Backfire or Pop When Starting Cold Engine
Discussion in '4 Cylinder' started by wingspar, Oct 6, 2011.
  1. Nov 17, 2011 at 7:48 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    If I leave the key in "on" for a few seconds before starting it happens less. I read somewhere on here that letting key be "on" for a few seconds makes for a quicker/smoother start.
    TacoFun likes this.
  2. Jan 23, 2013 at 9:40 PM
    alwaysfaded
    alwaysfaded Well-Known Member
    Adam
    So. Cal.
    08 Black taco, 5 spd.
    blacked out tint, k&n drop in, removed secondary filter, kenwood 7" touchscreen, 12" memphis audio sub, 1000 watt amp, Alpine type R conponets
    I have noticed this as well. When it's cold out, and I first start my truck in the morning it pops. Oh well glad to hear that it's common and shouldn't affect anything.
    TacoFun likes this.
  3. Jan 22, 2018 at 3:32 AM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    Glad to find this thread. Guess by the 2015 models it still wasn't worked out. Mine just started doing this the past weekend. Not really that cold compared to others areas but cold for so-cal (30s at night)
    TacoFun likes this.
  4. Jan 22, 2018 at 11:02 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Mine does it during the Texas summers too :confused:
  5. Jan 22, 2018 at 2:19 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Mine does this at random but not very often. Would like to see a video to confirm we are all talking about the same thing... maybe I will put one up. There does seem to be a correlation between the pop and colder start temperatures. My theory is that the colder temps require a richer fuel mix on startup, which in turn puts more raw fuel into the exhaust, which causes the pop when mixed with fresh air from smog pump. I also think the air pump adding air to burn the raw fuel in exhaust is what lights off the cat quickly. I don't see any other reason for an engine to immediately rev to 2200 rpm from a dead cold start.
    ecoterragaia likes this.
  6. Jan 23, 2018 at 4:27 PM
    wingspar
    wingspar [OP] Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    Wow, this is an old thread, and what blows my mind even more is that it is a thread I started... Almost 7 years ago. I so rarely hear the popping noise when I start it up anymore, maybe once every other month. I’ve forgot all about the temperature of the air when starting. Maybe I’ll pay attention to it, but for something that happens once every few weeks/months, getting it on video wasn’t possible for me.
    Thesandaddict likes this.
  7. Jan 27, 2018 at 9:24 PM
    Col_Macklin
    Col_Macklin Well-Known Member
    2013 Murdered Taco/ ACAB 4wd 2.7L
    Ha..mine does it too from time to time. Good to know its common. Thanks for the post.
  8. Jan 31, 2020 at 5:21 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Your 2017 motor had to be rebuilt? Did you find out what was the cause? This is the first ive read of a low mileage 3rd gen 2TR failure
    I hear this on mine sometimes during start up as well. Ive always thought it was normal
    TacoFun[QUOTED] likes this.
  9. Feb 4, 2022 at 3:19 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 97 & 98 EK, 23 Klx300R, 2014 Bolt R-spec
    just a couple of things tbh
    old thread i know but im having a similar issue with my truck and its never done this before until now....
    2013 tacoma with 128k miles when it sits for a bit it will go to start fall flat on its face backfire and then slowly start up and run fine afterwards no loss of power or bad idle its just that startup... and its not all the time either in a week or two time frame its only happened 4 times i have no idea what the issue is or if its normal from what you all say its normal but mine is slightly different where it about dies then starts so idk...
