Back up camera just stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aowanders.com, Jan 15, 2020.
  1. Feb 8, 2021 at 12:32 PM
    gmartin284
    gmartin284 Well-Known Member
    Gage
    2008 Tacoma 4x4 double cab
    Replaced the switch and still no back up camera... :annoyed:
  2. Feb 8, 2021 at 8:06 PM
    Taco Husker
    Taco Husker Member
    West Chester Ohio
    2014 TRD Sport DCSB Barcelona Red
    Sorry that didn’t fix your issue. Mine still works but I will be curious to see how you ultimately get yours fixed.
  3. Aug 15, 2021 at 2:50 PM
    Rola2010
    Rola2010 Well-Known Member
    Honolulu, HI
    2010 Tacoma 2wd base RC
    Reviving an older thread but wanting some confirmation the switch on my 5sp manual needs replacing. Camera works fine (have button to turn it on manually), but no reverse lights - they were dim at first, but if I played with the shifter they’d come on normally, now they are completely out and camera doesn’t go on when shifted to reverse. Checked the trigger wire in a-pillar and getting little to no volts when I’m reverse, so am thinking it’s likely the switch. How common is it for the reverse switch to need replacing?
  4. Aug 15, 2021 at 3:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I wouldn’t say it is common.
    But it does happen, I’m pretty sure there’s been at least 1 post on here with the switch going bad.
    I think the guy even posted pictures of it.
    You could unplug the reverse switch and jump the connector.
    If the camera works, replace the switch.
    If not, then the switch isn’t the problem.
    Of you want to be “safe” use a Voltage meter and test the switch.
    But you’ll need to remove the switch. Or have a helper put the Trans in and out of reverse while checking the ohms/continuity.
    Rola2010 and Jimmyh like this.
