Back spacing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Littlebro 5, Apr 6, 2011.
  1. Apr 6, 2011 at 10:38 PM
    Littlebro 5
    Littlebro 5 [OP] Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    What is a good back spacing on a 10" wide wheel with 12.5" 33" tires?:cool:
  2. Apr 7, 2011 at 5:57 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    In order to avoid conflict with the suspension backspacing needs to be about the same as the stock wheel, of course depending on the lift you may have rubbing problems elsewhere.
  3. Apr 7, 2011 at 9:19 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    3.5-3.75'' BS. youll need to be lifted at least 2.5'' to clear all plastic to btw.
  4. Apr 7, 2011 at 10:30 AM
    Littlebro 5
    Tyler
    Wilsonville or
    Yeah I am doing a 3" lift with 12.5 33" tires
  5. Apr 7, 2011 at 10:42 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I have 33x12.5" on 15x10" rims with a 3" lift and 3.76" BS and I had to cut quite a bit off and I still rub on the firewall off road. I would try for a 4" or a 4.5" BS if you don't want to cut a lot. Take a look at my build you will see everything I had to cut to make these tires fit.
