Backfire, "skipping" but no CEL
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buckaroo1993, Mar 8, 2017.
  1. Mar 8, 2017 at 2:21 PM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    Today I was pulling out from work and the truck backfired twice pretty loud. It then started "skipping" when under a load and several other minor backfires while I made it home but NO CEL! Is this normal? (No CEL light that is. lol) Idles rough too. Do I simply start pulling wires until I find the one that makes no difference?
  2. Mar 8, 2017 at 2:30 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Is it a 4 cylinder? I had spark plugs go bad under load but would idle fine.
  3. Mar 8, 2017 at 2:57 PM
    Buckaroo1993
    Vinny
    Georgia
    3.4L V-6. Idles rough. Ran fine this morning going to work.
  4. Mar 8, 2017 at 2:58 PM
    Rmodel65
    Jawja
    1996 Yota 4x4
    Viper Red paint
    I'd start with the plugs pull them and see how they look if they need to be replaced male sure to buy the correct two electrode style to replace them
  5. Mar 8, 2017 at 4:54 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Did you just fill up? Maybe some bad gas? Weird it doesn't throw a code though.
    wilcam47 likes this.
  6. Mar 8, 2017 at 4:58 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    Check the fuel filters, can't hurt to go through and clean the throttle body and MAF. Might find something in the process
  7. Mar 8, 2017 at 4:59 PM
    Buckaroo1993
    Vinny
    Georgia
    Yeah. I filled up yesterday as a matter of fact with 93. But I was on fumes and drove home yesterday and to work today and like I said, no problems until this afternoon. Weird.
  8. Mar 8, 2017 at 5:45 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Could be coil pack/igniter on its way out. Mine did the same. Ran on 5 cylinders for about a week until #3 misfire CEL came on. Was wondering why I couldn't go as fast up hill. Took a week for the code to come on. That's strange but it happened.
  9. Mar 8, 2017 at 6:12 PM
    Buckaroo1993
    Vinny
    Georgia
    Did you replace the entire coil pack or just the boot?
  10. Mar 8, 2017 at 6:24 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    pull the coils and look at the boots, if you shop you can get boot kit for reasonable prices.
    Odds are one if not all 3 are cooked on the bottom. boots and wires are a good place to start
    plugs if you think you may need them ( get the correct dual electrode Densos)
    cruxofthebisquit likes this.
  11. Mar 8, 2017 at 6:32 PM
    K-reg1776
    K-reg1776 Member
    2000 Red Tacoma
    Id start with things you can take apart and clean before spending money on parts you might not need. I try taking the Throttle body off, clean that, clean the IAC, the intake manifold and replace the gasket for the throttle body to the intake. Its maybe $3. I used seafoam and throttle body cleaner and it worked like a champ. Drives like its new again. Good luck. Also like many said check your wires, plugs, and coil packs.
  12. Mar 8, 2017 at 7:10 PM
    Buckaroo1993
    Vinny
    Georgia
    How often do the packs go bad?
  13. Mar 8, 2017 at 7:21 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    my junk has 220k, i've replaced one, but that was only because it was easier to get than the boot kit and i needed the truck, was not really convinced it was bad at the time but didn't have time to thoroughly diag. it was a "Make it run" situation
  14. Mar 8, 2017 at 8:42 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    pacs rarely go bad but the boots are basically a short spark plug wire....and they start looking like the one posted above eventually.
  15. Mar 8, 2017 at 8:47 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    How about starting with the fact there is no check engine light. When you initially turn the key on, does the light illuminate? If not, you may want to replace that bulb. After that, you should be able to pull codes with a paper clip. Maybe you already confirmed the light comes out...you never mentioned that.
  16. Mar 11, 2017 at 8:20 PM
    Buckaroo1993
    Vinny
    Georgia
    Well...this afternoon I was pulling the truck into the garage to work on it tomorrow (been driving the 4R since this started) and FINALLY the CEL came on. I don't have a code reader and it runs way too rough to drive it to Autozone or wherever. How can I check the code with a paperclip as stated above?
  17. Mar 11, 2017 at 10:23 PM
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
  18. Mar 12, 2017 at 6:02 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Search obd2 paper clip and some you tube videos will come up.
  19. Mar 14, 2017 at 5:16 PM
    Buckaroo1993
    Vinny
    Georgia
    I have read numerous "opinions" on the gap of dual electrode spark plugs. Some say they come "pre-gapped" and throw them in while just as many others say to check the gap first. (From the NGK website: "A spark plug part number might fit hundreds of different engines from many different manufacturers. Although the NGK factory will set the gap to a preselected setting, this may not be the right gap for your particular engine.") If the gap calls for .044" is that for EACH side or the cumulative of BOTH sides? ( I read on a post that someone checked the gap and it showed .022" on each side but it called for .044" so he adjusted both sides to .044". I need to know...definitively...do I or do I NOT gap dual electrode plugs? If so, do I gap each side to spec OR each side to "half" spec?
    P.S. Code read P0302 - Misfire on #2 cylinder
  20. Mar 14, 2017 at 5:23 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    could be some bad gas...maybe try putting some seafoam or something like that. If its not throwing a code yet it might not be quite bad enough for the part to go but will be soon. If the CEL light comes on and is flashing dont drive it untill you fix the problem.
