According to further reading, you do not want back pressure on turbos either :confused:
  2. Jan 11, 2011 at 2:57 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    You do not want ANY BACKPRESSURE in any forced induction application, even in NA vehicles you want the proper scavenging effect, which seems to get lost in translation...
  3. Jan 11, 2011 at 3:00 PM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    no backpressure on turbos is fine but on a NA you want some backpressure..
  4. Jan 11, 2011 at 3:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bingo!
  5. Jan 11, 2011 at 3:46 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    What if you're not boosted though?
  6. Jan 11, 2011 at 3:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Back pressure is bad regardless. Scavenging is what is used to get the most HP/TQ out of an NA engine. Scavenging doesnt play as much of a role when FI.
  7. Jan 11, 2011 at 3:53 PM
    ToucanV13
    So a cut out would be beneficial even in a stock engine application...
  8. Jan 11, 2011 at 4:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Jan 11, 2011 at 4:31 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Good read
  10. Jan 12, 2011 at 9:09 AM
    Drunknsloth
    Retribution
    South West
    But according to the website, the where in the RPM range you get more power depends on the size of the pipe...
  11. Jan 12, 2011 at 11:55 AM
    ToucanV13
    So how would you benefit more from a 3" as opposed to a 2.5" or is it marginal and only a racer/high performance car could notice a difference. I understand a bigger pipe allows more air flow but I want to know if it's marginal
  12. Jan 13, 2011 at 9:16 AM
    Drunknsloth
    Retribution
    South West
    From what I learned from the website it depends on what RPM range you want more power at. If you go for a 3" the velocity of the exhaust will be slower at low RPM range and faster at a higher RPM range. If you go with a 2.5" the increase in power would be at a lower RPM range then the 3"
