Back wheels dont spin
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dexter00, Feb 22, 2012.
  1. Feb 22, 2012 at 8:38 AM
    dexter00
    dexter00 [OP] New Member
    Daly
    SoCal
    09 Tacoma
    i just got my truck and washed it last night. this morning, the truck wont move in drive or reverse. the front tires spin but the back tires wont move as if the brakes or emergency brakes are frozen. its a 2009 tacoma trd 4x4 so this shouldnt happen. any ideas on what this could be and how to fix this? :eek:
  2. Feb 22, 2012 at 8:42 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Maybe the ebrake is stuck on Cuz if the front wheel spin that means your tranny is fine it engages but not sure if I'm right could be something else
  3. Feb 22, 2012 at 3:24 PM
    JKD
    JKD Well-Known Member
    If the front wheels are spinning with 4wd engaged, something must be broken. The Tacoma doesn't have a fluid coupling between the front and rear driveshafts.
    More likely OP means the front wheels spin when you jack that corner up.
    OP, release parking brake and hammer on the brake drums with a rubber mallet, then put it in gear. Is it below freezing where you are? Maybe heat those drums up (carefully).
  4. Feb 22, 2012 at 6:08 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Uh oh...
    I know for a fact I read on here from at least two different members they had their drums lock up after launching boats. If memory serves, one of them had a leaking axle seal, but it's been a while since I read it.
  5. Feb 22, 2012 at 6:15 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I'm curious to hear a little more.
