Back tires worn out 4,000 miles
Discussion in 'New Members' started by nicacapy, Feb 26, 2012.
  1. Feb 26, 2012 at 1:19 PM
    nicacapy
    nicacapy [OP] New Member
    Pete
    Nicaragua
    Tacoma crewcab
    I just bought the truck, put new tires on the back, the mechanic says the wheels are pointed out as \ /. I've already replace both back wheel bearings and one bent axel. And the springs but I think that was a waste of money and time. Everything under and the whole car looks perfect, no trace of an accident. Very hard to get parts here, too.
  2. Feb 26, 2012 at 1:42 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    thats a problem
  3. Feb 26, 2012 at 1:57 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    your axle must be bent?
  4. Feb 26, 2012 at 2:01 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Bent housing. If it were just a bent axle, the wheel would wobble going down the road.
    If the housing is bent, it's going to flex the axle shafts in the same direction all the time.
    If you had a bent axle, whatever caused that likely also bent the housing. The entire rear end needs to be replaced.
  5. Feb 26, 2012 at 2:47 PM
    Tacoma Mike
    Southern Maine
    this
    Yea had one of these last year. Wore the tires out in 4000 also.
    It went to two other garages until it came here.They had done alignments to it ( LOL). To confirm it i put it up on the alignment machine to get the before specs to show the customer and to check the thrust line. I replaced the housing and just used the guts out of his other unit. Was a easy diagnosis so as long as your frame isn't tweaked you should come right into alignment.
  6. Feb 26, 2012 at 2:53 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The rear is a straight, solid axle. The only way to get the tires pointed in different directions is if somethings bent. I agree with the posts above, your rear axle is jacked up.
  7. Feb 26, 2012 at 6:24 PM
    TacoAL
    TacoAL Well-Known Member
    AL
    The Gunshine State
    TC
    None (for now)
  8. Feb 26, 2012 at 6:39 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    OP said "truck" and his profile indicates a Taco CC, so I'd say it's not an IRS car.
  9. Feb 27, 2012 at 7:18 AM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    This will completely show my lack of knowledge on Tacoma suspensions, but do these have rear struts? If so, those could be causing the problem, had that happen to me before, it will eat the mess out of your tires!!!
  10. Feb 27, 2012 at 7:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    No
  11. Feb 27, 2012 at 7:26 AM
    Pugga
    Massachusetts
    No rear struts unless it's a custom built 4-link suspension (not many of those running around). The rear suspension is a solid axle with a leaf spring suspension. The shocks are only there to dampen the ride and do not support any weight.
  12. Feb 29, 2012 at 3:26 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
