Backfire or Pop When Starting Cold Engine
Discussion in '4 Cylinder' started by wingspar, Oct 6, 2011.
  1. Oct 6, 2011 at 3:30 PM
    wingspar
    wingspar [OP] Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    I searched and found old threads on the subject, but too old to bring back up. Seems to be common, but I only read where one person left their rig at the Dealer overnight so they could hear it for themselves. They said there was nothing wrong.
    Mine is a 2011 model with only 2,500 miles on it. I never noticed the pop till my other half heard it the other day, and said something. Now, I hear it when I start the engine when it is cold. It’s a little bothersome, but it almost seems to be normal from what I’ve read so far. Sure doesn’t seem like something like that should be normal. Should I just ignore it?
  2. Oct 7, 2011 at 9:23 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Mine still does it at times...there is a theory that gases are trapped in the exhaust system on shutdown and this creates the "backfire" on start up the next day. :confused:
    Nessmuk likes this.
  3. Oct 7, 2011 at 9:26 AM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    I think we've read through the same threads.
    Several people reported that their trucks don't do it any longer if they let it idle for 20 to 30 seconds before shutting it off.
  4. Oct 7, 2011 at 11:30 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I think this is normal and is caused by the emissions blower motor. It forces fresh air into the exhaust manifold during cold startup in order to continue burning the unburned fuel in exhaust gases. All that extra oxygen is bound to cause flash burning and the resulting 'pop' that we hear
  5. Oct 7, 2011 at 2:59 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    mine makes a few little pops when it starts but u have to be outside of the truck near the exhaust to hear them
  6. Oct 8, 2011 at 9:10 AM
    wingspar
    Oregon
    Thanks for the feedback. Guess I'll ignore it, but it does make me imagine the truck runs rough while diving it. Wonder why it pertains to this engine? I think, tho I could be wrong, I have the same engine in my 2007 Camry, and it doesn’t do it.
  7. Oct 8, 2011 at 11:24 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Happens to mine only when it gets cold out
  8. Oct 9, 2011 at 6:06 AM
    ecoterragaia
    Central Virginia
    Next time you're ready to cold start, pop the hood first and locate the emission blower motor. It's mounted on the truck body infront of the engine on the passenger side. It's round and has a black plastic housing, plain as day.
    Start the truck then go back to engine bay. You'll notice that the blower motor sounds like a like a shop-vac running. It will stay running for about 8-10 seconds. Once it shuts off, the ECU goes into closed loop mode and the idle will settle down.
    During the time that the blower is running is when you'll notice the 'pops'. I believe this is the continued burning of fuel, which is the point of the blower in the first place. The V6 Tacoma engines do not have this. A co-worker has an '07 Camry, and I didn't see a blower on that engine either (2.4L engine).
  9. Oct 9, 2011 at 11:02 AM
    2007 tacoma
    2007 Access Cab
    I think I know what you're talking about. You basically just look down and to the left and there's this air pump.
    Is this shutdown the disembodied VRRROOEEAAM sound I notice under the hood after cranking the truck? When I leave work tomorrow I'll pop the hood and get out to listen.
  10. Oct 11, 2011 at 10:14 AM
    wingspar
    Oregon
    I found the blower. Little almost flat round thing. I could not really hear much of a difference between startup and after the engine rpm’s slowed down. Kind of gets lost in all the other engine noise. I even video taped the exhaust pipe. No pop or backfire. It was about 64 degrees with a light rain, so maybe it wasn’t cold enough?
  11. Oct 11, 2011 at 12:09 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    My 2007 never did this, my 2011 does, it kinda starts rough. Like it hesitates prior to starting.
  12. Oct 12, 2011 at 6:20 PM
    wingspar
    Oregon
    It popped today, and it was about 54 degrees outside. Is there a certain outside temp that one always gets the pop/backfire? I’d like to set the video cam up and actually capture one.
    TacoFun likes this.
  13. Oct 12, 2011 at 6:23 PM
    joes06tacoma
    Joe
    Central Coast, CA
    We have two identical 2009 2.7 5speed trucks at work. I drive one of them. Mine has done it every morning since I have had it. It's got 54K on it now. The other truck probably has 30K on it and my co worker who drives it has commented on the same noise on cold starts. I don't know what it is, but it seems to be common and harmless.
    TacoFun likes this.
  14. Oct 15, 2011 at 12:02 PM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    Mine does it during the first start of the day.
  15. Oct 18, 2011 at 8:53 AM
    m1a1mg
    m1a1mg Member
    Manhattan, KS
    09 Tacoma
    Glad it isn't just mine.
  16. Oct 25, 2011 at 5:58 PM
    wingspar
    Oregon
    Mine hasn’t done it since I posted last. I’ve set the video cam up to tape it twice, and it didn’t happen either time. Kind of like when you take a vehicle that is acting up to a mechanic, and it purrs like a kitten for him.
  17. Oct 26, 2011 at 12:49 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I have same Taco as you and never had a problem.
    And a thread is never "too old to bring back up" you post to it and presto it's alive again.
  18. Nov 10, 2011 at 4:47 PM
    Icewatersteam
    Icewatersteam Comptroller
    2.7L 4cyl 4x4
    Mine's done it once or twice, almost certainly a pop and not a backfire. I theorize it's the release of a little stored tension from the contraction of the cold
  19. Nov 17, 2011 at 4:38 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    noticed this multiple times once it started getting cold. doesnt seem like it should be normal but oh well! but why does the emission blower only do this when its cold out?
  20. Nov 17, 2011 at 7:25 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Mine does it sometimes too but I've just been putting blame on the intake and exhaust and ignoring it.
