Back Up Camera Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by -40, Jan 13, 2019.
  1. Jan 13, 2019 at 7:29 PM
    -40 [OP] Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    I recently installed a tire carrier. It naturally blocks the factory back up camera. I don’t want to mess with taking out the factory back up camera from the tail gate and re routing it to a new location. I also don’t want to buy a kit, and pull out the front radio and do all that stuff.
    Curious if anyone has just spliced or simply cut into the OEM wires near the factory camera and ran a cheap aftermarket back up camera. Anyone know where the wires are located before they enter the tail gate? And any suggestions on a after market camera ( assuming this would work).
    Thanks
  2. Jan 13, 2019 at 7:45 PM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Yup, I just bought a second camera and extended the existing wiring harness. Installed the new camera on the swing out. Above the second hitch. Worked very well.
    On the passenger side tucked in behind the bumper is a plug, that’s the video feed for the camera. Just follow the harness to make sure.
    -40[OP] likes this.
  3. Jan 13, 2019 at 7:48 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Wonder if you could just plug it in where the camera unplugs for when you take the tailgate off
    -40[OP] likes this.
  4. Jan 13, 2019 at 7:54 PM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Is that the plug that @aaen is referring to above? It would be awesome if it's really that simple, but I think there may also be some voltage compatibility issues with various aftermarket cameras.
  5. Jan 13, 2019 at 7:58 PM
    Taco_Coma
    South NJ
    2018 DCSB SR5
    Yes, I didn’t even see his post when i was typing. The tailgate just unplugs and you should be able to plug into there
  6. Jan 13, 2019 at 9:10 PM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Exactly right... its not always that simple... check voltage for compatibility on aftermarket cameras.
    paleh0rse[QUOTED] likes this.
  7. Jan 13, 2019 at 11:06 PM
    aaen
    Northern Alberta
    Just reuse the one out of the tailgate or buy a second one from the Toyota. That is all I did .
    -40[OP] likes this.
  8. Jan 14, 2019 at 4:46 AM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    You could just add a second camera line without messing with oem one. I have an anytime second cam for front on a toggle switch but no reason why you cant put it in back
  9. Jan 14, 2019 at 7:59 PM
    North Dakota
    So best plan for me. I think I’ll buy a new factory one and try to hook up by the tail gate wires. I don’t care about the old one. It can sit there and look pretty.
  10. Jan 14, 2019 at 8:38 PM
    aaen
    Northern Alberta
    You may need to extend the wiring, I had to, just make sure you offset you splices so you do not end up with one giant section.
