Back up camera stopped working
Discussion in 'Audio & Video' started by Diabl0, Dec 26, 2021.
  1. Dec 26, 2021 at 6:13 AM
    Diabl0
    Diabl0 [OP] 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    My back up camera was flickering a few days ago and just stopped working today. It says no input on the screen. Is it broken? It’s been installed a few years now.
  2. Dec 26, 2021 at 7:44 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Normally when I saw this, either the ground or power wire had come loose or corroded
  3. Dec 26, 2021 at 7:51 AM
    Diabl0
    Tim
    Massachusetts
    I didn’t do the install it was done by some shop by the previous owner. Are you talking about where it ties into the reverse lights?
  4. Dec 26, 2021 at 7:52 AM
    Diabl0
    Tim
    Massachusetts
    It says no video signal I just checked behind the radio and it all looks good
  5. Dec 26, 2021 at 7:56 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Guess you'll have to turn around to look for a while until its fixed.
    Check the wiring at the camera end.
  6. Dec 26, 2021 at 8:29 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yeah depending on the camera, a lot of them have their ground wire back near the camera itself. The wire is insanely small, and most shops will crimp on a ring terminal that is far too big. They also won’t put on any heat shrink so the wire will simply rust and fall loose of the ring terminal that is screwed into some sheet metal and also probably rusty.
    crawl under the back end with a flash light and look for the camera wire and see if there are any wires dangling around
  7. Dec 26, 2021 at 8:34 AM
    Diabl0
    Tim
    Massachusetts
    I found a rusty wire screwed to the bottom of the bumper. Not sure if it’s the camera though.
  8. Dec 26, 2021 at 8:57 AM
    Diabl0
    Tim
    Massachusetts
    It’s a white wire I think it goes to my trailer hitch lights. I’m not sure where the ground is for the camera there are a lot of wires back there. It could go to the light it self right?
  9. Dec 26, 2021 at 9:20 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Won’t know until your trace it from the camera back till you find it
  10. Dec 28, 2021 at 2:09 PM
    jpking17
    jpking17 Well-Known Member
    2016 TRD Off Road
    Try powering off/power on. Disconnect the battery and leave it for a couple hours. Try all simple solutions first.
