back spacing for first gen
Discussion in 'Wheels & Tires' started by williamsdouglas73, Dec 19, 2012.
  1. Dec 19, 2012 at 7:55 PM
    williamsdouglas73
    williamsdouglas73 [OP] Well-Known Member
    doug williams
    redding
    97 tacoma dlx 4x4
    Bilstien adjustable 5100's up front, Trail-gear stinger bumper, custom fab stop sign skid plate, removed mud flaps
    I want to put new rims on my first gen. I'm looking to install 33 or 32 in tires. So either 11.5 in wide or 12.5 in wide. My question is this, what back spacing should I run for an 8 in wide rim? 3.75?4.75?
  2. Dec 19, 2012 at 8:20 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
  3. Dec 19, 2012 at 8:21 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    4" BS for a 285
    3.75" for a 12.50
  4. Dec 19, 2012 at 9:27 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    my personal experience...
    there's a possibility of slight frame rub
    with a 285 mounted using 4.0"
    This could vary due to brand of tire and sidewall design
    and only when at full steering lock left/right
    It's also a good possibility that a 1250 will have a slight amount of frame rub even at 3.75"
    I personally feel the 3.75" is the better all around choice
    because it allows for more tire fitment/size options and growth.
    I currently run 295's W 16 X 8 BS'd 4.0" ~tires rub the frame some~
    my previously mounted KMII 285's... (sidewall lugs may have contributed)
    tire rub was minimal tho' it polished the frame on one side
    more so then the other
    just sayin'
    ~probably because I wish I had gone with 3.75"
    and instead I need run a 1/4" spacer and swap out to longer lugs~ :(
    good luck OP with your choosing :)
  5. Dec 19, 2012 at 9:52 PM
    williamsdouglas73
    doug williams
    redding
    97 tacoma dlx 4x4
    thanks for the help guys! ill be sure to add pictures as she comes along, 3.75 bs it is then
  6. Dec 20, 2012 at 8:16 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I rubbed inside frame and outside (pinch weld) with 4" and 285's full lock/compression even with a shitload of cutting and clearancing. Gotta pay the piper one way or the other. Reducing backspacing even more would cause more pinch weld rub. Rubbing the frame only causes shiny spots. Rubbing the pinch weld hard can rip the fender off.
