Back up camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GT150, Nov 16, 2009.
  1. Nov 16, 2009 at 7:03 PM
    GT150
    GT150 [OP] Well-Known Member
    Blairsville Ga
    2010 Prerunner V-6
    Is there a way to disconnect the back up view finder in the rear view mirror?............I don't like it............
  2. Nov 16, 2009 at 7:22 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    The signal cable must be disconnected prior to tailgate removal. Plugs to weather-proof the cable ends ought to be in your glove box.
    Disconnect the cable and plug the ends. The camera signal won't have a path.
    I'd be curious to know if you would then have a blank screen pop up in the mirror when you go to reverse. If so, someone with a wiring diagram would have to provide clues to shutting down power to the camera or amputating it.
  3. Nov 16, 2009 at 7:25 PM
    LoHoNas
    LoHoNas Well-Known Member
    Jeff
    Lake Jackson TX.
    09 4x4 DC TRDSPORT MGM
    Debadged, Fog light mod,Grillcraft, Icons,TC UCA's, OME dakar leaf pack,Procomp 7089,BFG KM2 285/70/17 JVC NAV
    Not sure, but I'm thinking you can just turn it off with the button on the mirror it self.
  4. Nov 16, 2009 at 7:27 PM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    If I can find the thread where the guy disconnected it to make it come on anytime, you could probably just unplug it in that black thing that comes down from the roof to the top of the mirror. Inside that should be a plug that gives power to the monitor, but I don't know if that disconnects power for the auto-dimming function as well.
  5. Nov 16, 2009 at 7:28 PM
    def4pos8
    Ohio
    Isn't that the auto-dim, on/off switch?
  6. Nov 16, 2009 at 7:30 PM
    Chad
    Chad
    Raleigh, NC
  7. Nov 16, 2009 at 7:49 PM
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    Yes, pressing it while in reverse will turn the camera off.
  8. Nov 16, 2009 at 7:56 PM
    LoHoNas
    Jeff
    Lake Jackson TX.
    X2, yep what he said;)
