Back Up Camera Stopped Working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bajarenegade, Sep 4, 2021.
  1. Sep 4, 2021 at 1:28 PM
    Bajarenegade
    Bajarenegade [OP] Member
    2016 Gray Tacoma Quad Cab Longbed 4x4
    KMC Wheels, KO2’s, Add A Leaf, Bilsteins, Skid Plates, Prinsu Roof Rack, Front Camera
    Has anyone experienced their backup camera all of a sudden not being displayed in the console? I JD a dead battery which I switched out and after that no camera. I also have a front camera wired in that allows me to switch views and that does not work.
  2. Sep 4, 2021 at 1:38 PM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    Have you checked the inline fuse for whatever aftermarket camera "switcher" you installed?
    If that fuse is ok, I'd disconnect the battery for a few minutes to see if it sorts itself out when you reconnect the battery.
  3. Sep 4, 2021 at 5:07 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    If it was just your rear camera which was non-op I'd start with the connection near the tailgate. Since it's both cameras, look for something more central. A fuse or common switch is a good suggestion. If nothing else, temporarily un-hook the front camera and see if the rear one starts working again.
  4. Sep 4, 2021 at 5:17 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    I assume you have the “any time backup camera mod” from your description. Check the diode, as that’s a huge weak point since they are using a diode incorrectly in their circuit. (also why you can buy replacements from them), as they fail a lot.
    caliburrito likes this.
