back spacing question
Discussion in 'Wheels & Tires' started by 06silversport, Sep 14, 2011.
  1. Sep 14, 2011 at 6:48 PM
    06silversport
    06silversport [OP] Member
    PA
    06 Silver TRD Sport
    Can I run a wheel on my 06 4X4 Tacoma Sport with a 5.75 backspace. The wheel is 8.5" x 17 and I want to run 265/70/17 Goodyear Duratrac tires. I have Bilstein 5100's set at 1.75 lift up front and a 1" lift block in the rear.
    The 5.75 backspace will set the wheel in .3" or 8mm and will be .7" or 18mm out further.
    Are my numbers correct? Will they rub?
  2. Sep 14, 2011 at 7:40 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    i think that you're correct, it's going to sit in about ~.25 in compared to stock. tires and setup should be fine with min. rubbing if any at all on full lock. have you thought about using 1"-1.5" wheel adapters for an aggressive look.
  3. Sep 14, 2011 at 7:45 PM
    06silversport
    PA
    06 Silver TRD Sport
    I can get the same wheel in a -6 offset / 4.5 backspace, but I don't want the wheel/tire to stick out that far. It will set the wheel/tire out almost 2" more than it is stock.
  4. Sep 14, 2011 at 7:52 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    stock BS is a 5.5" and most folks w/ aftermarket wheels run a 4.5". you may be able to get away with the 5.75, but if you ever decide to go w/ a wider tire and want to use the same wheels, you'll have to add spacers.
  5. Sep 14, 2011 at 7:54 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    personally, i wouldn't mind the stock wheels sticking out another 1" for that aggressive look, but looks is subjective. i would go for the 4.5" bs setup;). take a good look at your stock wheels and try picturing the wheel/tire now more flushed with the fenders.
  6. Sep 15, 2011 at 5:41 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    While the inner edge of the rim will sit IN .25" compared to stock, the out eadge of the wheel will sit OUT 0.75" more than stock, due to the wider rim. That should pull the tire away from the UCA enough to prevent rubbing, since the tire is centered on the rim.
    But as Jamie said, if you are ever going to upsize to wider tires, these won't work for you.
