Back up fog lights or brighter bulb replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fore, Sep 26, 2009.
  1. Sep 26, 2009 at 11:09 AM
    Fore
    Fore [OP] Well-Known Member
    07 PreRunner
    Would like to install cheap but decent small back up clear lights similar to fog lights, has anyone done this before and can it be done with just tapping into the existing reverse lights or 4 prong trailer hook up wire? Would like to do this with no relay or switch to deal with and not having to wire it directly up to the battery? Or are there replacement bulbs brighter that won't melt the plastic lens cover that will work just as good? Please post your pic's if you have them.
  2. Sep 26, 2009 at 11:13 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I like 2 do something 2, don't C much with OEM back up lights.
  3. Sep 26, 2009 at 11:32 AM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    Lots of people have light mounted back there but to use for normal reverse like in parking lots I would think they would be too bright and against the law? Using them offroad or maybe doing some work at night would be OK and all you need is another switch, real easy set up.
  4. Sep 26, 2009 at 12:16 PM
    Reznor88
    Reznor88 Well-Known Member
    Northern California
    '06 PreRunner DC Off Road
  5. Sep 26, 2009 at 12:19 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i had them on my 02. they were tapped into the reverse lights wire. i think i had a toggle switch too.i cant recall right now
  6. Sep 26, 2009 at 12:58 PM
    george3
    new jersey
    tacoma
  7. Sep 26, 2009 at 2:46 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Pep Boys use to sell a 50W replacement back up bulb, and I never saw them anywhere else. I wonder if they still sell them...
  8. Sep 27, 2009 at 7:26 AM
    Fore
    07 PreRunner
  9. Sep 27, 2009 at 8:13 AM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
  10. Sep 27, 2009 at 8:28 AM
    dhurley
    Doug
    Here's another option. It's a Bully hitch light. Costs about 50 bucks.
  11. Sep 27, 2009 at 11:19 AM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    ^ That's probably the cleanest look out there. It's also protected by the hitch vs. placing them under the bumper as a bolt on. That looks out of place. I like the above.
  12. Sep 29, 2009 at 11:48 AM
    dhurley
    Doug
    At least here in the Springs, Pep Boys carries them in stock. It's 70 watts of light. You can wire directly to reverse lights or put it on a switch (included?).
