BackFire...popping at idle?
Discussion in '4 Cylinder' started by mobius, Apr 27, 2010.
  1. Apr 27, 2010 at 6:34 AM
    mobius
    mobius [OP] Well-Known Member
    Bluegrass State
    07 Tacoma SR5 / 07 4Runner SR5
    Hey guys,
    Quick question...I have an 07 access cab 4x4 4banger and notice that it backfires a bit. For example, I noticed it the other day driving down a back road...down hill, 4th gear, about 35mph. The other day I noticed it pop....pop...pop during idle. I usually run the cheap gas in it, 87. Has anyone noticed this? Should I be worried?
  2. Apr 27, 2010 at 6:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    No codes or CEL?
    Sounds like you maybe runnig rich or possibly a timing issue.
    I would suggest cleaning your MAF and pulling the battery NEG cable for a few minutes. Maybe the ECU developed a brainfart. Double check for some loose vac lines too.
  3. Apr 27, 2010 at 7:00 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    When was the you cleaned your fuel system. Put a can of seafoam in your tank.
  4. Apr 27, 2010 at 7:16 AM
    mobius
    Bluegrass State
    Thanks for the reply guys...honestly I've never cleaned my fuel system. Guess its time :) Seafoam? Never heard of that. Is it something I can pick up at Auto Zone? Just pour it in and run the engine?
  5. Apr 27, 2010 at 7:20 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Apr 27, 2010 at 7:34 AM
    mobius
    Bluegrass State
    Thanks 98 for the info...very helpful. Guess I now have plans this weekend :D
  7. Apr 27, 2010 at 7:35 AM
    98tacoma27
    Ben
    Not Beech Creek
  8. Apr 27, 2010 at 11:50 AM
    mobius
    Bluegrass State
    What should the timing be? What are you guys running? I get a ton of highway miles.
  9. Apr 27, 2010 at 11:53 AM
    Danosabre
    Dan
    Gardner,Ma
    09 TRD Off Road
    How many miles on it, and when did you last change the plugs?
  10. Apr 27, 2010 at 11:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    The timing is electronic and not adjustable. It's controlled by your crank sensor. Don't read into this too much yet. Do the simple easy fixes first or until a code pops up.
  11. Apr 27, 2010 at 12:04 PM
    mobius
    Bluegrass State
    Thanks 98...will do.
    Dano...I have 65k on it, changed the plugs around 25k. Probably wouldn't hurt to throw a new set in?
