Back Up Camera Wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06BLUEDBLSPORT, Dec 6, 2009.
  1. Dec 6, 2009 at 5:09 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT [OP] Well-Known Member
    Colin
    Lubbock Texas
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    I bought a back up camera and it appears i need to tap into the reverse light wiring to get the camera to work. I was wondering if there is anyway to bypass that little safety feature on my camera, if not, where is the nearest reserve light wire thats near the cab that i can splice. If i cant get it to work i am stopping by the dealership
  2. Dec 6, 2009 at 5:33 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
  3. Dec 6, 2009 at 5:37 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    Which safety feature? by tapping into the reverse light bulb wiring..you're making the camera turn on as soon as the reverse light bulb turns on. (the way it should be)
  4. Dec 6, 2009 at 5:41 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    yeah thats what its intending for me to do, but i want to bypass that so i dont have to tap into the reverse light wiring
  5. Dec 6, 2009 at 5:52 PM
    05PreRunner
    <-(714)-> SO-CAL
    If you don't want to tap into any wiring, then you're gonna have to run a whole new wire from the battery and just run it off a switch.
    Then you would be able to turn on the camera whenever you wanted
  6. Dec 6, 2009 at 5:56 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    DAMMIT WHY CANT YOU LIVE CLOSER!! then you could probably help me get this done in no time
  7. Dec 6, 2009 at 8:01 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
  8. Dec 6, 2009 at 8:02 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    why don't you want it to turn on when you backup, that's the point haha
  9. Dec 6, 2009 at 8:06 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    hahaha well its just i dont want to have to tap into the reverse lights, i want to just kinda power up and see whats behind me lol
  10. Dec 6, 2009 at 8:11 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Colin you have that fog light on your trailer wiring harness, right? Just tap into that with a new wire to the reverse lights in the fuse box.
  11. Dec 6, 2009 at 8:58 PM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    This diagram I drew up for you will allow the camera to turn on when engaged into reverse or whenever you want with a switch. The diode is to prevent current going to the reverse wire and turning the reverse lights on when you flick the switch on in a gear other than reverse.
  12. Dec 6, 2009 at 9:05 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    Thanks bro that looks great!! so doing this it will allow me to turn on the camera while in Drive?
  13. Dec 6, 2009 at 9:08 PM
    griffin407c
    Upstate NY
    yup.
    the camera will turn on everytime you engage the truck into reverse. if you're in park, drive, neutral, whatever.... just flip the switch on and the camera will come on in any gear.
  14. Dec 6, 2009 at 9:09 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    sweet deal man!!! quick question, where would those wires be located.
  15. Dec 6, 2009 at 9:20 PM
    griffin407c
    Upstate NY
    there's plenty of ignition sourced wires within the cab. the reverse wire can be found in the cab as well, behind the driver-side kick panel or you can find it out back at the tails.
